root/radiance/ray/src/common/color.c
Revision: 1.15
Committed: Wed Aug 28 08:39:47 1991 UTC (32 years, 9 months ago) by greg
Changes since 1.14: +11 -1 lines
slight improvement to run-length encoding
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * color.c - routines for color calculations.
9 *
10 * 10/10/85
11 */
12
13 #include <stdio.h>
14
15 #include "color.h"
16
17 #define MINELEN 8 /* minimum scanline length for encoding */
18 #define MINRUN 4 /* minimum run length */
19
20
21 char *
22 tempbuffer(len) /* get a temporary buffer */
23 unsigned len;
24 {
25 extern char *malloc(), *realloc();
26 static char *tempbuf = NULL;
27 static int tempbuflen = 0;
28
29 if (len > tempbuflen) {
30 if (tempbuflen > 0)
31 tempbuf = realloc(tempbuf, len);
32 else
33 tempbuf = malloc(len);
34 tempbuflen = tempbuf==NULL ? 0 : len;
35 }
36 return(tempbuf);
37 }
38
39
40 fwritecolrs(scanline, len, fp) /* write out a colr scanline */
41 register COLR *scanline;
42 int len;
43 register FILE *fp;
44 {
45 register int i, j, beg, cnt;
46 int c2;
47
48 if (len < MINELEN) /* too small to encode */
49 return(fwrite((char *)scanline,sizeof(COLR),len,fp) - len);
50 if (len > 32767) /* too big! */
51 return(-1);
52 putc(2, fp); /* put magic header */
53 putc(2, fp);
54 putc(len>>8, fp);
55 putc(len&255, fp);
56 /* put components seperately */
57 for (i = 0; i < 4; i++) {
58 for (j = 0; j < len; j += cnt) { /* find next run */
59 for (beg = j; beg < len; beg += cnt) {
60 for (cnt = 1; cnt < 127 && beg+cnt < len &&
61 scanline[beg+cnt][i] == scanline[beg][i]; cnt++)
62 ;
63 if (cnt >= MINRUN)
64 break; /* long enough */
65 }
66 if (beg-j > 1 && beg-j < MINRUN) {
67 c2 = j+1;
68 while (scanline[c2++][i] == scanline[j][i])
69 if (c2 == beg) { /* short run */
70 putc(128+beg-j, fp);
71 putc(scanline[j][i], fp);
72 j = beg;
73 break;
74 }
75 }
76 while (j < beg) { /* write out non-run */
77 if ((c2 = beg-j) > 128) c2 = 128;
78 putc(c2, fp);
79 while (c2--)
80 putc(scanline[j++][i], fp);
81 }
82 if (cnt >= MINRUN) { /* write out run */
83 putc(128+cnt, fp);
84 putc(scanline[beg][i], fp);
85 } else
86 cnt = 0;
87 }
88 }
89 return(ferror(fp) ? -1 : 0);
90 }
91
92
93 freadcolrs(scanline, len, fp) /* read in an encoded colr scanline */
94 register COLR *scanline;
95 int len;
96 register FILE *fp;
97 {
98 register int i, j;
99 int code;
100 /* determine scanline type */
101 if (len < MINELEN)
102 return(oldreadcolrs(scanline, len, fp));
103 if ((i = getc(fp)) == EOF)
104 return(-1);
105 if (i != 2) {
106 ungetc(i, fp);
107 return(oldreadcolrs(scanline, len, fp));
108 }
109 scanline[0][GRN] = getc(fp);
110 scanline[0][BLU] = getc(fp);
111 if ((i = getc(fp)) == EOF)
112 return(-1);
113 if (scanline[0][GRN] != 2 || scanline[0][BLU] & 128) {
114 scanline[0][RED] = 2;
115 scanline[0][EXP] = i;
116 return(oldreadcolrs(scanline+1, len-1, fp));
117 }
118 if ((scanline[0][BLU]<<8 | i) != len)
119 return(-1); /* length mismatch! */
120 /* read each component */
121 for (i = 0; i < 4; i++)
122 for (j = 0; j < len; ) {
123 if ((code = getc(fp)) == EOF)
124 return(-1);
125 if (code > 128) { /* run */
126 scanline[j++][i] = getc(fp);
127 for (code &= 127; --code; j++)
128 scanline[j][i] = scanline[j-1][i];
129 } else /* non-run */
130 while (code--)
131 scanline[j++][i] = getc(fp);
132 }
133 return(feof(fp) ? -1 : 0);
134 }
135
136
137 oldreadcolrs(scanline, len, fp) /* read in an old colr scanline */
138 register COLR *scanline;
139 int len;
140 register FILE *fp;
141 {
142 int rshift;
143 register int i;
144
145 rshift = 0;
146
147 while (len > 0) {
148 scanline[0][RED] = getc(fp);
149 scanline[0][GRN] = getc(fp);
150 scanline[0][BLU] = getc(fp);
151 scanline[0][EXP] = getc(fp);
152 if (feof(fp) || ferror(fp))
153 return(-1);
154 if (scanline[0][RED] == 1 &&
155 scanline[0][GRN] == 1 &&
156 scanline[0][BLU] == 1) {
157 for (i = scanline[0][EXP] << rshift; i > 0; i--) {
158 copycolr(scanline[0], scanline[-1]);
159 scanline++;
160 len--;
161 }
162 rshift += 8;
163 } else {
164 scanline++;
165 len--;
166 rshift = 0;
167 }
168 }
169 return(0);
170 }
171
172
173 fwritescan(scanline, len, fp) /* write out a scanline */
174 register COLOR *scanline;
175 int len;
176 FILE *fp;
177 {
178 COLR *clrscan;
179 int n;
180 register COLR *sp;
181 /* get scanline buffer */
182 if ((sp = (COLR *)tempbuffer(len*sizeof(COLR))) == NULL)
183 return(-1);
184 clrscan = sp;
185 /* convert scanline */
186 n = len;
187 while (n-- > 0) {
188 setcolr(sp[0], scanline[0][RED],
189 scanline[0][GRN],
190 scanline[0][BLU]);
191 scanline++;
192 sp++;
193 }
194 return(fwritecolrs(clrscan, len, fp));
195 }
196
197
198 freadscan(scanline, len, fp) /* read in a scanline */
199 register COLOR *scanline;
200 int len;
201 FILE *fp;
202 {
203 register COLR *clrscan;
204
205 if ((clrscan = (COLR *)tempbuffer(len*sizeof(COLR))) == NULL)
206 return(-1);
207 if (freadcolrs(clrscan, len, fp) < 0)
208 return(-1);
209 /* convert scanline */
210 colr_color(scanline[0], clrscan[0]);
211 while (--len > 0) {
212 scanline++; clrscan++;
213 if (clrscan[0][RED] == clrscan[-1][RED] &&
214 clrscan[0][GRN] == clrscan[-1][GRN] &&
215 clrscan[0][BLU] == clrscan[-1][BLU] &&
216 clrscan[0][EXP] == clrscan[-1][EXP])
217 copycolor(scanline[0], scanline[-1]);
218 else
219 colr_color(scanline[0], clrscan[0]);
220 }
221 return(0);
222 }
223
224
225 setcolr(clr, r, g, b) /* assign a short color value */
226 register COLR clr;
227 double r, g, b;
228 {
229 double frexp();
230 double d;
231 int e;
232
233 d = r > g ? r : g;
234 if (b > d) d = b;
235
236 if (d <= 1e-32) {
237 clr[RED] = clr[GRN] = clr[BLU] = 0;
238 clr[EXP] = 0;
239 return;
240 }
241
242 d = frexp(d, &e) * 256.0 / d;
243
244 clr[RED] = r * d;
245 clr[GRN] = g * d;
246 clr[BLU] = b * d;
247 clr[EXP] = e + COLXS;
248 }
249
250
251 colr_color(col, clr) /* convert short to float color */
252 register COLOR col;
253 register COLR clr;
254 {
255 double f;
256
257 if (clr[EXP] == 0)
258 col[RED] = col[GRN] = col[BLU] = 0.0;
259 else {
260 f = ldexp(1.0, (int)clr[EXP]-(COLXS+8));
261 col[RED] = (clr[RED] + 0.5)*f;
262 col[GRN] = (clr[GRN] + 0.5)*f;
263 col[BLU] = (clr[BLU] + 0.5)*f;
264 }
265 }
266
267
268 bigdiff(c1, c2, md) /* c1 delta c2 > md? */
269 register COLOR c1, c2;
270 double md;
271 {
272 register int i;
273
274 for (i = 0; i < 3; i++)
275 if (colval(c1,i)-colval(c2,i) > md*colval(c2,i) ||
276 colval(c2,i)-colval(c1,i) > md*colval(c1,i))
277 return(1);
278 return(0);
279 }
