root/radiance/ray/src/common/color.c
Revision: 2.14
Committed: Tue Dec 9 15:51:42 2003 UTC (20 years, 4 months ago) by greg
Changes since 2.13: +6 -1 lines
Added redirection for getc() and putc() on threaded C library
2 static const char RCSid[] = "$Id: color.c,v 2.13 2003/07/27 22:12:01 schorsch Exp $";
5 * color.c - routines for color calculations.
6 *
7 * Externals declared in color.h
8 */
9
10 #include "copyright.h"
11
12 #include <stdio.h>
13
14 #include <stdlib.h>
15
16 #include <math.h>
17
18 #include "color.h"
19
20 #ifdef getc_unlocked /* avoid horrendous overhead of flockfile */
21 #define getc getc_unlocked
22 #define putc putc_unlocked
23 #endif
24
25 #define MINELEN 8 /* minimum scanline length for encoding */
26 #define MAXELEN 0x7fff /* maximum scanline length for encoding */
27 #define MINRUN 4 /* minimum run length */
28
29
30 char *
31 tempbuffer(len) /* get a temporary buffer */
32 unsigned int len;
33 {
34 static char *tempbuf = NULL;
35 static unsigned tempbuflen = 0;
36
37 if (len > tempbuflen) {
38 if (tempbuflen > 0)
39 tempbuf = (char *)realloc((void *)tempbuf, len);
40 else
41 tempbuf = (char *)malloc(len);
42 tempbuflen = tempbuf==NULL ? 0 : len;
43 }
44 return(tempbuf);
45 }
46
47
48 int
49 fwritecolrs(scanline, len, fp) /* write out a colr scanline */
50 register COLR *scanline;
51 int len;
52 register FILE *fp;
53 {
54 register int i, j, beg, cnt = 1;
55 int c2;
56
57 if ((len < MINELEN) | (len > MAXELEN)) /* OOBs, write out flat */
58 return(fwrite((char *)scanline,sizeof(COLR),len,fp) - len);
59 /* put magic header */
60 putc(2, fp);
61 putc(2, fp);
62 putc(len>>8, fp);
63 putc(len&255, fp);
64 /* put components seperately */
65 for (i = 0; i < 4; i++) {
66 for (j = 0; j < len; j += cnt) { /* find next run */
67 for (beg = j; beg < len; beg += cnt) {
68 for (cnt = 1; cnt < 127 && beg+cnt < len &&
69 scanline[beg+cnt][i] == scanline[beg][i]; cnt++)
70 ;
71 if (cnt >= MINRUN)
72 break; /* long enough */
73 }
74 if (beg-j > 1 && beg-j < MINRUN) {
75 c2 = j+1;
76 while (scanline[c2++][i] == scanline[j][i])
77 if (c2 == beg) { /* short run */
78 putc(128+beg-j, fp);
79 putc(scanline[j][i], fp);
80 j = beg;
81 break;
82 }
83 }
84 while (j < beg) { /* write out non-run */
85 if ((c2 = beg-j) > 128) c2 = 128;
86 putc(c2, fp);
87 while (c2--)
88 putc(scanline[j++][i], fp);
89 }
90 if (cnt >= MINRUN) { /* write out run */
91 putc(128+cnt, fp);
92 putc(scanline[beg][i], fp);
93 } else
94 cnt = 0;
95 }
96 }
97 return(ferror(fp) ? -1 : 0);
98 }
99
100
101 static int
102 oldreadcolrs(scanline, len, fp) /* read in an old colr scanline */
103 register COLR *scanline;
104 int len;
105 register FILE *fp;
106 {
107 int rshift;
108 register int i;
109
110 rshift = 0;
111
112 while (len > 0) {
113 scanline[0][RED] = getc(fp);
114 scanline[0][GRN] = getc(fp);
115 scanline[0][BLU] = getc(fp);
116 scanline[0][EXP] = getc(fp);
117 if (feof(fp) || ferror(fp))
118 return(-1);
119 if (scanline[0][RED] == 1 &&
120 scanline[0][GRN] == 1 &&
121 scanline[0][BLU] == 1) {
122 for (i = scanline[0][EXP] << rshift; i > 0; i--) {
123 copycolr(scanline[0], scanline[-1]);
124 scanline++;
125 len--;
126 }
127 rshift += 8;
128 } else {
129 scanline++;
130 len--;
131 rshift = 0;
132 }
133 }
134 return(0);
135 }
136
137
138 int
139 freadcolrs(scanline, len, fp) /* read in an encoded colr scanline */
140 register COLR *scanline;
141 int len;
142 register FILE *fp;
143 {
144 register int i, j;
145 int code, val;
146 /* determine scanline type */
147 if ((len < MINELEN) | (len > MAXELEN))
148 return(oldreadcolrs(scanline, len, fp));
149 if ((i = getc(fp)) == EOF)
150 return(-1);
151 if (i != 2) {
152 ungetc(i, fp);
153 return(oldreadcolrs(scanline, len, fp));
154 }
155 scanline[0][GRN] = getc(fp);
156 scanline[0][BLU] = getc(fp);
157 if ((i = getc(fp)) == EOF)
158 return(-1);
159 if (scanline[0][GRN] != 2 || scanline[0][BLU] & 128) {
160 scanline[0][RED] = 2;
161 scanline[0][EXP] = i;
162 return(oldreadcolrs(scanline+1, len-1, fp));
163 }
164 if ((scanline[0][BLU]<<8 | i) != len)
165 return(-1); /* length mismatch! */
166 /* read each component */
167 for (i = 0; i < 4; i++)
168 for (j = 0; j < len; ) {
169 if ((code = getc(fp)) == EOF)
170 return(-1);
171 if (code > 128) { /* run */
172 code &= 127;
173 if ((val = getc(fp)) == EOF)
174 return -1;
175 while (code--)
176 scanline[j++][i] = val;
177 } else /* non-run */
178 while (code--) {
179 if ((val = getc(fp)) == EOF)
180 return -1;
181 scanline[j++][i] = val;
182 }
183 }
184 return(0);
185 }
186
187
188 int
189 fwritescan(scanline, len, fp) /* write out a scanline */
190 register COLOR *scanline;
191 int len;
192 FILE *fp;
193 {
194 COLR *clrscan;
195 int n;
196 register COLR *sp;
197 /* get scanline buffer */
198 if ((sp = (COLR *)tempbuffer(len*sizeof(COLR))) == NULL)
199 return(-1);
200 clrscan = sp;
201 /* convert scanline */
202 n = len;
203 while (n-- > 0) {
204 setcolr(sp[0], scanline[0][RED],
205 scanline[0][GRN],
206 scanline[0][BLU]);
207 scanline++;
208 sp++;
209 }
210 return(fwritecolrs(clrscan, len, fp));
211 }
212
213
214 int
215 freadscan(scanline, len, fp) /* read in a scanline */
216 register COLOR *scanline;
217 int len;
218 FILE *fp;
219 {
220 register COLR *clrscan;
221
222 if ((clrscan = (COLR *)tempbuffer(len*sizeof(COLR))) == NULL)
223 return(-1);
224 if (freadcolrs(clrscan, len, fp) < 0)
225 return(-1);
226 /* convert scanline */
227 colr_color(scanline[0], clrscan[0]);
228 while (--len > 0) {
229 scanline++; clrscan++;
230 if (clrscan[0][RED] == clrscan[-1][RED] &&
231 clrscan[0][GRN] == clrscan[-1][GRN] &&
232 clrscan[0][BLU] == clrscan[-1][BLU] &&
233 clrscan[0][EXP] == clrscan[-1][EXP])
234 copycolor(scanline[0], scanline[-1]);
235 else
236 colr_color(scanline[0], clrscan[0]);
237 }
238 return(0);
239 }
240
241
242 void
243 setcolr(clr, r, g, b) /* assign a short color value */
244 register COLR clr;
245 double r, g, b;
246 {
247 double d;
248 int e;
249
250 d = r > g ? r : g;
251 if (b > d) d = b;
252
253 if (d <= 1e-32) {
254 clr[RED] = clr[GRN] = clr[BLU] = 0;
255 clr[EXP] = 0;
256 return;
257 }
258
259 d = frexp(d, &e) * 255.9999 / d;
260
261 if (r > 0.0)
262 clr[RED] = r * d;
263 else
264 clr[RED] = 0;
265 if (g > 0.0)
266 clr[GRN] = g * d;
267 else
268 clr[GRN] = 0;
269 if (b > 0.0)
270 clr[BLU] = b * d;
271 else
272 clr[BLU] = 0;
273
274 clr[EXP] = e + COLXS;
275 }
276
277
278 void
279 colr_color(col, clr) /* convert short to float color */
280 register COLOR col;
281 register COLR clr;
282 {
283 double f;
284
285 if (clr[EXP] == 0)
286 col[RED] = col[GRN] = col[BLU] = 0.0;
287 else {
288 f = ldexp(1.0, (int)clr[EXP]-(COLXS+8));
289 col[RED] = (clr[RED] + 0.5)*f;
290 col[GRN] = (clr[GRN] + 0.5)*f;
291 col[BLU] = (clr[BLU] + 0.5)*f;
292 }
293 }
294
295
296 int
297 bigdiff(c1, c2, md) /* c1 delta c2 > md? */
298 register COLOR c1, c2;
299 double md;
300 {
301 register int i;
302
303 for (i = 0; i < 3; i++)
304 if (colval(c1,i)-colval(c2,i) > md*colval(c2,i) ||
305 colval(c2,i)-colval(c1,i) > md*colval(c1,i))
306 return(1);
307 return(0);
308 }
