root/radiance/ray/src/common/color.c
Revision: 1.14
Committed: Fri Aug 23 12:33:49 1991 UTC (32 years, 10 months ago) by greg
Changes since 1.13: +131 -105 lines
changed encoding of scanlines
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * color.c - routines for color calculations.
9 *
10 * 10/10/85
11 */
12
13 #include <stdio.h>
14
15 #include "color.h"
16
17 #define MINELEN 8 /* minimum scanline length for encoding */
18 #define MINRUN 4 /* minimum run length */
19
20
21 char *
22 tempbuffer(len) /* get a temporary buffer */
23 unsigned len;
24 {
25 extern char *malloc(), *realloc();
26 static char *tempbuf = NULL;
27 static int tempbuflen = 0;
28
29 if (len > tempbuflen) {
30 if (tempbuflen > 0)
31 tempbuf = realloc(tempbuf, len);
32 else
33 tempbuf = malloc(len);
34 tempbuflen = tempbuf==NULL ? 0 : len;
35 }
36 return(tempbuf);
37 }
38
39
40 fwritecolrs(scanline, len, fp) /* write out a colr scanline */
41 register COLR *scanline;
42 int len;
43 register FILE *fp;
44 {
45 register int i, j, beg, cnt;
46 int c2;
47
48 if (len < MINELEN) /* too small to encode */
49 return(fwrite((char *)scanline,sizeof(COLR),len,fp) - len);
50 if (len > 32767) /* too big! */
51 return(-1);
52 putc(2, fp); /* put magic header */
53 putc(2, fp);
54 putc(len>>8, fp);
55 putc(len&255, fp);
56 /* put components seperately */
57 for (i = 0; i < 4; i++) {
58 for (j = 0; j < len; j += cnt) { /* find next run */
59 for (beg = j; beg < len; beg += cnt) {
60 for (cnt = 1; cnt < 127 && beg+cnt < len &&
61 scanline[beg+cnt][i] == scanline[beg][i]; cnt++)
62 ;
63 if (cnt >= MINRUN)
64 break; /* long enough */
65 }
66 while (j < beg) { /* write out non-run(s) */
67 if ((c2 = beg-j) > 128) c2 = 128;
68 putc(c2, fp);
69 while (c2--)
70 putc(scanline[j++][i], fp);
71 }
72 if (cnt >= MINRUN) { /* write out run */
73 putc(128+cnt, fp);
74 putc(scanline[beg][i], fp);
75 } else
76 cnt = 0;
77 }
78 }
79 return(ferror(fp) ? -1 : 0);
80 }
81
82
83 freadcolrs(scanline, len, fp) /* read in an encoded colr scanline */
84 register COLR *scanline;
85 int len;
86 register FILE *fp;
87 {
88 register int i, j;
89 int code;
90 /* determine scanline type */
91 if (len < MINELEN)
92 return(oldreadcolrs(scanline, len, fp));
93 if ((i = getc(fp)) == EOF)
94 return(-1);
95 if (i != 2) {
96 ungetc(i, fp);
97 return(oldreadcolrs(scanline, len, fp));
98 }
99 scanline[0][GRN] = getc(fp);
100 scanline[0][BLU] = getc(fp);
101 if ((i = getc(fp)) == EOF)
102 return(-1);
103 if (scanline[0][GRN] != 2 || scanline[0][BLU] & 128) {
104 scanline[0][RED] = 2;
105 scanline[0][EXP] = i;
106 return(oldreadcolrs(scanline+1, len-1, fp));
107 }
108 if ((scanline[0][BLU]<<8 | i) != len)
109 return(-1); /* length mismatch! */
110 /* read each component */
111 for (i = 0; i < 4; i++)
112 for (j = 0; j < len; ) {
113 if ((code = getc(fp)) == EOF)
114 return(-1);
115 if (code > 128) { /* run */
116 scanline[j++][i] = getc(fp);
117 for (code &= 127; --code; j++)
118 scanline[j][i] = scanline[j-1][i];
119 } else /* non-run */
120 while (code--)
121 scanline[j++][i] = getc(fp);
122 }
123 return(feof(fp) ? -1 : 0);
124 }
125
126
127 oldreadcolrs(scanline, len, fp) /* read in an old colr scanline */
128 register COLR *scanline;
129 int len;
130 register FILE *fp;
131 {
132 int rshift;
133 register int i;
134
135 rshift = 0;
136
137 while (len > 0) {
138 scanline[0][RED] = getc(fp);
139 scanline[0][GRN] = getc(fp);
140 scanline[0][BLU] = getc(fp);
141 scanline[0][EXP] = getc(fp);
142 if (feof(fp) || ferror(fp))
143 return(-1);
144 if (scanline[0][RED] == 1 &&
145 scanline[0][GRN] == 1 &&
146 scanline[0][BLU] == 1) {
147 for (i = scanline[0][EXP] << rshift; i > 0; i--) {
148 copycolr(scanline[0], scanline[-1]);
149 scanline++;
150 len--;
151 }
152 rshift += 8;
153 } else {
154 scanline++;
155 len--;
156 rshift = 0;
157 }
158 }
159 return(0);
160 }
161
162
163 fwritescan(scanline, len, fp) /* write out a scanline */
164 register COLOR *scanline;
165 int len;
166 FILE *fp;
167 {
168 COLR *clrscan;
169 int n;
170 register COLR *sp;
171 /* get scanline buffer */
172 if ((sp = (COLR *)tempbuffer(len*sizeof(COLR))) == NULL)
173 return(-1);
174 clrscan = sp;
175 /* convert scanline */
176 n = len;
177 while (n-- > 0) {
178 setcolr(sp[0], scanline[0][RED],
179 scanline[0][GRN],
180 scanline[0][BLU]);
181 scanline++;
182 sp++;
183 }
184 return(fwritecolrs(clrscan, len, fp));
185 }
186
187
188 freadscan(scanline, len, fp) /* read in a scanline */
189 register COLOR *scanline;
190 int len;
191 FILE *fp;
192 {
193 register COLR *clrscan;
194
195 if ((clrscan = (COLR *)tempbuffer(len*sizeof(COLR))) == NULL)
196 return(-1);
197 if (freadcolrs(clrscan, len, fp) < 0)
198 return(-1);
199 /* convert scanline */
200 colr_color(scanline[0], clrscan[0]);
201 while (--len > 0) {
202 scanline++; clrscan++;
203 if (clrscan[0][RED] == clrscan[-1][RED] &&
204 clrscan[0][GRN] == clrscan[-1][GRN] &&
205 clrscan[0][BLU] == clrscan[-1][BLU] &&
206 clrscan[0][EXP] == clrscan[-1][EXP])
207 copycolor(scanline[0], scanline[-1]);
208 else
209 colr_color(scanline[0], clrscan[0]);
210 }
211 return(0);
212 }
213
214
215 setcolr(clr, r, g, b) /* assign a short color value */
216 register COLR clr;
217 double r, g, b;
218 {
219 double frexp();
220 double d;
221 int e;
222
223 d = r > g ? r : g;
224 if (b > d) d = b;
225
226 if (d <= 1e-32) {
227 clr[RED] = clr[GRN] = clr[BLU] = 0;
228 clr[EXP] = 0;
229 return;
230 }
231
232 d = frexp(d, &e) * 256.0 / d;
233
234 clr[RED] = r * d;
235 clr[GRN] = g * d;
236 clr[BLU] = b * d;
237 clr[EXP] = e + COLXS;
238 }
239
240
241 colr_color(col, clr) /* convert short to float color */
242 register COLOR col;
243 register COLR clr;
244 {
245 double f;
246
247 if (clr[EXP] == 0)
248 col[RED] = col[GRN] = col[BLU] = 0.0;
249 else {
250 f = ldexp(1.0, (int)clr[EXP]-(COLXS+8));
251 col[RED] = (clr[RED] + 0.5)*f;
252 col[GRN] = (clr[GRN] + 0.5)*f;
253 col[BLU] = (clr[BLU] + 0.5)*f;
254 }
255 }
256
257
258 bigdiff(c1, c2, md) /* c1 delta c2 > md? */
259 register COLOR c1, c2;
260 double md;
261 {
262 register int i;
263
264 for (i = 0; i < 3; i++)
265 if (colval(c1,i)-colval(c2,i) > md*colval(c2,i) ||
266 colval(c2,i)-colval(c1,i) > md*colval(c1,i))
267 return(1);
268 return(0);
269 }
