root/radiance/ray/src/common/color.h
Wed Jan 17 17:36:20 2024 UTC (4 months, 2 weeks ago) by greg
Changes since 2.44: +6 -3 lines
Diff to previous 2.44 , to selected 2.14
feat: Added convertscolorcol() to generate better RGB result
Sat Dec 16 01:00:02 2023 UTC (5 months, 2 weeks ago) by greg
Diff to previous 2.43 , to selected 2.14
fix: Fixed issue with buffer overrun (showed up mostly under Windows)
Fri Dec 15 03:42:31 2023 UTC (5 months, 2 weeks ago) by greg
Changes since 2.42: +7 -7 lines
Diff to previous 2.42 , to selected 2.14
refactor: Removed unnecessary parens
Thu Dec 14 19:54:03 2023 UTC (5 months, 2 weeks ago) by greg
Changes since 2.41: +2 -2 lines
Diff to previous 2.41 , to selected 2.14
fix: fixed potential issue with macro
Mon Nov 27 21:00:14 2023 UTC (6 months ago) by greg
Changes since 2.40: +6 -3 lines
Diff to previous 2.40 , to selected 2.14
refactor: Added number of spectral samples and wavelength splits to arguments
Tue Nov 21 01:30:20 2023 UTC (6 months, 1 week ago) by greg
Changes since 2.39: +7 -8 lines
Diff to previous 2.39 , to selected 2.14
Fri Nov 17 20:02:07 2023 UTC (6 months, 2 weeks ago) by greg
Diff to previous 2.38 , to selected 2.14
Wed Nov 15 18:02:52 2023 UTC (6 months, 2 weeks ago) by greg
Changes since 2.37: +156 -15 lines
Diff to previous 2.37 , to selected 2.14
Fri Apr 14 15:49:32 2023 UTC (13 months, 2 weeks ago) by greg
Diff to previous 2.36 , to selected 2.14
perf: Reduced ridiculous number of digits included in exposure
Sat Mar 5 17:18:02 2022 UTC (2 years, 2 months ago) by greg
Diff to previous 2.35 , to selected 2.14
refactor: changed char *tempbuffer() to void *tempbuffer()
Sun Nov 14 17:30:02 2021 UTC (2 years, 6 months ago) by greg
Changes since 2.34: +14 -5 lines
Diff to previous 2.34 , to selected 2.14
feat(rpict, rvu): added Sharp RGB primary rendering ability with -DSHARP_RGB
Thu Mar 26 15:40:32 2015 UTC (9 years, 2 months ago) by greg
CVS Tags: rad5R0, rad5R1, rad5R2, rad5R3
Changes since 2.33: +5 -5 lines
Diff to previous 2.33 , to selected 2.14
Fixed exact value for white
Wed Sep 11 16:00:13 2013 UTC (10 years, 8 months ago) by greg
Diff to previous 2.32 , to selected 2.14
Added stdio.h as needed on some build systems
Mon Feb 4 03:42:13 2013 UTC (11 years, 3 months ago) by greg
Diff to previous 2.31 , to selected 2.14
Added return value to primsval() macro
Fri May 20 02:06:38 2011 UTC (13 years ago) by greg
Changes since 2.30: +4 -6 lines
Diff to previous 2.30 , to selected 2.14
Thu May 21 18:08:43 2009 UTC (15 years ago) by greg
Diff to previous 2.29 , to selected 2.14
Tue Sep 5 21:54:32 2006 UTC (17 years, 9 months ago) by greg
CVS Tags: rad3R8, rad3R9
Changes since 2.28: +9 -8 lines
Diff to previous 2.28 , to selected 2.14
Added return values and colorprimsOK() function to check primary ranges
Changes since 2.27: +3 -2 lines
Diff to previous 2.27 , to selected 2.14
Sat Oct 18 04:46:24 2003 UTC (20 years, 7 months ago) by greg
Diff to previous 2.26 , to selected 2.14
Minor comment changes
Wed Jul 30 10:11:06 2003 UTC (20 years, 10 months ago) by schorsch
Diff to previous 2.25 , to selected 2.14
Mon Jul 14 22:23:59 2003 UTC (20 years, 10 months ago) by schorsch
Changes since 2.24: +4 -3 lines
Diff to previous 2.24 , to selected 2.14
Mon Jun 30 19:04:29 2003 UTC (20 years, 11 months ago) by greg
Changes since 2.23: +1 -2 lines
Diff to previous 2.23 , to selected 2.14
Mon Jun 30 14:59:10 2003 UTC (20 years, 11 months ago) by schorsch
Changes since 2.22: +1 -5 lines
Diff to previous 2.22 , to selected 2.14
Changes since 2.21: +1 -4 lines
Diff to previous 2.21 , to selected 2.14
Fri Jun 6 16:38:47 2003 UTC (21 years ago) by schorsch
Changes since 2.20: +9 -40 lines
Diff to previous 2.20 , to selected 2.14
*** empty log message ***
Tue May 13 17:58:32 2003 UTC (21 years ago) by greg
Diff to previous 2.19 , to selected 2.14
Changes since 2.18: +2 -57 lines
Diff to previous 2.18 , to selected 2.14
Changes since 2.17: +144 -12 lines
Diff to previous 2.17 , to selected 2.14
Wed Oct 21 17:48:06 1998 UTC (25 years, 7 months ago) by gwlarson
Changes since 2.16: +5 -4 lines
Diff to previous 2.16 , to selected 2.14
modifications to avoid problems with redeclared BYTE type
Tue Oct 28 11:13:51 1997 UTC (26 years, 7 months ago) by gregl
Changes since 2.15: +1 -4 lines
Diff to previous 2.15 , to selected 2.14
removed problematic declaration of memcpy()
Wed Sep 17 14:46:26 1997 UTC (26 years, 8 months ago) by gregl
Changes since 2.14: +2 -0 lines
Diff to previous 2.14
fixed macro definition of memcpy
Tue Apr 15 14:12:31 1997 UTC (27 years, 1 month ago) by greg
Diff to previous 2.13
changed STDPRIMS definition to avoid compiler problems
Fri Jan 31 12:39:12 1997 UTC (27 years, 4 months ago) by greg
Changes since 2.12: +6 -2 lines
added clipgamut() routine for performing gamut mapping and clipping
Thu Jan 30 19:14:37 1997 UTC (27 years, 4 months ago) by greg
Changes since 2.11: +4 -3 lines
changed colortrans() to optionally allow negative results
Fri Nov 10 17:04:19 1995 UTC (28 years, 6 months ago) by greg
Changes since 2.10: +0 -1 lines
removed memcpy() declaration
Sun Oct 15 14:07:59 1995 UTC (28 years, 7 months ago) by greg
Changes since 2.9: +61 -4 lines
made changes for new 32-bit_rle_xyze picture type
Fri Sep 2 12:02:17 1994 UTC (29 years, 9 months ago) by greg
added comment as to values of CIE_rf, CIE_gf and CIE_bf
Wed Aug 17 11:07:56 1994 UTC (29 years, 9 months ago) by greg
added 1 digit to accuracy of white
Wed Jun 29 18:16:56 1994 UTC (29 years, 11 months ago) by greg
Changes since 2.6: +41 -4 lines
changed RGB primaries and went to true (i.e. equal-energy) white
Mon Aug 2 13:51:43 1993 UTC (30 years, 10 months ago) by greg
Changes since 2.5: +4 -0 lines
added conditional atof() declarations
Fri Jun 4 14:51:41 1993 UTC (31 years ago) by greg
Changes since 2.4: +0 -7 lines
removed incompatible atof(), ldexp() and frexp() defines
Fri Oct 2 15:54:25 1992 UTC (31 years, 8 months ago) by greg
Thu May 28 09:25:26 1992 UTC (32 years ago) by greg
changed /256 to >>8 for compilers that aren't so swift
Thu Dec 19 14:45:43 1991 UTC (32 years, 5 months ago) by greg
Tue Nov 12 16:54:49 1991 UTC (32 years, 6 months ago) by greg
Diff to previous 1.15 , to selected 2.14
Mon Nov 11 14:00:12 1991 UTC (32 years, 6 months ago) by greg
Changes since 1.14: +1 -6 lines
Diff to previous 1.14 , to selected 2.14
Thu Oct 24 12:15:07 1991 UTC (32 years, 7 months ago) by greg
Changes since 1.13: +10 -2 lines
Diff to previous 1.13 , to selected 2.14
added new definition for efficacies
Thu Oct 24 10:29:03 1991 UTC (32 years, 7 months ago) by greg
Changes since 1.12: +2 -1 lines
Diff to previous 1.12 , to selected 2.14
fixed definition of luminance
Wed Jul 17 11:52:25 1991 UTC (32 years, 10 months ago) by greg
Changes since 1.11: +9 -9 lines
Diff to previous 1.11 , to selected 2.14
changed XSTRL macros to LXSTR for preprocessors with short id's
Thu Apr 18 12:54:22 1991 UTC (33 years, 1 month ago) by greg
Changes since 1.10: +3 -0 lines
Diff to previous 1.10 , to selected 2.14
added format info to headers
Tue Mar 19 12:06:33 1991 UTC (33 years, 2 months ago) by greg
Diff to previous 1.9 , to selected 2.14
changed constant for watts to lumens in brightness()
Mon Mar 18 09:32:49 1991 UTC (33 years, 2 months ago) by greg
Diff to previous 1.8 , to selected 2.14
added luminance() macro
Fri Dec 14 16:28:20 1990 UTC (33 years, 5 months ago) by greg
Changes since 1.7: +9 -0 lines
Diff to previous 1.7 , to selected 2.14
added macros for color correction header specification
Fri Dec 14 12:48:30 1990 UTC (33 years, 5 months ago) by greg
Changes since 1.6: +7 -3 lines
Diff to previous 1.6 , to selected 2.14
added correct color transformations
Tue Jan 9 10:57:30 1990 UTC (34 years, 5 months ago) by greg
Changes since 1.5: +8 -1 lines
Diff to previous 1.5 , to selected 2.14
added macros for reading and writing pixel aspect ratio info
Fri Jan 5 18:07:19 1990 UTC (34 years, 5 months ago) by greg
Changes since 1.4: +8 -1 lines
Diff to previous 1.4 , to selected 2.14
added macros for reading and writing exposure values
Fri Oct 20 20:35:21 1989 UTC (34 years, 7 months ago) by greg
Diff to previous 1.3 , to selected 2.14
second cut on color normalization
Fri Oct 20 16:45:25 1989 UTC (34 years, 7 months ago) by greg
Changes since 1.2: +9 -1 lines
Diff to previous 1.2 , to selected 2.14
added macros and routines for normalized short colors
Tue Sep 12 12:25:34 1989 UTC (34 years, 8 months ago) by greg
Changes since 1.1: +5 -0 lines
Diff to previous 1.1 , to selected 2.14
added routines for reading and writing picture resolution
Thu Feb 2 10:34:14 1989 UTC (35 years, 4 months ago) by greg
Diff to selected 2.14
