root/radiance/ray/src/common/color.c
Revision: 2.3
Committed: Mon Jun 29 22:40:28 1992 UTC (31 years, 10 months ago) by greg
additional check in freadcolrs() for long scanline
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * color.c - routines for color calculations.
9 *
10 * 10/10/85
11 */
12
13 #include <stdio.h>
14
15 #include "color.h"
16
17 #define MINELEN 8 /* minimum scanline length for encoding */
18 #define MINRUN 4 /* minimum run length */
19
20
21 char *
22 tempbuffer(len) /* get a temporary buffer */
23 unsigned len;
24 {
25 extern char *malloc(), *realloc();
26 static char *tempbuf = NULL;
27 static int tempbuflen = 0;
28
29 if (len > tempbuflen) {
30 if (tempbuflen > 0)
31 tempbuf = realloc(tempbuf, len);
32 else
33 tempbuf = malloc(len);
34 tempbuflen = tempbuf==NULL ? 0 : len;
35 }
36 return(tempbuf);
37 }
38
39
40 fwritecolrs(scanline, len, fp) /* write out a colr scanline */
41 register COLR *scanline;
42 unsigned len;
43 register FILE *fp;
44 {
45 register int i, j, beg, cnt;
46 int c2;
47
48 if (len < MINELEN | len > 0x7fff) /* OOBs, write out flat */
49 return(fwrite((char *)scanline,sizeof(COLR),len,fp) - len);
50 /* put magic header */
51 putc(2, fp);
52 putc(2, fp);
53 putc(len>>8, fp);
54 putc(len&255, fp);
55 /* put components seperately */
56 for (i = 0; i < 4; i++) {
57 for (j = 0; j < len; j += cnt) { /* find next run */
58 for (beg = j; beg < len; beg += cnt) {
59 for (cnt = 1; cnt < 127 && beg+cnt < len &&
60 scanline[beg+cnt][i] == scanline[beg][i]; cnt++)
61 ;
62 if (cnt >= MINRUN)
63 break; /* long enough */
64 }
65 if (beg-j > 1 && beg-j < MINRUN) {
66 c2 = j+1;
67 while (scanline[c2++][i] == scanline[j][i])
68 if (c2 == beg) { /* short run */
69 putc(128+beg-j, fp);
70 putc(scanline[j][i], fp);
71 j = beg;
72 break;
73 }
74 }
75 while (j < beg) { /* write out non-run */
76 if ((c2 = beg-j) > 128) c2 = 128;
77 putc(c2, fp);
78 while (c2--)
79 putc(scanline[j++][i], fp);
80 }
81 if (cnt >= MINRUN) { /* write out run */
82 putc(128+cnt, fp);
83 putc(scanline[beg][i], fp);
84 } else
85 cnt = 0;
86 }
87 }
88 return(ferror(fp) ? -1 : 0);
89 }
90
91
92 freadcolrs(scanline, len, fp) /* read in an encoded colr scanline */
93 register COLR *scanline;
94 int len;
95 register FILE *fp;
96 {
97 register int i, j;
98 int code;
99 /* determine scanline type */
100 if (len < MINELEN | len > 0x7fff)
101 return(oldreadcolrs(scanline, len, fp));
102 if ((i = getc(fp)) == EOF)
103 return(-1);
104 if (i != 2) {
105 ungetc(i, fp);
106 return(oldreadcolrs(scanline, len, fp));
107 }
108 scanline[0][GRN] = getc(fp);
109 scanline[0][BLU] = getc(fp);
110 if ((i = getc(fp)) == EOF)
111 return(-1);
112 if (scanline[0][GRN] != 2 || scanline[0][BLU] & 128) {
113 scanline[0][RED] = 2;
114 scanline[0][EXP] = i;
115 return(oldreadcolrs(scanline+1, len-1, fp));
116 }
117 if ((scanline[0][BLU]<<8 | i) != len)
118 return(-1); /* length mismatch! */
119 /* read each component */
120 for (i = 0; i < 4; i++)
121 for (j = 0; j < len; ) {
122 if ((code = getc(fp)) == EOF)
123 return(-1);
124 if (code > 128) { /* run */
125 scanline[j++][i] = getc(fp);
126 for (code &= 127; --code; j++)
127 scanline[j][i] = scanline[j-1][i];
128 } else /* non-run */
129 while (code--)
130 scanline[j++][i] = getc(fp);
131 }
132 return(feof(fp) ? -1 : 0);
133 }
134
135
136 oldreadcolrs(scanline, len, fp) /* read in an old colr scanline */
137 register COLR *scanline;
138 int len;
139 register FILE *fp;
140 {
141 int rshift;
142 register int i;
143
144 rshift = 0;
145
146 while (len > 0) {
147 scanline[0][RED] = getc(fp);
148 scanline[0][GRN] = getc(fp);
149 scanline[0][BLU] = getc(fp);
150 scanline[0][EXP] = getc(fp);
151 if (feof(fp) || ferror(fp))
152 return(-1);
153 if (scanline[0][RED] == 1 &&
154 scanline[0][GRN] == 1 &&
155 scanline[0][BLU] == 1) {
156 for (i = scanline[0][EXP] << rshift; i > 0; i--) {
157 copycolr(scanline[0], scanline[-1]);
158 scanline++;
159 len--;
160 }
161 rshift += 8;
162 } else {
163 scanline++;
164 len--;
165 rshift = 0;
166 }
167 }
168 return(0);
169 }
170
171
172 fwritescan(scanline, len, fp) /* write out a scanline */
173 register COLOR *scanline;
174 int len;
175 FILE *fp;
176 {
177 COLR *clrscan;
178 int n;
179 register COLR *sp;
180 /* get scanline buffer */
181 if ((sp = (COLR *)tempbuffer(len*sizeof(COLR))) == NULL)
182 return(-1);
183 clrscan = sp;
184 /* convert scanline */
185 n = len;
186 while (n-- > 0) {
187 setcolr(sp[0], scanline[0][RED],
188 scanline[0][GRN],
189 scanline[0][BLU]);
190 scanline++;
191 sp++;
192 }
193 return(fwritecolrs(clrscan, len, fp));
194 }
195
196
197 freadscan(scanline, len, fp) /* read in a scanline */
198 register COLOR *scanline;
199 int len;
200 FILE *fp;
201 {
202 register COLR *clrscan;
203
204 if ((clrscan = (COLR *)tempbuffer(len*sizeof(COLR))) == NULL)
205 return(-1);
206 if (freadcolrs(clrscan, len, fp) < 0)
207 return(-1);
208 /* convert scanline */
209 colr_color(scanline[0], clrscan[0]);
210 while (--len > 0) {
211 scanline++; clrscan++;
212 if (clrscan[0][RED] == clrscan[-1][RED] &&
213 clrscan[0][GRN] == clrscan[-1][GRN] &&
214 clrscan[0][BLU] == clrscan[-1][BLU] &&
215 clrscan[0][EXP] == clrscan[-1][EXP])
216 copycolor(scanline[0], scanline[-1]);
217 else
218 colr_color(scanline[0], clrscan[0]);
219 }
220 return(0);
221 }
222
223
224 setcolr(clr, r, g, b) /* assign a short color value */
225 register COLR clr;
226 double r, g, b;
227 {
228 double frexp();
229 double d;
230 int e;
231
232 d = r > g ? r : g;
233 if (b > d) d = b;
234
235 if (d <= 1e-32) {
236 clr[RED] = clr[GRN] = clr[BLU] = 0;
237 clr[EXP] = 0;
238 return;
239 }
240
241 d = frexp(d, &e) * 256.0 / d;
242
243 clr[RED] = r * d;
244 clr[GRN] = g * d;
245 clr[BLU] = b * d;
246 clr[EXP] = e + COLXS;
247 }
248
249
250 colr_color(col, clr) /* convert short to float color */
251 register COLOR col;
252 register COLR clr;
253 {
254 double f;
255
256 if (clr[EXP] == 0)
257 col[RED] = col[GRN] = col[BLU] = 0.0;
258 else {
259 f = ldexp(1.0, (int)clr[EXP]-(COLXS+8));
260 col[RED] = (clr[RED] + 0.5)*f;
261 col[GRN] = (clr[GRN] + 0.5)*f;
262 col[BLU] = (clr[BLU] + 0.5)*f;
263 }
264 }
265
266
267 bigdiff(c1, c2, md) /* c1 delta c2 > md? */
268 register COLOR c1, c2;
269 double md;
270 {
271 register int i;
272
273 for (i = 0; i < 3; i++)
274 if (colval(c1,i)-colval(c2,i) > md*colval(c2,i) ||
275 colval(c2,i)-colval(c1,i) > md*colval(c1,i))
276 return(1);
277 return(0);
278 }
