root/radiance/ray/src/common/color.c
Revision: 1.12
Committed: Sat Sep 22 10:45:42 1990 UTC (33 years, 9 months ago) by greg
Changes since 1.11: +0 -138 lines
removed spec_rgb.c and resolu.c for separate compilation
1 /* Copyright (c) 1986 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * color.c - routines for color calculations.
9 *
10 * 10/10/85
11 */
12
13 #include <stdio.h>
14
15 #include "color.h"
16
17
18 fwritecolrs(scanline, len, fp) /* write out a colr scanline */
19 register COLR *scanline;
20 int len;
21 register FILE *fp;
22 {
23 COLR lastcolr;
24 int rept;
25
26 lastcolr[RED] = lastcolr[GRN] = lastcolr[BLU] = 1;
27 lastcolr[EXP] = 0;
28 rept = 0;
29
30 while (len > 0) {
31 if (scanline[0][EXP] == lastcolr[EXP] &&
32 scanline[0][RED] == lastcolr[RED] &&
33 scanline[0][GRN] == lastcolr[GRN] &&
34 scanline[0][BLU] == lastcolr[BLU])
35 rept++;
36 else {
37 while (rept) { /* write out count */
38 putc(1, fp);
39 putc(1, fp);
40 putc(1, fp);
41 putc(rept & 255, fp);
42 rept >>= 8;
43 }
44 putc(scanline[0][RED], fp); /* new color */
45 putc(scanline[0][GRN], fp);
46 putc(scanline[0][BLU], fp);
47 putc(scanline[0][EXP], fp);
48 copycolr(lastcolr, scanline[0]);
49 rept = 0;
50 }
51 scanline++;
52 len--;
53 }
54 while (rept) { /* write out count */
55 putc(1, fp);
56 putc(1, fp);
57 putc(1, fp);
58 putc(rept & 255, fp);
59 rept >>= 8;
60 }
61 return(ferror(fp) ? -1 : 0);
62 }
63
64
65 freadcolrs(scanline, len, fp) /* read in a colr scanline */
66 register COLR *scanline;
67 int len;
68 register FILE *fp;
69 {
70 int rshift;
71 register int i;
72
73 rshift = 0;
74
75 while (len > 0) {
76 scanline[0][RED] = getc(fp);
77 scanline[0][GRN] = getc(fp);
78 scanline[0][BLU] = getc(fp);
79 scanline[0][EXP] = getc(fp);
80 if (feof(fp) || ferror(fp))
81 return(-1);
82 if (scanline[0][RED] == 1 &&
83 scanline[0][GRN] == 1 &&
84 scanline[0][BLU] == 1) {
85 for (i = scanline[0][EXP] << rshift; i > 0; i--) {
86 copycolr(scanline[0], scanline[-1]);
87 scanline++;
88 len--;
89 }
90 rshift += 8;
91 } else {
92 scanline++;
93 len--;
94 rshift = 0;
95 }
96 }
97 return(0);
98 }
99
100
101 fwritescan(scanline, len, fp) /* write out a scanline */
102 register COLOR *scanline;
103 int len;
104 register FILE *fp;
105 {
106 COLR lastcolr, thiscolr;
107 int rept;
108
109 lastcolr[RED] = lastcolr[GRN] = lastcolr[BLU] = 1;
110 lastcolr[EXP] = 0;
111 rept = 0;
112
113 while (len > 0) {
114 setcolr(thiscolr, scanline[0][RED],
115 scanline[0][GRN],
116 scanline[0][BLU]);
117 if (thiscolr[EXP] == lastcolr[EXP] &&
118 thiscolr[RED] == lastcolr[RED] &&
119 thiscolr[GRN] == lastcolr[GRN] &&
120 thiscolr[BLU] == lastcolr[BLU])
121 rept++;
122 else {
123 while (rept) { /* write out count */
124 putc(1, fp);
125 putc(1, fp);
126 putc(1, fp);
127 putc(rept & 255, fp);
128 rept >>= 8;
129 }
130 putc(thiscolr[RED], fp); /* new color */
131 putc(thiscolr[GRN], fp);
132 putc(thiscolr[BLU], fp);
133 putc(thiscolr[EXP], fp);
134 copycolr(lastcolr, thiscolr);
135 rept = 0;
136 }
137 scanline++;
138 len--;
139 }
140 while (rept) { /* write out count */
141 putc(1, fp);
142 putc(1, fp);
143 putc(1, fp);
144 putc(rept & 255, fp);
145 rept >>= 8;
146 }
147 return(ferror(fp) ? -1 : 0);
148 }
149
150
151 freadscan(scanline, len, fp) /* read in a scanline */
152 register COLOR *scanline;
153 int len;
154 register FILE *fp;
155 {
156 COLR thiscolr;
157 int rshift;
158 register int i;
159
160 rshift = 0;
161
162 while (len > 0) {
163 thiscolr[RED] = getc(fp);
164 thiscolr[GRN] = getc(fp);
165 thiscolr[BLU] = getc(fp);
166 thiscolr[EXP] = getc(fp);
167 if (feof(fp) || ferror(fp))
168 return(-1);
169 if (thiscolr[RED] == 1 &&
170 thiscolr[GRN] == 1 &&
171 thiscolr[BLU] == 1) {
172 for (i = thiscolr[EXP] << rshift; i > 0; i--) {
173 copycolor(scanline[0], scanline[-1]);
174 scanline++;
175 len--;
176 }
177 rshift += 8;
178 } else {
179 colr_color(scanline[0], thiscolr);
180 scanline++;
181 len--;
182 rshift = 0;
183 }
184 }
185 return(0);
186 }
187
188
189 setcolr(clr, r, g, b) /* assign a short color value */
190 register COLR clr;
191 double r, g, b;
192 {
193 double frexp();
194 double d;
195 int e;
196
197 d = r > g ? r : g;
198 if (b > d) d = b;
199
200 if (d <= 1e-32) {
201 clr[RED] = clr[GRN] = clr[BLU] = 0;
202 clr[EXP] = 0;
203 return;
204 }
205
206 d = frexp(d, &e) * 256.0 / d;
207
208 clr[RED] = r * d;
209 clr[GRN] = g * d;
210 clr[BLU] = b * d;
211 clr[EXP] = e + COLXS;
212 }
213
214
215 colr_color(col, clr) /* convert short to float color */
216 register COLOR col;
217 register COLR clr;
218 {
219 double f;
220
221 if (clr[EXP] == 0)
222 col[RED] = col[GRN] = col[BLU] = 0.0;
223 else {
224 f = ldexp(1.0, (int)clr[EXP]-(COLXS+8));
225 col[RED] = (clr[RED] + 0.5)*f;
226 col[GRN] = (clr[GRN] + 0.5)*f;
227 col[BLU] = (clr[BLU] + 0.5)*f;
228 }
229 }
230
231
232 normcolrs(scan, len, adjust) /* normalize a scanline of colrs */
233 register COLR *scan;
234 int len;
235 int adjust;
236 {
237 register int c;
238 register int shift;
239
240 while (len-- > 0) {
241 shift = scan[0][EXP] + adjust - COLXS;
242 if (shift > 0) {
243 if (shift > 8) {
244 scan[0][RED] =
245 scan[0][GRN] =
246 scan[0][BLU] = 255;
247 } else {
248 shift--;
249 c = (scan[0][RED]<<1 | 1) << shift;
250 scan[0][RED] = c > 255 ? 255 : c;
251 c = (scan[0][GRN]<<1 | 1) << shift;
252 scan[0][GRN] = c > 255 ? 255 : c;
253 c = (scan[0][BLU]<<1 | 1) << shift;
254 scan[0][BLU] = c > 255 ? 255 : c;
255 }
256 } else if (shift < 0) {
257 if (shift < -8) {
258 scan[0][RED] =
259 scan[0][GRN] =
260 scan[0][BLU] = 0;
261 } else {
262 shift = -1-shift;
263 scan[0][RED] = ((scan[0][RED]>>shift)+1)>>1;
264 scan[0][GRN] = ((scan[0][GRN]>>shift)+1)>>1;
265 scan[0][BLU] = ((scan[0][BLU]>>shift)+1)>>1;
266 }
267 }
268 scan[0][EXP] = COLXS - adjust;
269 scan++;
270 }
271 }
272
273
274 bigdiff(c1, c2, md) /* c1 delta c2 > md? */
275 register COLOR c1, c2;
276 double md;
277 {
278 register int i;
279
280 for (i = 0; i < 3; i++)
281 if (colval(c1,i)-colval(c2,i) > md*colval(c2,i) ||
282 colval(c2,i)-colval(c1,i) > md*colval(c1,i))
283 return(1);
284 return(0);
285 }
