1 |
/* Copyright (c) 1986 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* color.c - routines for color calculations. |
9 |
10 |
* 10/10/85 |
11 |
12 |
13 |
#include <stdio.h> |
14 |
15 |
#include "color.h" |
16 |
17 |
#ifdef SPEC_RGB |
18 |
19 |
* The following table contains the CIE tristimulus integrals |
20 |
* for X, Y, and Z. The table is cumulative, so that |
21 |
* each color coordinate integrates to 1. |
22 |
23 |
24 |
#define STARTWL 380 /* starting wavelength (nanometers) */ |
25 |
#define INCWL 10 /* wavelength increment */ |
26 |
#define NINC 40 /* # of values */ |
27 |
28 |
static BYTE chroma[3][NINC] = { |
29 |
{ /* X */ |
30 |
0, 0, 0, 2, 6, 13, 22, 30, 36, 41, |
31 |
42, 43, 43, 44, 46, 52, 60, 71, 87, 106, |
32 |
128, 153, 178, 200, 219, 233, 243, 249, 252, 254, |
33 |
255, 255, 255, 255, 255, 255, 255, 255, 255, 255 |
34 |
}, { /* Y */ |
35 |
0, 0, 0, 0, 0, 1, 2, 4, 7, 11, |
36 |
17, 24, 34, 48, 64, 84, 105, 127, 148, 169, |
37 |
188, 205, 220, 232, 240, 246, 250, 253, 254, 255, |
38 |
39 |
}, { /* Z */ |
40 |
0, 0, 2, 10, 32, 66, 118, 153, 191, 220, |
41 |
237, 246, 251, 253, 254, 255, 255, 255, 255, 255, |
42 |
255, 255, 255, 255, 255, 255, 255, 255, 255, 255, |
43 |
44 |
45 |
46 |
47 |
48 |
spec_rgb(col, s, e) /* comput RGB color from spectral range */ |
49 |
COLOR col; |
50 |
int s, e; |
51 |
52 |
COLOR ciecolor; |
53 |
54 |
spec_cie(ciecolor, s, e); |
55 |
cie_rgb(col, ciecolor); |
56 |
57 |
58 |
59 |
spec_cie(col, s, e) /* compute a color from a spectral range */ |
60 |
COLOR col; /* returned color */ |
61 |
int s, e; /* starting and ending wavelengths */ |
62 |
63 |
register int i, d, r; |
64 |
65 |
s -= STARTWL; |
66 |
if (s < 0) |
67 |
s = 0; |
68 |
69 |
e -= STARTWL; |
70 |
if (e >= INCWL*(NINC - 1)) |
71 |
e = INCWL*(NINC - 1) - 1; |
72 |
73 |
d = e / INCWL; /* interpolate values */ |
74 |
r = e % INCWL; |
75 |
for (i = 0; i < 3; i++) |
76 |
col[i] = chroma[i][d]*(INCWL - r) + chroma[i][d + 1]*r; |
77 |
78 |
d = s / INCWL; |
79 |
r = s % INCWL; |
80 |
81 |
col[i] -= chroma[i][d]*(INCWL - r) - chroma[i][d + 1]*r; |
82 |
83 |
col[RED] = (col[RED] + 0.5) / (256*INCWL); |
84 |
col[GRN] = (col[GRN] + 0.5) / (256*INCWL); |
85 |
col[BLU] = (col[BLU] + 0.5) / (256*INCWL); |
86 |
87 |
88 |
89 |
cie_rgb(rgbcolor, ciecolor) /* convert CIE to RGB (NTSC) */ |
90 |
register COLOR rgbcolor, ciecolor; |
91 |
92 |
static float cmat[3][3] = { |
93 |
1.73, -.48, -.26, |
94 |
-.81, 1.65, -.02, |
95 |
.08, -.17, 1.28, |
96 |
97 |
register int i; |
98 |
99 |
for (i = 0; i < 3; i++) { |
100 |
rgbcolor[i] = cmat[i][0]*ciecolor[0] + |
101 |
cmat[i][1]*ciecolor[1] + |
102 |
cmat[i][2]*ciecolor[2] ; |
103 |
if (rgbcolor[i] < 0.0) |
104 |
rgbcolor[i] = 0.0; |
105 |
106 |
107 |
#endif |
108 |
109 |
110 |
fwritecolrs(scanline, len, fp) /* write out a colr scanline */ |
111 |
register COLR *scanline; |
112 |
int len; |
113 |
register FILE *fp; |
114 |
115 |
COLR lastcolr; |
116 |
int rept; |
117 |
118 |
lastcolr[RED] = lastcolr[GRN] = lastcolr[BLU] = 1; |
119 |
lastcolr[EXP] = 0; |
120 |
rept = 0; |
121 |
122 |
while (len > 0) { |
123 |
if (scanline[0][EXP] == lastcolr[EXP] && |
124 |
scanline[0][RED] == lastcolr[RED] && |
125 |
scanline[0][GRN] == lastcolr[GRN] && |
126 |
scanline[0][BLU] == lastcolr[BLU]) |
127 |
rept++; |
128 |
else { |
129 |
while (rept) { /* write out count */ |
130 |
putc(1, fp); |
131 |
putc(1, fp); |
132 |
putc(1, fp); |
133 |
putc(rept & 255, fp); |
134 |
rept >>= 8; |
135 |
136 |
putc(scanline[0][RED], fp); /* new color */ |
137 |
putc(scanline[0][GRN], fp); |
138 |
putc(scanline[0][BLU], fp); |
139 |
putc(scanline[0][EXP], fp); |
140 |
copycolr(lastcolr, scanline[0]); |
141 |
rept = 0; |
142 |
143 |
scanline++; |
144 |
len--; |
145 |
146 |
147 |
putc(1, fp); |
148 |
putc(1, fp); |
149 |
putc(1, fp); |
150 |
151 |
rept >>= 8; |
152 |
153 |
return(ferror(fp) ? -1 : 0); |
154 |
155 |
156 |
157 |
freadcolrs(scanline, len, fp) /* read in a colr scanline */ |
158 |
159 |
int len; |
160 |
161 |
162 |
int rshift; |
163 |
register int i; |
164 |
165 |
rshift = 0; |
166 |
167 |
while (len > 0) { |
168 |
scanline[0][RED] = getc(fp); |
169 |
scanline[0][GRN] = getc(fp); |
170 |
scanline[0][BLU] = getc(fp); |
171 |
scanline[0][EXP] = getc(fp); |
172 |
if (feof(fp) || ferror(fp)) |
173 |
return(-1); |
174 |
if (scanline[0][RED] == 1 && |
175 |
scanline[0][GRN] == 1 && |
176 |
scanline[0][BLU] == 1) { |
177 |
for (i = scanline[0][EXP] << rshift; i > 0; i--) { |
178 |
copycolr(scanline[0], scanline[-1]); |
179 |
scanline++; |
180 |
len--; |
181 |
182 |
rshift += 8; |
183 |
} else { |
184 |
scanline++; |
185 |
len--; |
186 |
rshift = 0; |
187 |
188 |
189 |
return(0); |
190 |
191 |
192 |
193 |
fwritescan(scanline, len, fp) /* write out a scanline */ |
194 |
register COLOR *scanline; |
195 |
int len; |
196 |
197 |
198 |
COLR lastcolr, thiscolr; |
199 |
int rept; |
200 |
201 |
202 |
203 |
rept = 0; |
204 |
205 |
while (len > 0) { |
206 |
setcolr(thiscolr, scanline[0][RED], |
207 |
scanline[0][GRN], |
208 |
scanline[0][BLU]); |
209 |
if (thiscolr[EXP] == lastcolr[EXP] && |
210 |
thiscolr[RED] == lastcolr[RED] && |
211 |
thiscolr[GRN] == lastcolr[GRN] && |
212 |
thiscolr[BLU] == lastcolr[BLU]) |
213 |
rept++; |
214 |
else { |
215 |
216 |
putc(1, fp); |
217 |
putc(1, fp); |
218 |
putc(1, fp); |
219 |
220 |
rept >>= 8; |
221 |
222 |
putc(thiscolr[RED], fp); /* new color */ |
223 |
putc(thiscolr[GRN], fp); |
224 |
putc(thiscolr[BLU], fp); |
225 |
putc(thiscolr[EXP], fp); |
226 |
copycolr(lastcolr, thiscolr); |
227 |
rept = 0; |
228 |
229 |
scanline++; |
230 |
len--; |
231 |
232 |
233 |
putc(1, fp); |
234 |
putc(1, fp); |
235 |
putc(1, fp); |
236 |
237 |
rept >>= 8; |
238 |
239 |
240 |
241 |
242 |
243 |
freadscan(scanline, len, fp) /* read in a scanline */ |
244 |
245 |
int len; |
246 |
247 |
248 |
COLR thiscolr; |
249 |
int rshift; |
250 |
register int i; |
251 |
252 |
rshift = 0; |
253 |
254 |
while (len > 0) { |
255 |
thiscolr[RED] = getc(fp); |
256 |
thiscolr[GRN] = getc(fp); |
257 |
thiscolr[BLU] = getc(fp); |
258 |
thiscolr[EXP] = getc(fp); |
259 |
260 |
return(-1); |
261 |
if (thiscolr[RED] == 1 && |
262 |
thiscolr[GRN] == 1 && |
263 |
thiscolr[BLU] == 1) { |
264 |
for (i = thiscolr[EXP] << rshift; i > 0; i--) { |
265 |
copycolor(scanline[0], scanline[-1]); |
266 |
scanline++; |
267 |
len--; |
268 |
269 |
rshift += 8; |
270 |
} else { |
271 |
colr_color(scanline[0], thiscolr); |
272 |
scanline++; |
273 |
len--; |
274 |
rshift = 0; |
275 |
276 |
277 |
return(0); |
278 |
279 |
280 |
281 |
setcolr(clr, r, g, b) /* assign a short color value */ |
282 |
register COLR clr; |
283 |
double r, g, b; |
284 |
285 |
double frexp(); |
286 |
double d; |
287 |
int e; |
288 |
289 |
d = r > g ? r : g; |
290 |
if (b > d) d = b; |
291 |
292 |
if (d <= 0.0) { |
293 |
clr[RED] = clr[GRN] = clr[BLU] = 0; |
294 |
clr[EXP] = 0; |
295 |
return; |
296 |
297 |
298 |
d = frexp(d, &e) * 256.0 / d; |
299 |
300 |
clr[RED] = r * d; |
301 |
clr[GRN] = g * d; |
302 |
clr[BLU] = b * d; |
303 |
clr[EXP] = e + COLXS; |
304 |
305 |
306 |
307 |
colr_color(col, clr) /* convert short to float color */ |
308 |
register COLOR col; |
309 |
310 |
311 |
double ldexp(), f; |
312 |
313 |
if (clr[EXP] == 0) |
314 |
col[RED] = col[GRN] = col[BLU] = 0.0; |
315 |
else { |
316 |
f = ldexp(1.0, clr[EXP]-(COLXS+8)); |
317 |
col[RED] = (clr[RED] + 0.5)*f; |
318 |
col[GRN] = (clr[GRN] + 0.5)*f; |
319 |
col[BLU] = (clr[BLU] + 0.5)*f; |
320 |
321 |
322 |
323 |
324 |
#ifdef FREXP |
325 |
double |
326 |
frexp(x, ip) /* call it paranoia, I've seen the lib version */ |
327 |
register double x; |
328 |
int *ip; |
329 |
330 |
int neg; |
331 |
register int i; |
332 |
333 |
if (neg = (x < 0.0)) |
334 |
x = -x; |
335 |
else if (x == 0.0) { |
336 |
*ip = 0; |
337 |
return(0.0); |
338 |
339 |
if (x < 0.5) |
340 |
for (i = 0; x < 0.5; i--) |
341 |
x *= 2.0; |
342 |
else |
343 |
for (i = 0; x >= 1.0; i++) |
344 |
x /= 2.0; |
345 |
*ip = i; |
346 |
if (neg) |
347 |
return(-x); |
348 |
else |
349 |
return(x); |
350 |
351 |
#endif |
