--- ray/src/common/color.c 1989/11/06 15:10:24 1.9 +++ ray/src/common/color.c 1990/08/30 09:13:21 1.11 @@ -45,7 +45,7 @@ static BYTE chroma[3][NINC] = { }; -spec_rgb(col, s, e) /* comput RGB color from spectral range */ +spec_rgb(col, s, e) /* compute RGB color from spectral range */ COLOR col; int s, e; { @@ -367,15 +367,16 @@ register COLR clr; } -normcolrs(scan, len) /* normalize a scanline of colrs */ +normcolrs(scan, len, adjust) /* normalize a scanline of colrs */ register COLR *scan; int len; +int adjust; { register int c; register int shift; while (len-- > 0) { - shift = scan[0][EXP] - COLXS; + shift = scan[0][EXP] + adjust - COLXS; if (shift > 0) { if (shift > 8) { scan[0][RED] = @@ -402,7 +403,7 @@ int len; scan[0][BLU] = ((scan[0][BLU]>>shift)+1)>>1; } } - scan[0][EXP] = COLXS; + scan[0][EXP] = COLXS - adjust; scan++; } }
