root/radiance/ray/src/common/color.h
Revision: 1.8
Committed: Fri Dec 14 16:28:20 1990 UTC (33 years, 6 months ago) by greg
Changes since 1.7: +9 -0 lines
added macros for color correction header specification
1 /* Copyright (c) 1986 Regents of the University of California */
2
3 /* SCCSid "$SunId$ LBL" */
4
5 /*
6 * color.h - header for routines using pixel color values.
7 *
8 * 12/31/85
9 *
10 * Two color representations are used, one for calculation and
11 * another for storage. Calculation is done with three floats
12 * for speed. Stored color values use 4 bytes which contain
13 * three single byte mantissas and a common exponent.
14 */
15
16 #define RED 0
17 #define GRN 1
18 #define BLU 2
19 #define EXP 3
20 #define COLXS 128 /* excess used for exponent */
21
22 typedef unsigned char BYTE; /* 8-bit unsigned integer */
23
24 typedef BYTE COLR[4]; /* red, green, blue, exponent */
25
26 #define copycolr(c1,c2) (c1[0]=c2[0],c1[1]=c2[1], \
27 c1[2]=c2[2],c1[3]=c2[3])
28
29 typedef float COLOR[3]; /* red, green, blue */
30
31 #define colval(col,pri) ((col)[pri])
32
33 #define setcolor(col,r,g,b) ((col)[RED]=(r),(col)[GRN]=(g),(col)[BLU]=(b))
34
35 #define copycolor(c1,c2) ((c1)[0]=(c2)[0],(c1)[1]=(c2)[1],(c1)[2]=(c2)[2])
36
37 #define scalecolor(col,sf) ((col)[0]*=(sf),(col)[1]*=(sf),(col)[2]*=(sf))
38
39 #define addcolor(c1,c2) ((c1)[0]+=(c2)[0],(c1)[1]+=(c2)[1],(c1)[2]+=(c2)[2])
40
41 #define multcolor(c1,c2) ((c1)[0]*=(c2)[0],(c1)[1]*=(c2)[1],(c1)[2]*=(c2)[2])
42
43 #ifdef NTSC
44 #define bright(col) (.295*(col)[RED]+.636*(col)[GRN]+.070*(col)[BLU])
45 #define normbright(c) (int)((74L*(c)[RED]+164L*(c)[GRN]+18L*(c)[BLU])/256)
46 #else
47 #define bright(col) (.263*(col)[RED]+.655*(col)[GRN]+.082*(col)[BLU])
48 #define normbright(c) (int)((67L*(c)[RED]+168L*(c)[GRN]+21L*(c)[BLU])/256)
49 #endif
50
51 #define intens(col) ( (col)[0] > (col)[1] \
52 ? (col)[0] > (col)[2] ? (col)[0] : (col)[2] \
53 : (col)[1] > (col)[2] ? (col)[1] : (col)[2] )
54
55 #define colrval(c,p) ( (c)[EXP] ? \
56 ldexp((c)[p]+.5,(int)(c)[EXP]-(COLXS+8)) : \
57 0. )
58
59 #define WHTCOLOR {1.0,1.0,1.0}
60 #define BLKCOLOR {0.0,0.0,0.0}
61 #define WHTCOLR {128,128,128,COLXS+1}
62 #define BLKCOLR {0,0,0,0}
63
64 /* definitions for resolution header */
65 #define XDECR 1
66 #define YDECR 2
67 #define YMAJOR 4
68
69 /* macros for exposures */
70 #define EXPOSSTR "EXPOSURE="
71 #define EXPOSSTRL 9
72 #define isexpos(hl) (!strncmp(hl,EXPOSSTR,EXPOSSTRL))
73 #define exposval(hl) atof((hl)+EXPOSSTRL)
74 #define fputexpos(ex,fp) fprintf(fp,"%s%e\n",EXPOSSTR,ex)
75
76 /* macros for pixel aspect ratios */
77 #define ASPECTSTR "PIXASPECT="
78 #define ASPECTSTRL 10
79 #define isaspect(hl) (!strncmp(hl,ASPECTSTR,ASPECTSTRL))
80 #define aspectval(hl) atof((hl)+ASPECTSTRL)
81 #define fputaspect(pa,fp) fprintf(fp,"%s%f\n",ASPECTSTR,pa)
82
83 /* macros for color correction */
84 #define COLCORSTR "COLORCORR="
85 #define COLCORSTRL 10
86 #define iscolcor(hl) (!strncmp(hl,COLCORSTR,COLCORSTRL))
87 #define colcorval(cc,hl) sscanf(hl+COLCORSTRL,"%f %f %f", \
88 &(cc)[RED],&(cc)[GRN],&(cc)[BLU])
89 #define fputcolcor(cc,fp) fprintf(fp,"%s %f %f %f\n",COLCORSTR, \
90 (cc)[RED],(cc)[GRN],(cc)[BLU])
91
92 extern double ldexp(), atof();
