--- ray/src/common/color.h 2009/05/21 18:08:43 2.30 +++ ray/src/common/color.h 2011/05/20 02:06:38 2.31 @@ -1,9 +1,7 @@ -/* RCSid $Id: color.h,v 2.30 2009/05/21 18:08:43 greg Exp $ */ +/* RCSid $Id: color.h,v 2.31 2011/05/20 02:06:38 greg Exp $ */ /* * color.h - header for routines using pixel color values. * - * Must be included after X11 headers, since they declare a BYTE type. - * * Two color representations are used, one for calculation and * another for storage. Calculation is done with three floats * for speed. Stored color values use 4 bytes which contain @@ -28,10 +26,10 @@ extern "C" { #define COLXS 128 /* excess used for exponent */ #define WHT 3 /* used for RGBPRIMS type */ -#undef BYTE -#define BYTE unsigned char /* 8-bit unsigned integer */ +#undef uby8 +#define uby8 unsigned char /* 8-bit unsigned integer */ -typedef BYTE COLR[4]; /* red, green, blue (or X,Y,Z), exponent */ +typedef uby8 COLR[4]; /* red, green, blue (or X,Y,Z), exponent */ typedef float COLORV; typedef COLORV COLOR[3]; /* red, green, blue (or X,Y,Z) */
