root/radiance/ray/src/common/color.c
Revision: 2.27
Committed: Wed Nov 15 18:02:52 2023 UTC (6 months, 3 weeks ago) by greg
Changes since 2.26: +287 -25 lines
2 static const char RCSid[] = "$Id: color.c,v 2.X in progress $";
5 * color.c - routines for color calculations.
6 *
7 * Externals declared in color.h
8 */
9
10 #include "copyright.h"
11
12 #include <stdio.h>
13 #include <stdlib.h>
14 #include <math.h>
15 #include "color.h"
16
17 #ifdef getc_unlocked /* avoid horrendous overhead of flockfile */
18 #undef getc
19 #undef putc
20 #undef ferror
21 #define getc getc_unlocked
22 #define putc putc_unlocked
23 #define ferror ferror_unlocked
24 #endif
25
26 #define MINELEN 8 /* minimum scanline length for encoding */
27 #define MAXELEN 0x7fff /* maximum scanline length for encoding */
28 #define MINRUN 4 /* minimum run length */
29
30
31 int CNDX[4] = {0,1,2,3}; /* RGBE indices for SCOLOR, SCOLR */
32 float WLPART[4] = {780,588,480,380}; /* RGB wavelength limits+partitions (nm) */
33
34
35 int
36 setspectrsamp( /* assign spectral sampling, 1 if good, -1 if bad */
37 int cn[4], /* input cn[3]=nsamps */
38 float wlpt[4] /* input wlpt[0],wlpt[3]=extrema */
39 )
40 {
41 static const float PKWL[3] = {607, 553, 469};
42 int i, j;
43
44 if (cn[3] < 3)
45 return(-1); /* reject this */
46
47 if (wlpt[0] < wlpt[3]) {
48 float tf = wlpt[0];
49 wlpt[0] = wlpt[3]; wlpt[3] = tf;
50 }
51 if (wlpt[0] - wlpt[3] < 50.f)
52 return(-1); /* also reject */
53
54 if (cn[3] > MAXCSAMP)
55 cn[3] = MAXCSAMP;
56
57 if ((wlpt[3] >= PKWL[2]) | (wlpt[0] <= PKWL[0])) {
58 wlpt[1] = wlpt[0] + 0.333333f*(wlpt[3]-wlpt[0]);
59 wlpt[2] = wlpt[0] + 0.666667f*(wlpt[3]-wlpt[0]);
60 cn[0] = 0; cn[1] = cn[3]/3; cn[2] = cn[3]*2/3;
61 return(0); /* unhappy but non-fatal return value */
62 }
63 wlpt[1] = 588.f; /* tuned for standard green channel */
64 wlpt[2] = 480.f;
65 if (cn[3] == 3) { /* nothing to tune? */
66 cn[0] = 0; cn[1] = 1; cn[2] = 2;
67 } else { /* else find nearest color indices */
68 double curwl[3];
69 memset(curwl, 0, sizeof(curwl));
70 for (i = cn[3]; i--; ) {
71 const float cwl = (i+.5f)/cn[3]*(wlpt[3]-wlpt[0]) + wlpt[0];
72 for (j = 3; j--; )
73 if (fabs(cwl - PKWL[j]) < fabs(curwl[j] - PKWL[j])) {
74 curwl[j] = cwl;
75 cn[j] = i;
76 }
77 }
78 }
79 return(1); /* happy return value */
80 }
81
82
83 void
84 setscolor( /* assign spectral color from RGB */
85 SCOLOR scol,
86 double r,
87 double g,
88 double b
89 )
90 {
91 const double step = (WLPART[3] - WLPART[0])/(double)NCSAMP;
92 double cwl = WLPART[0] + .5*step;
93 int i;
94
95 for (i = 0; i < NCSAMP; i++) {
96 if (cwl >= WLPART[1])
97 scol[i] = r;
98 else if (cwl >= WLPART[2])
99 scol[i] = g;
100 else
101 scol[i] = b;
102 cwl += step;
103 }
104 }
105
106
107 void
108 scolor2color( /* assign RGB color from spectrum */
109 COLOR col,
110 SCOLOR scol, /* uses average over bands */
111 int ncs,
112 float wlpt[4]
113 )
114 {
115 const double step = (wlpt[3] - wlpt[0])/(double)ncs;
116 double cwl = wlpt[0] + .5*step;
117 int i, j=0, n=0;
118
119 setcolor(col, 0, 0, 0);
120 for (i = 0; i < ncs; i++) {
121 if (cwl < wlpt[j+1]) {
122 if (n > 1) col[j] /= (COLORV)n;
123 j++;
124 n = 0;
125 }
126 col[j] += scol[i];
127 n++;
128 cwl += step;
129 }
130 if (n > 1) col[j] /= (COLORV)n;
131 }
132
133
134 void
135 scolor2colr( /* assign RGBE from spectral color */
136 COLR clr,
137 SCOLOR scol, /* uses average over bands */
138 int ncs,
139 float wlpt[4]
140 )
141 {
142 COLOR col;
143
144 scolor2color(col, scol, ncs, wlpt);
145 setcolr(clr, col[RED], col[GRN], col[BLU]);
146 }
147
148
149 void
150 scolor2scolr( /* float spectrum to common exponent */
151 SCOLR sclr,
152 SCOLOR scol,
153 int ncs
154 )
155 {
156 int i = ncs;
157 COLORV p = scol[--i];
158
159 while (i)
160 if (scol[--i] > p)
161 p = scol[i];
162 if (p <= 1e-32) {
163 memset(sclr, 0, ncs+1);
164 return;
165 }
166 p = frexp(p, &i) * 256.0 / p;
167 sclr[ncs] = i + COLXS;
168 for (i = ncs; i--; )
169 sclr[i] = (scol[i] > 0) * (int)(scol[i]*p);
170 }
171
172
173 void
174 scolr2scolor( /* common exponent to float spectrum */
175 SCOLOR scol,
176 SCOLR sclr,
177 int ncs
178 )
179 {
180 double f;
181 int i;
182
183 if (sclr[ncs] == 0) {
184 memset(scol, 0, sizeof(COLORV)*ncs);
185 return;
186 }
187 f = ldexp(1.0, (int)sclr[ncs]-(COLXS+8));
188
189 for (i = ncs; i--; )
190 scol[i] = (sclr[i] + 0.5)*f;
191 }
192
193
194 double
195 scolor_mean( /* compute average for spectral color */
196 SCOLOR scol
197 )
198 {
199 int i = NCSAMP;
200 double sum = 0;
201
202 while (i--)
203 sum += scol[i];
204
205 return sum/(double)NCSAMP;
206 }
207
208
209 double
210 sintens( /* find maximum value from spectrum */
211 SCOLOR scol
212 )
213 {
214 int i = NCSAMP;
215 COLORV peak = scol[--i];
216
217 while (i)
218 if (scol[--i] > peak)
219 peak = scol[i];
220
221 return peak;
222 }
223
224
225 void
226 convertscolor( /* spectrum conversion, zero-fill ends */
227 SCOLOR dst, /* destination spectrum */
228 int dnc, /* destination # of spectral samples/intervals */
229 double dwl0, /* starting destination wavelength (longer) */
230 double dwl1, /* ending destination wavelength (shorter) */
231 const COLORV src[], /* source spectrum array */
232 int snc,
233 double swl0, /* long/short wavelengths may be reversed */
234 double swl1
235 )
236 {
237 const int sdir = 1 - 2*(swl0 < swl1);
238 const double sstp = (swl1 - swl0)/(double)snc;
239 const double dstp = (dwl1 - dwl0)/(double)dnc;
240 const double rdstp = 1./dstp;
241 int si, ssi, di;
242 double wl;
243
244 if ((dnc < 3) | (dwl0 <= dwl1) | (dst == src))
245 return; /* invalid destination */
246
247 if (dnc == snc && (dwl0-swl0)*(dwl0-swl0) + (dwl1-swl1)*(dwl1-swl1) <= .5) {
248 memcpy(dst, src, sizeof(COLORV)*dnc);
249 return; /* same spectral sampling */
250 }
251 memset(dst, 0, sizeof(COLORV)*dnc);
252 /* set starting positions */
253 if ((sdir>0 ? swl0 : swl1) <= dwl0) {
254 if (sdir > 0) {
255 wl = swl0;
256 ssi = 0;
257 } else {
258 wl = swl1;
259 ssi = snc-1;
260 }
261 si = 0;
262 di = (wl - dwl0)*rdstp;
263 } else {
264 wl = dwl0;
265 si = (wl - swl0)/sstp;
266 ssi = sdir > 0 ? si : snc-1 - si;
267 di = 0;
268 }
269 swl0 += (sdir < 0)*sstp;
270 /* step through intervals */
271 while ((si < snc) & (di < dnc)) {
272 double intvl;
273 if (swl0 + (ssi+sdir)*sstp < dwl0 + (di+1)*dstp) {
274 intvl = dwl0 + (di+1)*dstp - wl;
275 dst[di++] += src[ssi]*intvl*rdstp;
276 } else {
277 intvl = swl0 + (ssi+sdir)*sstp - wl;
278 dst[di] += src[ssi]*intvl*rdstp;
279 ssi += sdir;
280 si++;
281 }
282 wl += intvl;
283 }
284 }
285
286
287 void *
288 tempbuffer( /* get a temporary buffer */
289 size_t len
290 )
291 {
292 static void *tempbuf = NULL;
293 static size_t tempbuflen = 0;
294
295 if (!len) { /* call to free */
296 if (tempbuflen) {
297 free(tempbuf);
298 tempbuf = NULL;
299 tempbuflen = 0;
300 }
301 return(NULL);
302 }
303 if (len <= tempbuflen) /* big enough already? */
304 return(tempbuf);
305 /* else free & reallocate */
306 if (tempbuflen)
307 free(tempbuf);
308 tempbuf = malloc(len);
309 tempbuflen = len*(tempbuf != NULL);
310 return(tempbuf);
311 }
312
313
314 int
315 fwritecolrs( /* write out a colr scanline */
316 COLR *scanline,
317 int len,
318 FILE *fp
319 )
320 {
321 int i, j, beg, cnt = 1;
322 int c2;
323
324 if ((len < MINELEN) | (len > MAXELEN)) /* OOBs, write out flat */
325 return(fwrite((char *)scanline,sizeof(COLR),len,fp) - len);
326 /* put magic header */
327 putc(2, fp);
328 putc(2, fp);
329 putc(len>>8, fp);
330 putc(len&0xff, fp);
331 /* put components seperately */
332 for (i = 0; i < 4; i++) {
333 for (j = 0; j < len; j += cnt) { /* find next run */
334 for (beg = j; beg < len; beg += cnt) {
335 for (cnt = 1; (cnt < 127) & (beg+cnt < len) &&
336 scanline[beg+cnt][i] == scanline[beg][i]; cnt++)
337 ;
338 if (cnt >= MINRUN)
339 break; /* long enough */
340 }
341 if ((beg-j > 1) & (beg-j < MINRUN)) {
342 c2 = j+1;
343 while (scanline[c2++][i] == scanline[j][i])
344 if (c2 == beg) { /* short run */
345 putc(128+beg-j, fp);
346 putc(scanline[j][i], fp);
347 j = beg;
348 break;
349 }
350 }
351 while (j < beg) { /* write out non-run */
352 if ((c2 = beg-j) > 128) c2 = 128;
353 putc(c2, fp);
354 while (c2--)
355 putc(scanline[j++][i], fp);
356 }
357 if (cnt >= MINRUN) { /* write out run */
358 putc(128+cnt, fp);
359 putc(scanline[beg][i], fp);
360 } else
361 cnt = 0;
362 }
363 }
364 return(ferror(fp) ? -1 : 0);
365 }
366
367 /*
368 * An old-format scanline is either a stream of valid RGBE or XYZE real
369 * pixels or at least one real pixel followed by some number of
370 * invalid real pixels of the form (1,1,1,n), where n is a count.
371 * These can themselves be repeated to create a multibyte repeat
372 * count, with the least significant byte first (little-endian order.)
373 * Repeat counts are limited by the size of an int; if a repetition
374 * leads to an overrun, the rest of the the repetition will be
375 * silently ignored.
376 */
377 static int
378 oldreadcolrs( /* read in an old-style colr scanline */
379 COLR *scanline,
380 int len,
381 FILE *fp
382 )
383 {
384 int rshift = 0;
385 int i;
386
387 while (len > 0) {
388 scanline[0][RED] = getc(fp);
389 scanline[0][GRN] = getc(fp);
390 scanline[0][BLU] = getc(fp);
391 scanline[0][EXP] = i = getc(fp);
392 if (i == EOF)
393 return(-1);
394 if (scanline[0][GRN] == 1 &&
395 (scanline[0][RED] == 1) &
396 (scanline[0][BLU] == 1)) {
397 i = scanline[0][EXP] << rshift;
398 while (i--) {
399 copycolr(scanline[0], scanline[-1]);
400 if (--len <= 0)
401 return(0);
402 scanline++;
403 }
404 rshift += 8;
405 } else {
406 scanline++;
407 len--;
408 rshift = 0;
409 }
410 }
411 return(0);
412 }
413
414 /*
415 * There are two scanline formats: old and new. The old format
416 * compresses runs of RGBE or XYZE four-byte real pixels; the new
417 * format breaks the pixels into R, G, B, and E lines (or XYZE lines)
418 * which are individually run-length encoded.
419 *
420 * An old-format scanline always begins with a valid real pixel; at
421 * least one of the RGB (or XYZ) values will have its high-order bit
422 * set. A new-format scanline begins with four bytes which are not a
423 * valid real pixel: (2, 2, lenhigh, lenlow) where lenhigh is always
424 * less than 128 and hence never has a high-order bit set.
425 *
426 * A new-format scanline is broken into its RGBE or XYZE components.
427 * Each is output and run-length encoded separately so that a scanline
428 * is broken into four records. In turn, each record is organized
429 * into chunks of up to 128 characters, which begin with a count byte.
430 * If the count byte is greater than 128, the following data byte is
431 * repeated (count-128) times. If not, the count byte is followed by
432 * that many data bytes.
433 */
434 int
435 freadcolrs( /* read in an encoded colr scanline */
436 COLR *scanline,
437 int len,
438 FILE *fp
439 )
440 {
441 int i, j;
442 int code, val;
443 /* determine scanline type */
444 if (len <= 0)
445 return(0);
446 if ((i = getc(fp)) == EOF)
447 return(-1);
448 scanline[0][RED] = i;
449 scanline[0][GRN] = getc(fp);
450 scanline[0][BLU] = getc(fp);
451 if ((i = getc(fp)) == EOF)
452 return(-1);
453 if ((scanline[0][RED] != 2) | (scanline[0][GRN] != 2) |
454 (scanline[0][BLU] & 0x80)) {
455 scanline[0][EXP] = i;
456 return(oldreadcolrs(scanline+1, len-1, fp));
457 }
458 if ((scanline[0][BLU]<<8 | i) != len)
459 return(-1); /* length mismatch! */
460 /* read each component */
461 for (i = 0; i < 4; i++)
462 for (j = 0; j < len; ) {
463 if ((code = getc(fp)) == EOF)
464 return(-1);
465 if (code > 128) { /* run */
466 code &= 127;
467 if ((val = getc(fp)) == EOF)
468 return -1;
469 if (j + code > len)
470 return -1; /* overrun */
471 while (code--)
472 scanline[j++][i] = val;
473 } else { /* non-run */
474 if (j + code > len)
475 return -1; /* overrun */
476 while (code--) {
477 if ((val = getc(fp)) == EOF)
478 return -1;
479 scanline[j++][i] = val;
480 }
481 }
482 }
483 return(0);
484 }
485
486
487 int
488 fwritescan( /* write out a scanline */
489 COLOR *scanline,
490 int len,
491 FILE *fp
492 )
493 {
494 COLR *clrscan;
495 int n;
496 COLR *sp;
497 /* get scanline buffer */
498 if ((sp = (COLR *)tempbuffer(len*sizeof(COLR))) == NULL)
499 return(-1);
500 clrscan = sp;
501 /* convert scanline */
502 n = len;
503 while (n-- > 0) {
504 setcolr(sp[0], scanline[0][RED],
505 scanline[0][GRN],
506 scanline[0][BLU]);
507 scanline++;
508 sp++;
509 }
510 return(fwritecolrs(clrscan, len, fp));
511 }
512
513
514 int
515 freadscan( /* read in a scanline */
516 COLOR *scanline,
517 int len,
518 FILE *fp
519 )
520 {
521 COLR *clrscan;
522
523 if ((clrscan = (COLR *)tempbuffer(len*sizeof(COLR))) == NULL)
524 return(-1);
525 if (freadcolrs(clrscan, len, fp) < 0)
526 return(-1);
527 /* convert scanline */
528 colr_color(scanline[0], clrscan[0]);
529 while (--len > 0) {
530 scanline++; clrscan++;
531 if (clrscan[0][GRN] == clrscan[-1][GRN] &&
532 (clrscan[0][RED] == clrscan[-1][RED]) &
533 (clrscan[0][BLU] == clrscan[-1][BLU]) &
534 (clrscan[0][EXP] == clrscan[-1][EXP]))
535 copycolor(scanline[0], scanline[-1]);
536 else
537 colr_color(scanline[0], clrscan[0]);
538 }
539 return(0);
540 }
541
542
543 void
544 setcolr( /* assign a short color value */
545 COLR clr,
546 double r,
547 double g,
548 double b
549 )
550 {
551 double d;
552 int e;
553
554 d = r > g ? r : g;
555 if (b > d) d = b;
556
557 if (d <= 1e-32) {
558 clr[RED] = clr[GRN] = clr[BLU] = 0;
559 clr[EXP] = 0;
560 return;
561 }
562
563 d = frexp(d, &e) * 256.0 / d;
564
565 clr[RED] = (r > 0) * (int)(r*d);
566 clr[GRN] = (g > 0) * (int)(g*d);
567 clr[BLU] = (b > 0) * (int)(b*d);
568 clr[EXP] = e + COLXS;
569 }
570
571
572 void
573 colr_color( /* convert short to float color */
574 COLOR col,
575 COLR clr
576 )
577 {
578 double f;
579
580 if (clr[EXP] == 0) {
581 col[RED] = col[GRN] = col[BLU] = 0.0;
582 return;
583 }
584 f = ldexp(1.0, (int)clr[EXP]-(COLXS+8));
585 col[RED] = (clr[RED] + 0.5)*f;
586 col[GRN] = (clr[GRN] + 0.5)*f;
587 col[BLU] = (clr[BLU] + 0.5)*f;
588 }
589
590
591 int
592 bigdiff( /* c1 delta c2 > md? */
593 COLOR c1,
594 COLOR c2,
595 double md
596 )
597 {
598 int i;
599
600 for (i = 0; i < 3; i++)
601 if ((colval(c1,i)-colval(c2,i) > md*colval(c2,i)) |
602 (colval(c2,i)-colval(c1,i) > md*colval(c1,i)))
603 return(1);
604 return(0);
605 }
606
607
608 int
609 sbigsdiff( /* sc1 delta sc2 > md? */
610 SCOLOR c1,
611 SCOLOR c2,
612 double md
613 )
614 {
615 int i = NCSAMP;
616
617 while (i--)
618 if ((c1[i]-c2[i] > md*c2[i]) | (c2[i]-c1[i] > md*c1[i]))
619 return(1);
620 return(0);
621 }
