--- ray/src/common/color.c 1992/06/23 10:59:34 2.2
+++ ray/src/common/color.c 2003/02/22 02:07:22 2.9
@@ -1,51 +1,110 @@
-/* Copyright (c) 1991 Regents of the University of California */
#ifndef lint
-static char SCCSid[] = "$SunId$ LBL";
+static const char RCSid[] = "$Id: color.c,v 2.9 2003/02/22 02:07:22 greg Exp $";
#endif
* color.c - routines for color calculations.
- * 10/10/85
+ * Externals declared in color.h
+ * The Radiance Software License, Version 1.0
+ * Copyright (c) 1990 - 2002 The Regents of the University of California,
+ * through Lawrence Berkeley National Laboratory. All rights reserved.
+ * Redistribution and use in source and binary forms, with or without
+ * modification, are permitted provided that the following conditions
+ * are met:
+ * 1. Redistributions of source code must retain the above copyright
+ * notice, this list of conditions and the following disclaimer.
+ * 2. Redistributions in binary form must reproduce the above copyright
+ * notice, this list of conditions and the following disclaimer in
+ * the documentation and/or other materials provided with the
+ * distribution.
+ * 3. The end-user documentation included with the redistribution,
+ * if any, must include the following acknowledgment:
+ * "This product includes Radiance software
+ * (http://radsite.lbl.gov/)
+ * developed by the Lawrence Berkeley National Laboratory
+ * (http://www.lbl.gov/)."
+ * Alternately, this acknowledgment may appear in the software itself,
+ * if and wherever such third-party acknowledgments normally appear.
+ * 4. The names "Radiance," "Lawrence Berkeley National Laboratory"
+ * and "The Regents of the University of California" must
+ * not be used to endorse or promote products derived from this
+ * software without prior written permission. For written
+ * permission, please contact radiance@radsite.lbl.gov.
+ * 5. Products derived from this software may not be called "Radiance",
+ * nor may "Radiance" appear in their name, without prior written
+ * permission of Lawrence Berkeley National Laboratory.
+ * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED
+ * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
+ * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
+ * DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR
+ * ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
+ * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
+ * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
+ * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
+ * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
+ * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
+ * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ * This software consists of voluntary contributions made by many
+ * individuals on behalf of Lawrence Berkeley National Laboratory. For more
+ * information on Lawrence Berkeley National Laboratory, please see
#include
+#include
+#include
#include "color.h"
#define MINELEN 8 /* minimum scanline length for encoding */
+#define MAXELEN 0x7fff /* maximum scanline length for encoding */
#define MINRUN 4 /* minimum run length */
char *
tempbuffer(len) /* get a temporary buffer */
-unsigned len;
+unsigned int len;
- extern char *malloc(), *realloc();
static char *tempbuf = NULL;
- static int tempbuflen = 0;
+ static unsigned tempbuflen = 0;
if (len > tempbuflen) {
if (tempbuflen > 0)
- tempbuf = realloc(tempbuf, len);
+ tempbuf = (char *)realloc(tempbuf, len);
else
- tempbuf = malloc(len);
+ tempbuf = (char *)malloc(len);
tempbuflen = tempbuf==NULL ? 0 : len;
return(tempbuf);
+int
fwritecolrs(scanline, len, fp) /* write out a colr scanline */
register COLR *scanline;
-unsigned len;
+int len;
register FILE *fp;
- register int i, j, beg, cnt;
+ register int i, j, beg, cnt = 1;
int c2;
- if (len < MINELEN | len > 0x7fff) /* OOBs, write out flat */
+ if (len < MINELEN | len > MAXELEN) /* OOBs, write out flat */
return(fwrite((char *)scanline,sizeof(COLR),len,fp) - len);
/* put magic header */
putc(2, fp);
@@ -89,15 +148,53 @@ register FILE *fp;
+static int
+oldreadcolrs(scanline, len, fp) /* read in an old colr scanline */
+register COLR *scanline;
+int len;
+register FILE *fp;
+ int rshift;
+ register int i;
+ rshift = 0;
+ while (len > 0) {
+ scanline[0][RED] = getc(fp);
+ scanline[0][GRN] = getc(fp);
+ scanline[0][BLU] = getc(fp);
+ scanline[0][EXP] = getc(fp);
+ if (feof(fp) || ferror(fp))
+ return(-1);
+ if (scanline[0][RED] == 1 &&
+ scanline[0][GRN] == 1 &&
+ scanline[0][BLU] == 1) {
+ for (i = scanline[0][EXP] << rshift; i > 0; i--) {
+ copycolr(scanline[0], scanline[-1]);
+ scanline++;
+ len--;
+ rshift += 8;
+ } else {
+ scanline++;
+ len--;
+ rshift = 0;
+ return(0);
+int
freadcolrs(scanline, len, fp) /* read in an encoded colr scanline */
int len;
register FILE *fp;
register int i, j;
- int code;
+ int code, val;
/* determine scanline type */
- if (len < MINELEN)
return(oldreadcolrs(scanline, len, fp));
if ((i = getc(fp)) == EOF)
return(-1);
@@ -122,53 +219,23 @@ register FILE *fp;
if ((code = getc(fp)) == EOF)
return(-1);
if (code > 128) { /* run */
- scanline[j++][i] = getc(fp);
- for (code &= 127; --code; j++)
- scanline[j][i] = scanline[j-1][i];
- } else /* non-run */
+ code &= 127;
+ if ((val = getc(fp)) == EOF)
+ return -1;
while (code--)
+ scanline[j++][i] = val;
+ } else /* non-run */
+ while (code--) {
+ return -1;
- return(feof(fp) ? -1 : 0);
-oldreadcolrs(scanline, len, fp) /* read in an old colr scanline */
-register COLR *scanline;
-int len;
-register FILE *fp;
- int rshift;
- register int i;
- rshift = 0;
- while (len > 0) {
- scanline[0][RED] = getc(fp);
- scanline[0][GRN] = getc(fp);
- scanline[0][BLU] = getc(fp);
- scanline[0][EXP] = getc(fp);
- if (feof(fp) || ferror(fp))
- return(-1);
- if (scanline[0][RED] == 1 &&
- scanline[0][GRN] == 1 &&
- scanline[0][BLU] == 1) {
- for (i = scanline[0][EXP] << rshift; i > 0; i--) {
- copycolr(scanline[0], scanline[-1]);
- scanline++;
- len--;
- rshift += 8;
- } else {
- scanline++;
- len--;
- rshift = 0;
return(0);
+int
fwritescan(scanline, len, fp) /* write out a scanline */
register COLOR *scanline;
int len;
@@ -194,6 +261,7 @@ FILE *fp;
+int
freadscan(scanline, len, fp) /* read in a scanline */
int len;
@@ -221,11 +289,11 @@ FILE *fp;
+void
setcolr(clr, r, g, b) /* assign a short color value */
register COLR clr;
double r, g, b;
- double frexp();
double d;
int e;
@@ -238,7 +306,7 @@ double r, g, b;
return;
- d = frexp(d, &e) * 256.0 / d;
+ d = frexp(d, &e) * 255.9999 / d;
clr[RED] = r * d;
clr[GRN] = g * d;
@@ -247,6 +315,7 @@ double r, g, b;
+void
colr_color(col, clr) /* convert short to float color */
register COLOR col;
register COLR clr;
@@ -264,6 +333,7 @@ register COLR clr;
+int
bigdiff(c1, c2, md) /* c1 delta c2 > md? */
register COLOR c1, c2;
double md;
