--- ray/src/common/color.h 1997/01/30 19:14:37 2.12 +++ ray/src/common/color.h 1997/10/28 11:13:51 2.16 @@ -69,8 +69,8 @@ typedef float COLORMAT[3][3]; /* color coordinate con #define CIE_y_w 0.3333 #endif -#define STDPRIMS {CIE_x_r,CIE_y_r,CIE_x_g,CIE_y_g, \ - CIE_x_b,CIE_y_b,CIE_x_w,CIE_y_w} +#define STDPRIMS {{CIE_x_r,CIE_y_r},{CIE_x_g,CIE_y_g}, \ + {CIE_x_b,CIE_y_b},{CIE_x_w,CIE_y_w}} #define CIE_D ( CIE_x_r*(CIE_y_g - CIE_y_b) + \ CIE_x_g*(CIE_y_b - CIE_y_r) + \ @@ -187,13 +187,16 @@ extern double atof(), ldexp(), frexp(); extern RGBPRIMS stdprims; /* standard primary chromaticities */ extern COLORMAT rgb2xyzmat; /* RGB to XYZ conversion matrix */ extern COLORMAT xyz2rgbmat; /* XYZ to RGB conversion matrix */ +extern COLOR cblack, cwhite; /* black (0,0,0) and white (1,1,1) */ -#define cie_rgb(rgb,xyz) colortrans(rgb,xyz2rgbmat,xyz,1) -#define rgb_cie(xyz,rgb) colortrans(xyz,rgb2xyzmat,rgb,1) +#define CGAMUT_LOWER 01 +#define CGAMUT_UPPER 02 +#define CGAMUT (CGAMUT_LOWER|CGAMUT_UPPER) +#define rgb_cie(xyz,rgb) colortrans(xyz,rgb2xyzmat,rgb) + #ifdef BSD #define cpcolormat(md,ms) bcopy((char *)ms,(char *)md,sizeof(COLORMAT)) #else -extern char *memcpy(); -#define cpcolormat(md,ms) (void)memcpy((char *)md,(char *)ms,sizeof(COLORMAT)) +#define cpcolormat(md,ms) memcpy((char *)md,(char *)ms,sizeof(COLORMAT)) #endif
