--- ray/src/common/color.h 2003/02/22 02:07:22 2.18
+++ ray/src/common/color.h 2003/06/30 19:04:29 2.24
@@ -1,4 +1,4 @@
-/* RCSid: $Id: color.h,v 2.18 2003/02/22 02:07:22 greg Exp $ */
+/* RCSid $Id: color.h,v 2.24 2003/06/30 19:04:29 greg Exp $ */
* color.h - header for routines using pixel color values.
@@ -9,71 +9,14 @@
* for speed. Stored color values use 4 bytes which contain
* three single byte mantissas and a common exponent.
- * The Radiance Software License, Version 1.0
- * Copyright (c) 1990 - 2002 The Regents of the University of California,
- * through Lawrence Berkeley National Laboratory. All rights reserved.
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following conditions
- * are met:
- * 1. Redistributions of source code must retain the above copyright
- * notice, this list of conditions and the following disclaimer.
- * 2. Redistributions in binary form must reproduce the above copyright
- * notice, this list of conditions and the following disclaimer in
- * the documentation and/or other materials provided with the
- * distribution.
- * 3. The end-user documentation included with the redistribution,
- * if any, must include the following acknowledgment:
- * "This product includes Radiance software
- * (http://radsite.lbl.gov/)
- * developed by the Lawrence Berkeley National Laboratory
- * (http://www.lbl.gov/)."
- * Alternately, this acknowledgment may appear in the software itself,
- * if and wherever such third-party acknowledgments normally appear.
- * 4. The names "Radiance," "Lawrence Berkeley National Laboratory"
- * and "The Regents of the University of California" must
- * not be used to endorse or promote products derived from this
- * software without prior written permission. For written
- * permission, please contact radiance@radsite.lbl.gov.
- * 5. Products derived from this software may not be called "Radiance",
- * nor may "Radiance" appear in their name, without prior written
- * permission of Lawrence Berkeley National Laboratory.
- * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED
- * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
- * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
- * DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR
- * ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
- * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
- * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
- * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
- * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
- * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
- * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
- * SUCH DAMAGE.
- * This software consists of voluntary contributions made by many
- * individuals on behalf of Lawrence Berkeley National Laboratory. For more
- * information on Lawrence Berkeley National Laboratory, please see
-#include
-#include
+#ifndef _RAD_COLOR_H_
+#define _RAD_COLOR_H_
#ifdef __cplusplus
extern "C" {
#endif
+#include
#define RED 0
#define GRN 1
#define BLU 2
@@ -253,47 +196,9 @@ extern COLOR cblack, cwhite; /* black (0,0,0) and whi
#define rgb_cie(xyz,rgb) colortrans(xyz,rgb2xyzmat,rgb)
-#ifdef BSD
-#define cpcolormat(md,ms) bcopy((char *)ms,(char *)md,sizeof(COLORMAT))
-#else
-#define cpcolormat(md,ms) memcpy((char *)md,(char *)ms,sizeof(COLORMAT))
-#endif
+#define cpcolormat(md,ms) memcpy((void *)md,(void *)ms,sizeof(COLORMAT))
-#ifdef NOPROTO
/* defined in color.c */
-extern char *tempbuffer();
-extern int fwritecolrs();
-extern int freadcolrs();
-extern int fwritescan();
-extern int freadscan();
-extern void setcolr();
-extern void colr_color();
-extern int bigdiff();
- /* defined in spec_rgb.c */
-extern void spec_rgb();
-extern void spec_cie();
-extern void cie_rgb();
-extern int clipgamut();
-extern void colortrans();
-extern void multcolormat();
-extern void compxyz2rgbmat();
-extern void comprgb2xyzmat();
-extern void comprgb2rgbmat();
-extern void compxyzWBmat();
-extern void compxyz2rgbWBmat();
-extern void comprgb2xyzWBmat();
-extern void comprgb2rgbWBmat();
- /* defined in colrops.c */
-extern int setcolrcor();
-extern int setcolrinv();
-extern int setcolrgam();
-extern int colrs_gambs();
-extern int gambs_colrs();
-extern void shiftcolrs();
-extern void normcolrs();
-#else
- /* defined in color.c */
extern char *tempbuffer(unsigned int len);
extern int fwritecolrs(COLR *scanline, int len, FILE *fp);
extern int freadcolrs(COLR *scanline, int len, FILE *fp);
@@ -328,8 +233,9 @@ extern int gambs_colrs(COLR *scan, int len);
extern void shiftcolrs(COLR *scan, int len, int adjust);
extern void normcolrs(COLR *scan, int len, int adjust);
-#endif
#ifdef __cplusplus
#endif
+#endif /* _RAD_COLOR_H_ */
