root/radiance/ray/src/common/color.h
Revision: 2.11
Committed: Fri Nov 10 17:04:19 1995 UTC (28 years, 7 months ago) by greg
Changes since 2.10: +0 -1 lines
removed memcpy() declaration
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 /* SCCSid "$SunId$ LBL" */
4
5 /*
6 * color.h - header for routines using pixel color values.
7 *
8 * 12/31/85
9 *
10 * Two color representations are used, one for calculation and
11 * another for storage. Calculation is done with three floats
12 * for speed. Stored color values use 4 bytes which contain
13 * three single byte mantissas and a common exponent.
14 */
15
16 #define RED 0
17 #define GRN 1
18 #define BLU 2
19 #define CIEX 0 /* or, if input is XYZ... */
20 #define CIEY 1
21 #define CIEZ 2
22 #define EXP 3 /* exponent same for either format */
23 #define COLXS 128 /* excess used for exponent */
24 #define WHT 3 /* used for RGBPRIMS type */
25
26 typedef unsigned char BYTE; /* 8-bit unsigned integer */
27
28 typedef BYTE COLR[4]; /* red, green, blue (or X,Y,Z), exponent */
29
30 typedef float COLOR[3]; /* red, green, blue (or X,Y,Z) */
31
32 typedef float RGBPRIMS[4][2]; /* (x,y) chromaticities for RGBW */
33 typedef float (*RGBPRIMP)[2]; /* pointer to RGBPRIMS array */
34
35 typedef float COLORMAT[3][3]; /* color coordinate conversion matrix */
36
37 #define copycolr(c1,c2) (c1[0]=c2[0],c1[1]=c2[1], \
38 c1[2]=c2[2],c1[3]=c2[3])
39
40 #define colval(col,pri) ((col)[pri])
41
42 #define setcolor(col,r,g,b) ((col)[RED]=(r),(col)[GRN]=(g),(col)[BLU]=(b))
43
44 #define copycolor(c1,c2) ((c1)[0]=(c2)[0],(c1)[1]=(c2)[1],(c1)[2]=(c2)[2])
45
46 #define scalecolor(col,sf) ((col)[0]*=(sf),(col)[1]*=(sf),(col)[2]*=(sf))
47
48 #define addcolor(c1,c2) ((c1)[0]+=(c2)[0],(c1)[1]+=(c2)[1],(c1)[2]+=(c2)[2])
49
50 #define multcolor(c1,c2) ((c1)[0]*=(c2)[0],(c1)[1]*=(c2)[1],(c1)[2]*=(c2)[2])
51
52 #ifdef NTSC
53 #define CIE_x_r 0.670 /* standard NTSC primaries */
54 #define CIE_y_r 0.330
55 #define CIE_x_g 0.210
56 #define CIE_y_g 0.710
57 #define CIE_x_b 0.140
58 #define CIE_y_b 0.080
59 #define CIE_x_w 0.3333 /* use true white */
60 #define CIE_y_w 0.3333
61 #else
62 #define CIE_x_r 0.640 /* nominal CRT primaries */
63 #define CIE_y_r 0.330
64 #define CIE_x_g 0.290
65 #define CIE_y_g 0.600
66 #define CIE_x_b 0.150
67 #define CIE_y_b 0.060
68 #define CIE_x_w 0.3333 /* use true white */
69 #define CIE_y_w 0.3333
70 #endif
71
72 #define STDPRIMS {CIE_x_r,CIE_y_r,CIE_x_g,CIE_y_g, \
73 CIE_x_b,CIE_y_b,CIE_x_w,CIE_y_w}
74
75 #define CIE_D ( CIE_x_r*(CIE_y_g - CIE_y_b) + \
76 CIE_x_g*(CIE_y_b - CIE_y_r) + \
77 CIE_x_b*(CIE_y_r - CIE_y_g) )
78 #define CIE_C_rD ( (1./CIE_y_w) * \
79 ( CIE_x_w*(CIE_y_g - CIE_y_b) - \
80 CIE_y_w*(CIE_x_g - CIE_x_b) + \
81 CIE_x_g*CIE_y_b - CIE_x_b*CIE_y_g ) )
82 #define CIE_C_gD ( (1./CIE_y_w) * \
83 ( CIE_x_w*(CIE_y_b - CIE_y_r) - \
84 CIE_y_w*(CIE_x_b - CIE_x_r) - \
85 CIE_x_r*CIE_y_b + CIE_x_b*CIE_y_r ) )
86 #define CIE_C_bD ( (1./CIE_y_w) * \
87 ( CIE_x_w*(CIE_y_r - CIE_y_g) - \
88 CIE_y_w*(CIE_x_r - CIE_x_g) + \
89 CIE_x_r*CIE_y_g - CIE_x_g*CIE_y_r ) )
90
91 #define CIE_rf (CIE_y_r*CIE_C_rD/CIE_D)
92 #define CIE_gf (CIE_y_g*CIE_C_gD/CIE_D)
93 #define CIE_bf (CIE_y_b*CIE_C_bD/CIE_D)
94
95 /* As of 9-94, CIE_rf=.265074126, CIE_gf=.670114631 and CIE_bf=.064811243 */
96
97 /***** The following definitions are valid for RGB colors only... *****/
98
99 #define bright(col) (CIE_rf*(col)[RED]+CIE_gf*(col)[GRN]+CIE_bf*(col)[BLU])
100 #define normbright(c) ( ( (long)(CIE_rf*256.+.5)*(c)[RED] + \
101 (long)(CIE_gf*256.+.5)*(c)[GRN] + \
102 (long)(CIE_bf*256.+.5)*(c)[BLU] ) >> 8 )
103
104 /* luminous efficacies over visible spectrum */
105 #define MAXEFFICACY 683. /* defined maximum at 550 nm */
106 #define WHTEFFICACY 179. /* uniform white light */
107 #define D65EFFICACY 203. /* standard illuminant D65 */
108 #define INCEFFICACY 160. /* illuminant A (incand.) */
109 #define SUNEFFICACY 208. /* illuminant B (solar dir.) */
110 #define SKYEFFICACY D65EFFICACY /* skylight */
111 #define DAYEFFICACY D65EFFICACY /* combined sky and solar */
112
113 #define luminance(col) (WHTEFFICACY * bright(col))
114
115 /***** ...end of stuff specific to RGB colors *****/
116
117 #define intens(col) ( (col)[0] > (col)[1] \
118 ? (col)[0] > (col)[2] ? (col)[0] : (col)[2] \
119 : (col)[1] > (col)[2] ? (col)[1] : (col)[2] )
120
121 #define colrval(c,p) ( (c)[EXP] ? \
122 ldexp((c)[p]+.5,(int)(c)[EXP]-(COLXS+8)) : \
123 0. )
124
125 #define WHTCOLOR {1.0,1.0,1.0}
126 #define BLKCOLOR {0.0,0.0,0.0}
127 #define WHTCOLR {128,128,128,COLXS+1}
128 #define BLKCOLR {0,0,0,0}
129
130 /* picture format identifier */
131 #define COLRFMT "32-bit_rle_rgbe"
132 #define CIEFMT "32-bit_rle_xyze"
133 #define PICFMT "32-bit_rle_???e" /* matches either */
134 #define LPICFMT 15 /* max format id len */
135
136 /* macros for exposures */
137 #define EXPOSSTR "EXPOSURE="
138 #define LEXPOSSTR 9
139 #define isexpos(hl) (!strncmp(hl,EXPOSSTR,LEXPOSSTR))
140 #define exposval(hl) atof((hl)+LEXPOSSTR)
141 #define fputexpos(ex,fp) fprintf(fp,"%s%e\n",EXPOSSTR,ex)
142
143 /* macros for pixel aspect ratios */
144 #define ASPECTSTR "PIXASPECT="
145 #define LASPECTSTR 10
146 #define isaspect(hl) (!strncmp(hl,ASPECTSTR,LASPECTSTR))
147 #define aspectval(hl) atof((hl)+LASPECTSTR)
148 #define fputaspect(pa,fp) fprintf(fp,"%s%f\n",ASPECTSTR,pa)
149
150 /* macros for primary specifications */
151 #define PRIMARYSTR "PRIMARIES="
152 #define LPRIMARYSTR 10
153 #define isprims(hl) (!strncmp(hl,PRIMARYSTR,LPRIMARYSTR))
154 #define primsval(p,hl) sscanf(hl+LPRIMARYSTR, \
155 "%f %f %f %f %f %f %f %f", \
156 &(p)[RED][CIEX],&(p)[RED][CIEY], \
157 &(p)[GRN][CIEX],&(p)[GRN][CIEY], \
158 &(p)[BLU][CIEX],&(p)[BLU][CIEY], \
159 &(p)[WHT][CIEX],&(p)[WHT][CIEY])
160 #define fputprims(p,fp) fprintf(fp, \
161 "%s %.4f %.4f %.4f %.4f %.4f %.4f %.4f %.4f\n",\
162 PRIMARYSTR, \
163 (p)[RED][CIEX],(p)[RED][CIEY], \
164 (p)[GRN][CIEX],(p)[GRN][CIEY], \
165 (p)[BLU][CIEX],(p)[BLU][CIEY], \
166 (p)[WHT][CIEX],(p)[WHT][CIEY])
167
168 /* macros for color correction */
169 #define COLCORSTR "COLORCORR="
170 #define LCOLCORSTR 10
171 #define iscolcor(hl) (!strncmp(hl,COLCORSTR,LCOLCORSTR))
172 #define colcorval(cc,hl) sscanf(hl+LCOLCORSTR,"%f %f %f", \
173 &(cc)[RED],&(cc)[GRN],&(cc)[BLU])
174 #define fputcolcor(cc,fp) fprintf(fp,"%s %f %f %f\n",COLCORSTR, \
175 (cc)[RED],(cc)[GRN],(cc)[BLU])
176
177 #ifdef DCL_ATOF
178 extern double atof(), ldexp(), frexp();
179 #endif
180
181 /*
182 * Conversions to and from XYZ space generally don't apply WHTEFFICACY.
183 * If you need Y to be luminance (cd/m^2), this must be applied when
184 * converting from radiance (watts/sr/m^2).
185 */
186
187 extern RGBPRIMS stdprims; /* standard primary chromaticities */
188 extern COLORMAT rgb2xyzmat; /* RGB to XYZ conversion matrix */
189 extern COLORMAT xyz2rgbmat; /* XYZ to RGB conversion matrix */
190
191 #define cie_rgb(rgb,xyz) colortrans(rgb,xyz2rgbmat,xyz)
192 #define rgb_cie(xyz,rgb) colortrans(xyz,rgb2xyzmat,rgb)
193
194 #ifdef BSD
195 #define cpcolormat(md,ms) bcopy((char *)ms,(char *)md,sizeof(COLORMAT))
196 #else
197 #define cpcolormat(md,ms) (void)memcpy((char *)md,(char *)ms,sizeof(COLORMAT))
198 #endif
