--- ray/src/common/color.h 2003/07/14 22:23:59 2.25 +++ ray/src/common/color.h 2003/10/18 04:46:24 2.27 @@ -1,4 +1,4 @@ -/* RCSid $Id: color.h,v 2.25 2003/07/14 22:23:59 schorsch Exp $ */ +/* RCSid $Id: color.h,v 2.27 2003/10/18 04:46:24 greg Exp $ */ /* * color.h - header for routines using pixel color values. * @@ -113,7 +113,7 @@ typedef float COLORMAT[3][3]; /* color coordinate con #define D65EFFICACY 203. /* standard illuminant D65 */ #define INCEFFICACY 160. /* illuminant A (incand.) */ #define SUNEFFICACY 208. /* illuminant B (solar dir.) */ -#define SKYEFFICACY D65EFFICACY /* skylight */ +#define SKYEFFICACY D65EFFICACY /* skylight (should be 110) */ #define DAYEFFICACY D65EFFICACY /* combined sky and solar */ #define luminance(col) (WHTEFFICACY * bright(col)) @@ -226,8 +226,8 @@ extern void compxyz2rgbWBmat(COLORMAT mat, RGBPRIMS pr extern void comprgb2xyzWBmat(COLORMAT mat, RGBPRIMS pr); extern void comprgb2rgbWBmat(COLORMAT mat, RGBPRIMS pr1, RGBPRIMS pr2); /* defined in colrops.c */ -extern int setcolrcor(double (*f)(), double a2); -extern int setcolrinv(double (*f)(), double a2); +extern int setcolrcor(double (*f)(double, double), double a2); +extern int setcolrinv(double (*f)(double, double), double a2); extern int setcolrgam(double g); extern int colrs_gambs(COLR *scan, int len); extern int gambs_colrs(COLR *scan, int len);
