root/radiance/ray/src/common/color.c
Revision: 2.8
Committed: Sat Mar 26 13:44:38 1994 UTC (30 years, 2 months ago) by greg
bug avoidance in setcolr()
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * color.c - routines for color calculations.
9 *
10 * 10/10/85
11 */
12
13 #include <stdio.h>
14
15 #include <math.h>
16
17 #include "color.h"
18
19 #define MINELEN 8 /* minimum scanline length for encoding */
20 #define MAXELEN 0x7fff /* maximum scanline length for encoding */
21 #define MINRUN 4 /* minimum run length */
22
23
24 char *
25 tempbuffer(len) /* get a temporary buffer */
26 unsigned len;
27 {
28 extern char *malloc(), *realloc();
29 static char *tempbuf = NULL;
30 static unsigned tempbuflen = 0;
31
32 if (len > tempbuflen) {
33 if (tempbuflen > 0)
34 tempbuf = realloc(tempbuf, len);
35 else
36 tempbuf = malloc(len);
37 tempbuflen = tempbuf==NULL ? 0 : len;
38 }
39 return(tempbuf);
40 }
41
42
43 fwritecolrs(scanline, len, fp) /* write out a colr scanline */
44 register COLR *scanline;
45 unsigned len;
46 register FILE *fp;
47 {
48 register int i, j, beg, cnt;
49 int c2;
50
51 if (len < MINELEN | len > MAXELEN) /* OOBs, write out flat */
52 return(fwrite((char *)scanline,sizeof(COLR),len,fp) - len);
53 /* put magic header */
54 putc(2, fp);
55 putc(2, fp);
56 putc(len>>8, fp);
57 putc(len&255, fp);
58 /* put components seperately */
59 for (i = 0; i < 4; i++) {
60 for (j = 0; j < len; j += cnt) { /* find next run */
61 for (beg = j; beg < len; beg += cnt) {
62 for (cnt = 1; cnt < 127 && beg+cnt < len &&
63 scanline[beg+cnt][i] == scanline[beg][i]; cnt++)
64 ;
65 if (cnt >= MINRUN)
66 break; /* long enough */
67 }
68 if (beg-j > 1 && beg-j < MINRUN) {
69 c2 = j+1;
70 while (scanline[c2++][i] == scanline[j][i])
71 if (c2 == beg) { /* short run */
72 putc(128+beg-j, fp);
73 putc(scanline[j][i], fp);
74 j = beg;
75 break;
76 }
77 }
78 while (j < beg) { /* write out non-run */
79 if ((c2 = beg-j) > 128) c2 = 128;
80 putc(c2, fp);
81 while (c2--)
82 putc(scanline[j++][i], fp);
83 }
84 if (cnt >= MINRUN) { /* write out run */
85 putc(128+cnt, fp);
86 putc(scanline[beg][i], fp);
87 } else
88 cnt = 0;
89 }
90 }
91 return(ferror(fp) ? -1 : 0);
92 }
93
94
95 freadcolrs(scanline, len, fp) /* read in an encoded colr scanline */
96 register COLR *scanline;
97 int len;
98 register FILE *fp;
99 {
100 register int i, j;
101 int code, val;
102 /* determine scanline type */
103 if (len < MINELEN | len > MAXELEN)
104 return(oldreadcolrs(scanline, len, fp));
105 if ((i = getc(fp)) == EOF)
106 return(-1);
107 if (i != 2) {
108 ungetc(i, fp);
109 return(oldreadcolrs(scanline, len, fp));
110 }
111 scanline[0][GRN] = getc(fp);
112 scanline[0][BLU] = getc(fp);
113 if ((i = getc(fp)) == EOF)
114 return(-1);
115 if (scanline[0][GRN] != 2 || scanline[0][BLU] & 128) {
116 scanline[0][RED] = 2;
117 scanline[0][EXP] = i;
118 return(oldreadcolrs(scanline+1, len-1, fp));
119 }
120 if ((scanline[0][BLU]<<8 | i) != len)
121 return(-1); /* length mismatch! */
122 /* read each component */
123 for (i = 0; i < 4; i++)
124 for (j = 0; j < len; ) {
125 if ((code = getc(fp)) == EOF)
126 return(-1);
127 if (code > 128) { /* run */
128 code &= 127;
129 val = getc(fp);
130 while (code--)
131 scanline[j++][i] = val;
132 } else /* non-run */
133 while (code--)
134 scanline[j++][i] = getc(fp);
135 }
136 return(feof(fp) ? -1 : 0);
137 }
138
139
140 oldreadcolrs(scanline, len, fp) /* read in an old colr scanline */
141 register COLR *scanline;
142 int len;
143 register FILE *fp;
144 {
145 int rshift;
146 register int i;
147
148 rshift = 0;
149
150 while (len > 0) {
151 scanline[0][RED] = getc(fp);
152 scanline[0][GRN] = getc(fp);
153 scanline[0][BLU] = getc(fp);
154 scanline[0][EXP] = getc(fp);
155 if (feof(fp) || ferror(fp))
156 return(-1);
157 if (scanline[0][RED] == 1 &&
158 scanline[0][GRN] == 1 &&
159 scanline[0][BLU] == 1) {
160 for (i = scanline[0][EXP] << rshift; i > 0; i--) {
161 copycolr(scanline[0], scanline[-1]);
162 scanline++;
163 len--;
164 }
165 rshift += 8;
166 } else {
167 scanline++;
168 len--;
169 rshift = 0;
170 }
171 }
172 return(0);
173 }
174
175
176 fwritescan(scanline, len, fp) /* write out a scanline */
177 register COLOR *scanline;
178 int len;
179 FILE *fp;
180 {
181 COLR *clrscan;
182 int n;
183 register COLR *sp;
184 /* get scanline buffer */
185 if ((sp = (COLR *)tempbuffer(len*sizeof(COLR))) == NULL)
186 return(-1);
187 clrscan = sp;
188 /* convert scanline */
189 n = len;
190 while (n-- > 0) {
191 setcolr(sp[0], scanline[0][RED],
192 scanline[0][GRN],
193 scanline[0][BLU]);
194 scanline++;
195 sp++;
196 }
197 return(fwritecolrs(clrscan, len, fp));
198 }
199
200
201 freadscan(scanline, len, fp) /* read in a scanline */
202 register COLOR *scanline;
203 int len;
204 FILE *fp;
205 {
206 register COLR *clrscan;
207
208 if ((clrscan = (COLR *)tempbuffer(len*sizeof(COLR))) == NULL)
209 return(-1);
210 if (freadcolrs(clrscan, len, fp) < 0)
211 return(-1);
212 /* convert scanline */
213 colr_color(scanline[0], clrscan[0]);
214 while (--len > 0) {
215 scanline++; clrscan++;
216 if (clrscan[0][RED] == clrscan[-1][RED] &&
217 clrscan[0][GRN] == clrscan[-1][GRN] &&
218 clrscan[0][BLU] == clrscan[-1][BLU] &&
219 clrscan[0][EXP] == clrscan[-1][EXP])
220 copycolor(scanline[0], scanline[-1]);
221 else
222 colr_color(scanline[0], clrscan[0]);
223 }
224 return(0);
225 }
226
227
228 setcolr(clr, r, g, b) /* assign a short color value */
229 register COLR clr;
230 double r, g, b;
231 {
232 double d;
233 int e;
234
235 d = r > g ? r : g;
236 if (b > d) d = b;
237
238 if (d <= 1e-32) {
239 clr[RED] = clr[GRN] = clr[BLU] = 0;
240 clr[EXP] = 0;
241 return;
242 }
243
244 d = frexp(d, &e) * 255.9999 / d;
245
246 clr[RED] = r * d;
247 clr[GRN] = g * d;
248 clr[BLU] = b * d;
249 clr[EXP] = e + COLXS;
250 }
251
252
253 colr_color(col, clr) /* convert short to float color */
254 register COLOR col;
255 register COLR clr;
256 {
257 double f;
258
259 if (clr[EXP] == 0)
260 col[RED] = col[GRN] = col[BLU] = 0.0;
261 else {
262 f = ldexp(1.0, (int)clr[EXP]-(COLXS+8));
263 col[RED] = (clr[RED] + 0.5)*f;
264 col[GRN] = (clr[GRN] + 0.5)*f;
265 col[BLU] = (clr[BLU] + 0.5)*f;
266 }
267 }
268
269
270 bigdiff(c1, c2, md) /* c1 delta c2 > md? */
271 register COLOR c1, c2;
272 double md;
273 {
274 register int i;
275
276 for (i = 0; i < 3; i++)
277 if (colval(c1,i)-colval(c2,i) > md*colval(c2,i) ||
278 colval(c2,i)-colval(c1,i) > md*colval(c1,i))
279 return(1);
280 return(0);
281 }
