--- ray/src/common/color.h 1995/10/15 14:07:59 2.10
+++ ray/src/common/color.h 2003/02/22 02:07:22 2.18
@@ -1,11 +1,8 @@
-/* Copyright (c) 1991 Regents of the University of California */
-/* SCCSid "$SunId$ LBL" */
+/* RCSid: $Id: color.h,v 2.18 2003/02/22 02:07:22 greg Exp $ */
* color.h - header for routines using pixel color values.
- * 12/31/85
+ * Must be included after X11 headers, since they declare a BYTE type.
* Two color representations are used, one for calculation and
* another for storage. Calculation is done with three floats
@@ -13,6 +10,70 @@
* three single byte mantissas and a common exponent.
+ * The Radiance Software License, Version 1.0
+ * Copyright (c) 1990 - 2002 The Regents of the University of California,
+ * through Lawrence Berkeley National Laboratory. All rights reserved.
+ * Redistribution and use in source and binary forms, with or without
+ * modification, are permitted provided that the following conditions
+ * are met:
+ * 1. Redistributions of source code must retain the above copyright
+ * notice, this list of conditions and the following disclaimer.
+ * 2. Redistributions in binary form must reproduce the above copyright
+ * notice, this list of conditions and the following disclaimer in
+ * the documentation and/or other materials provided with the
+ * distribution.
+ * 3. The end-user documentation included with the redistribution,
+ * if any, must include the following acknowledgment:
+ * "This product includes Radiance software
+ * (http://radsite.lbl.gov/)
+ * developed by the Lawrence Berkeley National Laboratory
+ * (http://www.lbl.gov/)."
+ * Alternately, this acknowledgment may appear in the software itself,
+ * if and wherever such third-party acknowledgments normally appear.
+ * 4. The names "Radiance," "Lawrence Berkeley National Laboratory"
+ * and "The Regents of the University of California" must
+ * not be used to endorse or promote products derived from this
+ * software without prior written permission. For written
+ * permission, please contact radiance@radsite.lbl.gov.
+ * 5. Products derived from this software may not be called "Radiance",
+ * nor may "Radiance" appear in their name, without prior written
+ * permission of Lawrence Berkeley National Laboratory.
+ * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED
+ * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
+ * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
+ * DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR
+ * ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
+ * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
+ * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
+ * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
+ * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
+ * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
+ * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ * This software consists of voluntary contributions made by many
+ * individuals on behalf of Lawrence Berkeley National Laboratory. For more
+ * information on Lawrence Berkeley National Laboratory, please see
+#include
+#include
+#ifdef __cplusplus
+extern "C" {
+#endif
#define RED 0
#define GRN 1
#define BLU 2
@@ -23,7 +84,8 @@
#define COLXS 128 /* excess used for exponent */
#define WHT 3 /* used for RGBPRIMS type */
-typedef unsigned char BYTE; /* 8-bit unsigned integer */
+#undef BYTE
+#define BYTE unsigned char /* 8-bit unsigned integer */
typedef BYTE COLR[4]; /* red, green, blue (or X,Y,Z), exponent */
@@ -69,8 +131,8 @@ typedef float COLORMAT[3][3]; /* color coordinate con
#define CIE_y_w 0.3333
#endif
-#define STDPRIMS {CIE_x_r,CIE_y_r,CIE_x_g,CIE_y_g, \
- CIE_x_b,CIE_y_b,CIE_x_w,CIE_y_w}
+#define STDPRIMS {{CIE_x_r,CIE_y_r},{CIE_x_g,CIE_y_g}, \
+ {CIE_x_b,CIE_y_b},{CIE_x_w,CIE_y_w}}
#define CIE_D ( CIE_x_r*(CIE_y_g - CIE_y_b) + \
CIE_x_g*(CIE_y_b - CIE_y_r) + \
@@ -174,26 +236,100 @@ typedef float COLORMAT[3][3]; /* color coordinate con
#define fputcolcor(cc,fp) fprintf(fp,"%s %f %f %f\n",COLCORSTR, \
(cc)[RED],(cc)[GRN],(cc)[BLU])
-#ifdef DCL_ATOF
-extern double atof(), ldexp(), frexp();
-#endif
* Conversions to and from XYZ space generally don't apply WHTEFFICACY.
* If you need Y to be luminance (cd/m^2), this must be applied when
* converting from radiance (watts/sr/m^2).
-extern RGBPRIMS stdprims; /* standard primary chromaticities */
-extern COLORMAT rgb2xyzmat; /* RGB to XYZ conversion matrix */
-extern COLORMAT xyz2rgbmat; /* XYZ to RGB conversion matrix */
+extern RGBPRIMS stdprims; /* standard primary chromaticities */
+extern COLORMAT rgb2xyzmat; /* RGB to XYZ conversion matrix */
+extern COLORMAT xyz2rgbmat; /* XYZ to RGB conversion matrix */
+extern COLOR cblack, cwhite; /* black (0,0,0) and white (1,1,1) */
-#define cie_rgb(rgb,xyz) colortrans(rgb,xyz2rgbmat,xyz)
+#define CGAMUT_LOWER 01
+#define CGAMUT_UPPER 02
+#define CGAMUT (CGAMUT_LOWER|CGAMUT_UPPER)
#define rgb_cie(xyz,rgb) colortrans(xyz,rgb2xyzmat,rgb)
#ifdef BSD
#define cpcolormat(md,ms) bcopy((char *)ms,(char *)md,sizeof(COLORMAT))
#else
-extern char *memcpy();
-#define cpcolormat(md,ms) (void)memcpy((char *)md,(char *)ms,sizeof(COLORMAT))
+#define cpcolormat(md,ms) memcpy((char *)md,(char *)ms,sizeof(COLORMAT))
+#endif
+#ifdef NOPROTO
+ /* defined in color.c */
+extern char *tempbuffer();
+extern int fwritecolrs();
+extern int freadcolrs();
+extern int fwritescan();
+extern int freadscan();
+extern void setcolr();
+extern void colr_color();
+extern int bigdiff();
+ /* defined in spec_rgb.c */
+extern void spec_rgb();
+extern void spec_cie();
+extern void cie_rgb();
+extern int clipgamut();
+extern void colortrans();
+extern void multcolormat();
+extern void compxyz2rgbmat();
+extern void comprgb2xyzmat();
+extern void comprgb2rgbmat();
+extern void compxyzWBmat();
+extern void compxyz2rgbWBmat();
+extern void comprgb2xyzWBmat();
+extern void comprgb2rgbWBmat();
+ /* defined in colrops.c */
+extern int setcolrcor();
+extern int setcolrinv();
+extern int setcolrgam();
+extern int colrs_gambs();
+extern int gambs_colrs();
+extern void shiftcolrs();
+extern void normcolrs();
+#else
+extern char *tempbuffer(unsigned int len);
+extern int fwritecolrs(COLR *scanline, int len, FILE *fp);
+extern int freadcolrs(COLR *scanline, int len, FILE *fp);
+extern int fwritescan(COLOR *scanline, int len, FILE *fp);
+extern int freadscan(COLOR *scanline, int len, FILE *fp);
+extern void setcolr(COLR clr, double r, double g, double b);
+extern void colr_color(COLOR col, COLR clr);
+extern int bigdiff(COLOR c1, COLOR c2, double md);
+extern void spec_rgb(COLOR col, int s, int e);
+extern void spec_cie(COLOR col, int s, int e);
+extern void cie_rgb(COLOR rgb, COLOR xyz);
+extern int clipgamut(COLOR col, double brt, int gamut,
+ COLOR lower, COLOR upper);
+extern void colortrans(COLOR c2, COLORMAT mat, COLOR c1);
+extern void multcolormat(COLORMAT m3, COLORMAT m2,
+ COLORMAT m1);
+extern void compxyz2rgbmat(COLORMAT mat, RGBPRIMS pr);
+extern void comprgb2xyzmat(COLORMAT mat, RGBPRIMS pr);
+extern void comprgb2rgbmat(COLORMAT mat, RGBPRIMS pr1, RGBPRIMS pr2);
+extern void compxyzWBmat(COLORMAT mat, float wht1[2],
+ float wht2[2]);
+extern void compxyz2rgbWBmat(COLORMAT mat, RGBPRIMS pr);
+extern void comprgb2xyzWBmat(COLORMAT mat, RGBPRIMS pr);
+extern void comprgb2rgbWBmat(COLORMAT mat, RGBPRIMS pr1, RGBPRIMS pr2);
+extern int setcolrcor(double (*f)(), double a2);
+extern int setcolrinv(double (*f)(), double a2);
+extern int setcolrgam(double g);
+extern int colrs_gambs(COLR *scan, int len);
+extern int gambs_colrs(COLR *scan, int len);
+extern void shiftcolrs(COLR *scan, int len, int adjust);
+extern void normcolrs(COLR *scan, int len, int adjust);
+#endif
+#ifdef __cplusplus
#endif
