root/radiance/ray/src/common/color.c
Sat May 31 20:13:31 2014 UTC (10 years ago) by greg
Changes since 2.16: +50 -41 lines
Diff to previous 2.16 , to selected 1.7
Long overdue ANSIfication
Wed Feb 9 00:00:17 2005 UTC (19 years, 4 months ago) by greg
Changes since 2.15: +7 -2 lines
Diff to previous 2.15 , to selected 1.7
Added checks for overrun scanlines
Tue Sep 14 02:53:50 2004 UTC (19 years, 8 months ago) by greg
Diff to previous 2.14 , to selected 1.7
Added #undef for getc/putc where they were being replaced
Tue Dec 9 15:51:42 2003 UTC (20 years, 6 months ago) by greg
Changes since 2.13: +6 -1 lines
Diff to previous 2.13 , to selected 1.7
Added redirection for getc() and putc() on threaded C library
Diff to previous 2.12 , to selected 1.7
Wed Apr 23 00:52:33 2003 UTC (21 years, 1 month ago) by greg
Diff to previous 2.11 , to selected 1.7
Mon Apr 7 15:43:08 2003 UTC (21 years, 2 months ago) by greg
Changes since 2.10: +13 -3 lines
Diff to previous 2.10 , to selected 1.7
Updated man pages and fixed ages old bug in conversion of negative colors
Diff to previous 2.9 , to selected 1.7
Changes since 2.8: +117 -50 lines
Diff to previous 2.8 , to selected 1.7
Sat Mar 26 13:44:38 1994 UTC (30 years, 2 months ago) by greg
Diff to previous 2.7 , to selected 1.7
bug avoidance in setcolr()
Fri Jun 4 14:51:39 1993 UTC (31 years ago) by greg
Changes since 2.6: +2 -4 lines
Diff to previous 2.6 , to selected 1.7
removed incompatible atof(), ldexp() and frexp() defines
Tue Mar 2 09:09:51 1993 UTC (31 years, 3 months ago) by greg
Diff to previous 2.5 , to selected 1.7
minor efficiency improvement in freadcolrs()
Fri Feb 26 10:08:50 1993 UTC (31 years, 3 months ago) by greg
Diff to previous 2.4 , to selected 1.7
hopefully fixed problem for 2-byte int compilers
Fri Oct 2 15:59:58 1992 UTC (31 years, 8 months ago) by greg
Diff to previous 2.3 , to selected 1.7
Mon Jun 29 22:40:28 1992 UTC (31 years, 11 months ago) by greg
Diff to previous 2.2 , to selected 1.7
additional check in freadcolrs() for long scanline
Tue Jun 23 10:59:34 1992 UTC (31 years, 11 months ago) by greg
Diff to previous 2.1 , to selected 1.7
made longer scanlines possible by switching off RLE
Tue Nov 12 16:55:34 1991 UTC (32 years, 7 months ago) by greg
Diff to previous 1.15 , to selected 1.7
Wed Aug 28 08:39:47 1991 UTC (32 years, 9 months ago) by greg
Changes since 1.14: +11 -1 lines
Diff to previous 1.14 , to selected 1.7
slight improvement to run-length encoding
Fri Aug 23 12:33:49 1991 UTC (32 years, 9 months ago) by greg
Changes since 1.13: +131 -105 lines
Diff to previous 1.13 , to selected 1.7
changed encoding of scanlines
Fri Oct 19 11:13:02 1990 UTC (33 years, 7 months ago) by greg
Changes since 1.12: +0 -42 lines
Diff to previous 1.12 , to selected 1.7
moved normcolrs() to colrops.c
Sat Sep 22 10:45:42 1990 UTC (33 years, 8 months ago) by greg
Changes since 1.11: +0 -138 lines
Diff to previous 1.11 , to selected 1.7
removed spec_rgb.c and resolu.c for separate compilation
Thu Aug 30 09:13:21 1990 UTC (33 years, 9 months ago) by greg
Diff to previous 1.10 , to selected 1.7
fixed typo in comment (whew! -- I'll call it quits for today!)
Fri Jan 26 08:21:45 1990 UTC (34 years, 4 months ago) by greg
Changes since 1.9: +4 -3 lines
Diff to previous 1.9 , to selected 1.7
Mon Nov 6 15:10:24 1989 UTC (34 years, 7 months ago) by greg
Changes since 1.8: +10 -8 lines
Diff to previous 1.8 , to selected 1.7
added rounding to normcolrs()
Fri Oct 20 20:35:22 1989 UTC (34 years, 7 months ago) by greg
Changes since 1.7: +31 -28 lines
Diff to previous 1.7
second cut on color normalization
Revision 1.7 - (view) (download) (annotate) - [selected]
Fri Oct 20 16:53:01 1989 UTC (34 years, 7 months ago) by greg
Changes since 1.6: +14 -0 lines
Diff to previous 1.6
moved bigdiff() from image.c to color.c (more logical)
Fri Oct 20 16:45:26 1989 UTC (34 years, 7 months ago) by greg
Changes since 1.5: +37 -1 lines
added macros and routines for normalized short colors
Wed Sep 13 16:35:14 1989 UTC (34 years, 9 months ago) by greg
Changes since 1.4: +46 -0 lines
Added routines for getting and putting picture resolution
Thu May 11 22:15:57 1989 UTC (35 years, 1 month ago) by greg
Fixed overflow problem in setcolr with exponent assignment
Thu May 11 21:22:38 1989 UTC (35 years, 1 month ago) by greg
Changes since 1.2: +0 -30 lines
deleted frexp() routine
Wed Mar 15 13:48:37 1989 UTC (35 years, 3 months ago) by greg
added cast to unsigned value
Thu Feb 2 10:34:29 1989 UTC (35 years, 4 months ago) by greg
Diff to selected 1.7
