1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: color.c,v 2.13 2003/07/27 22:12:01 schorsch Exp $"; |
3 |
#endif |
4 |
5 |
* color.c - routines for color calculations. |
6 |
7 |
* Externals declared in color.h |
8 |
9 |
10 |
#include "copyright.h" |
11 |
12 |
#include <stdio.h> |
13 |
14 |
#include <stdlib.h> |
15 |
16 |
#include <math.h> |
17 |
18 |
#include "color.h" |
19 |
20 |
#ifdef getc_unlocked /* avoid horrendous overhead of flockfile */ |
21 |
#define getc getc_unlocked |
22 |
#define putc putc_unlocked |
23 |
#endif |
24 |
25 |
#define MINELEN 8 /* minimum scanline length for encoding */ |
26 |
#define MAXELEN 0x7fff /* maximum scanline length for encoding */ |
27 |
#define MINRUN 4 /* minimum run length */ |
28 |
29 |
30 |
char * |
31 |
tempbuffer(len) /* get a temporary buffer */ |
32 |
unsigned int len; |
33 |
34 |
static char *tempbuf = NULL; |
35 |
static unsigned tempbuflen = 0; |
36 |
37 |
if (len > tempbuflen) { |
38 |
if (tempbuflen > 0) |
39 |
tempbuf = (char *)realloc((void *)tempbuf, len); |
40 |
else |
41 |
tempbuf = (char *)malloc(len); |
42 |
tempbuflen = tempbuf==NULL ? 0 : len; |
43 |
44 |
return(tempbuf); |
45 |
46 |
47 |
48 |
int |
49 |
fwritecolrs(scanline, len, fp) /* write out a colr scanline */ |
50 |
register COLR *scanline; |
51 |
int len; |
52 |
register FILE *fp; |
53 |
54 |
register int i, j, beg, cnt = 1; |
55 |
int c2; |
56 |
57 |
if ((len < MINELEN) | (len > MAXELEN)) /* OOBs, write out flat */ |
58 |
return(fwrite((char *)scanline,sizeof(COLR),len,fp) - len); |
59 |
/* put magic header */ |
60 |
putc(2, fp); |
61 |
putc(2, fp); |
62 |
putc(len>>8, fp); |
63 |
putc(len&255, fp); |
64 |
/* put components seperately */ |
65 |
for (i = 0; i < 4; i++) { |
66 |
for (j = 0; j < len; j += cnt) { /* find next run */ |
67 |
for (beg = j; beg < len; beg += cnt) { |
68 |
for (cnt = 1; cnt < 127 && beg+cnt < len && |
69 |
scanline[beg+cnt][i] == scanline[beg][i]; cnt++) |
70 |
71 |
if (cnt >= MINRUN) |
72 |
break; /* long enough */ |
73 |
74 |
if (beg-j > 1 && beg-j < MINRUN) { |
75 |
c2 = j+1; |
76 |
while (scanline[c2++][i] == scanline[j][i]) |
77 |
if (c2 == beg) { /* short run */ |
78 |
putc(128+beg-j, fp); |
79 |
putc(scanline[j][i], fp); |
80 |
j = beg; |
81 |
break; |
82 |
83 |
84 |
while (j < beg) { /* write out non-run */ |
85 |
if ((c2 = beg-j) > 128) c2 = 128; |
86 |
putc(c2, fp); |
87 |
while (c2--) |
88 |
putc(scanline[j++][i], fp); |
89 |
90 |
if (cnt >= MINRUN) { /* write out run */ |
91 |
putc(128+cnt, fp); |
92 |
putc(scanline[beg][i], fp); |
93 |
} else |
94 |
cnt = 0; |
95 |
96 |
97 |
return(ferror(fp) ? -1 : 0); |
98 |
99 |
100 |
101 |
static int |
102 |
oldreadcolrs(scanline, len, fp) /* read in an old colr scanline */ |
103 |
104 |
int len; |
105 |
106 |
107 |
int rshift; |
108 |
register int i; |
109 |
110 |
rshift = 0; |
111 |
112 |
while (len > 0) { |
113 |
scanline[0][RED] = getc(fp); |
114 |
scanline[0][GRN] = getc(fp); |
115 |
scanline[0][BLU] = getc(fp); |
116 |
scanline[0][EXP] = getc(fp); |
117 |
if (feof(fp) || ferror(fp)) |
118 |
return(-1); |
119 |
if (scanline[0][RED] == 1 && |
120 |
scanline[0][GRN] == 1 && |
121 |
scanline[0][BLU] == 1) { |
122 |
for (i = scanline[0][EXP] << rshift; i > 0; i--) { |
123 |
copycolr(scanline[0], scanline[-1]); |
124 |
scanline++; |
125 |
len--; |
126 |
127 |
rshift += 8; |
128 |
} else { |
129 |
scanline++; |
130 |
len--; |
131 |
rshift = 0; |
132 |
133 |
134 |
return(0); |
135 |
136 |
137 |
138 |
int |
139 |
freadcolrs(scanline, len, fp) /* read in an encoded colr scanline */ |
140 |
141 |
int len; |
142 |
143 |
144 |
register int i, j; |
145 |
int code, val; |
146 |
/* determine scanline type */ |
147 |
if ((len < MINELEN) | (len > MAXELEN)) |
148 |
return(oldreadcolrs(scanline, len, fp)); |
149 |
if ((i = getc(fp)) == EOF) |
150 |
return(-1); |
151 |
if (i != 2) { |
152 |
ungetc(i, fp); |
153 |
154 |
155 |
156 |
157 |
158 |
return(-1); |
159 |
if (scanline[0][GRN] != 2 || scanline[0][BLU] & 128) { |
160 |
scanline[0][RED] = 2; |
161 |
scanline[0][EXP] = i; |
162 |
return(oldreadcolrs(scanline+1, len-1, fp)); |
163 |
164 |
if ((scanline[0][BLU]<<8 | i) != len) |
165 |
return(-1); /* length mismatch! */ |
166 |
/* read each component */ |
167 |
for (i = 0; i < 4; i++) |
168 |
for (j = 0; j < len; ) { |
169 |
if ((code = getc(fp)) == EOF) |
170 |
return(-1); |
171 |
if (code > 128) { /* run */ |
172 |
code &= 127; |
173 |
if ((val = getc(fp)) == EOF) |
174 |
return -1; |
175 |
while (code--) |
176 |
scanline[j++][i] = val; |
177 |
} else /* non-run */ |
178 |
while (code--) { |
179 |
180 |
return -1; |
181 |
182 |
183 |
184 |
return(0); |
185 |
186 |
187 |
188 |
int |
189 |
fwritescan(scanline, len, fp) /* write out a scanline */ |
190 |
register COLOR *scanline; |
191 |
int len; |
192 |
FILE *fp; |
193 |
194 |
COLR *clrscan; |
195 |
int n; |
196 |
register COLR *sp; |
197 |
/* get scanline buffer */ |
198 |
if ((sp = (COLR *)tempbuffer(len*sizeof(COLR))) == NULL) |
199 |
return(-1); |
200 |
clrscan = sp; |
201 |
/* convert scanline */ |
202 |
n = len; |
203 |
while (n-- > 0) { |
204 |
setcolr(sp[0], scanline[0][RED], |
205 |
scanline[0][GRN], |
206 |
scanline[0][BLU]); |
207 |
scanline++; |
208 |
sp++; |
209 |
210 |
return(fwritecolrs(clrscan, len, fp)); |
211 |
212 |
213 |
214 |
int |
215 |
freadscan(scanline, len, fp) /* read in a scanline */ |
216 |
217 |
int len; |
218 |
FILE *fp; |
219 |
220 |
register COLR *clrscan; |
221 |
222 |
if ((clrscan = (COLR *)tempbuffer(len*sizeof(COLR))) == NULL) |
223 |
return(-1); |
224 |
if (freadcolrs(clrscan, len, fp) < 0) |
225 |
return(-1); |
226 |
227 |
colr_color(scanline[0], clrscan[0]); |
228 |
while (--len > 0) { |
229 |
scanline++; clrscan++; |
230 |
if (clrscan[0][RED] == clrscan[-1][RED] && |
231 |
clrscan[0][GRN] == clrscan[-1][GRN] && |
232 |
clrscan[0][BLU] == clrscan[-1][BLU] && |
233 |
clrscan[0][EXP] == clrscan[-1][EXP]) |
234 |
copycolor(scanline[0], scanline[-1]); |
235 |
else |
236 |
237 |
238 |
return(0); |
239 |
240 |
241 |
242 |
void |
243 |
setcolr(clr, r, g, b) /* assign a short color value */ |
244 |
register COLR clr; |
245 |
double r, g, b; |
246 |
247 |
double d; |
248 |
int e; |
249 |
250 |
d = r > g ? r : g; |
251 |
if (b > d) d = b; |
252 |
253 |
if (d <= 1e-32) { |
254 |
clr[RED] = clr[GRN] = clr[BLU] = 0; |
255 |
clr[EXP] = 0; |
256 |
return; |
257 |
258 |
259 |
d = frexp(d, &e) * 255.9999 / d; |
260 |
261 |
if (r > 0.0) |
262 |
clr[RED] = r * d; |
263 |
else |
264 |
clr[RED] = 0; |
265 |
if (g > 0.0) |
266 |
clr[GRN] = g * d; |
267 |
else |
268 |
clr[GRN] = 0; |
269 |
if (b > 0.0) |
270 |
clr[BLU] = b * d; |
271 |
else |
272 |
clr[BLU] = 0; |
273 |
274 |
clr[EXP] = e + COLXS; |
275 |
276 |
277 |
278 |
void |
279 |
colr_color(col, clr) /* convert short to float color */ |
280 |
register COLOR col; |
281 |
282 |
283 |
double f; |
284 |
285 |
if (clr[EXP] == 0) |
286 |
col[RED] = col[GRN] = col[BLU] = 0.0; |
287 |
else { |
288 |
f = ldexp(1.0, (int)clr[EXP]-(COLXS+8)); |
289 |
col[RED] = (clr[RED] + 0.5)*f; |
290 |
col[GRN] = (clr[GRN] + 0.5)*f; |
291 |
col[BLU] = (clr[BLU] + 0.5)*f; |
292 |
293 |
294 |
295 |
296 |
int |
297 |
bigdiff(c1, c2, md) /* c1 delta c2 > md? */ |
298 |
register COLOR c1, c2; |
299 |
double md; |
300 |
301 |
register int i; |
302 |
303 |
for (i = 0; i < 3; i++) |
304 |
if (colval(c1,i)-colval(c2,i) > md*colval(c2,i) || |
305 |
colval(c2,i)-colval(c1,i) > md*colval(c1,i)) |
306 |
return(1); |
307 |
return(0); |
308 |
