Forgot one #undef
Made reading uncompressed scanlines a bit faster
Long overdue ANSIfication
Added checks for overrun scanlines
Added #undef for getc/putc where they were being replaced
Added redirection for getc() and putc() on threaded C library
Updated man pages and fixed ages old bug in conversion of negative colors
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
bug avoidance in setcolr()
removed incompatible atof(), ldexp() and frexp() defines
minor efficiency improvement in freadcolrs()
hopefully fixed problem for 2-byte int compilers
additional check in freadcolrs() for long scanline
made longer scanlines possible by switching off RLE
slight improvement to run-length encoding
changed encoding of scanlines
moved normcolrs() to colrops.c
removed spec_rgb.c and resolu.c for separate compilation
fixed typo in comment (whew! -- I'll call it quits for today!)
added rounding to normcolrs()
second cut on color normalization
moved bigdiff() from image.c to color.c (more logical)
added macros and routines for normalized short colors
Added routines for getting and putting picture resolution
Fixed overflow problem in setcolr with exponent assignment
deleted frexp() routine
added cast to unsigned value
