--- ray/src/common/color.h 2003/05/13 17:58:32 2.20 +++ ray/src/common/color.h 2003/06/06 16:38:47 2.21 @@ -1,4 +1,4 @@ -/* RCSid $Id: color.h,v 2.20 2003/05/13 17:58:32 greg Exp $ */ +/* RCSid $Id: color.h,v 2.21 2003/06/06 16:38:47 schorsch Exp $ */ /* * color.h - header for routines using pixel color values. * @@ -9,16 +9,18 @@ * for speed. Stored color values use 4 bytes which contain * three single byte mantissas and a common exponent. */ +#ifndef _RAD_COLOR_H_ +#define _RAD_COLOR_H_ +#ifdef __cplusplus +extern "C" { +#endif + #include "copyright.h" #include #include -#ifdef __cplusplus -extern "C" { -#endif - #define RED 0 #define GRN 1 #define BLU 2 @@ -204,41 +206,7 @@ extern COLOR cblack, cwhite; /* black (0,0,0) and whi #define cpcolormat(md,ms) memcpy((void *)md,(void *)ms,sizeof(COLORMAT)) #endif -#ifdef NOPROTO /* defined in color.c */ -extern char *tempbuffer(); -extern int fwritecolrs(); -extern int freadcolrs(); -extern int fwritescan(); -extern int freadscan(); -extern void setcolr(); -extern void colr_color(); -extern int bigdiff(); - /* defined in spec_rgb.c */ -extern void spec_rgb(); -extern void spec_cie(); -extern void cie_rgb(); -extern int clipgamut(); -extern void colortrans(); -extern void multcolormat(); -extern void compxyz2rgbmat(); -extern void comprgb2xyzmat(); -extern void comprgb2rgbmat(); -extern void compxyzWBmat(); -extern void compxyz2rgbWBmat(); -extern void comprgb2xyzWBmat(); -extern void comprgb2rgbWBmat(); - /* defined in colrops.c */ -extern int setcolrcor(); -extern int setcolrinv(); -extern int setcolrgam(); -extern int colrs_gambs(); -extern int gambs_colrs(); -extern void shiftcolrs(); -extern void normcolrs(); - -#else - /* defined in color.c */ extern char *tempbuffer(unsigned int len); extern int fwritecolrs(COLR *scanline, int len, FILE *fp); extern int freadcolrs(COLR *scanline, int len, FILE *fp); @@ -273,8 +241,9 @@ extern int gambs_colrs(COLR *scan, int len); extern void shiftcolrs(COLR *scan, int len, int adjust); extern void normcolrs(COLR *scan, int len, int adjust); -#endif #ifdef __cplusplus } #endif +#endif /* _RAD_COLOR_H_ */ +
