1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: color.c,v 2.24 2023/06/30 00:58:47 greg Exp $"; |
3 |
#endif |
4 |
5 |
* color.c - routines for color calculations. |
6 |
7 |
* Externals declared in color.h |
8 |
9 |
10 |
#include "copyright.h" |
11 |
12 |
#include <stdio.h> |
13 |
#include <stdlib.h> |
14 |
#include <math.h> |
15 |
#include "color.h" |
16 |
17 |
#ifdef getc_unlocked /* avoid horrendous overhead of flockfile */ |
18 |
#undef getc |
19 |
#undef putc |
20 |
#undef ferror |
21 |
#define getc getc_unlocked |
22 |
#define putc putc_unlocked |
23 |
#define ferror ferror_unlocked |
24 |
#endif |
25 |
26 |
#define MINELEN 8 /* minimum scanline length for encoding */ |
27 |
#define MAXELEN 0x7fff /* maximum scanline length for encoding */ |
28 |
#define MINRUN 4 /* minimum run length */ |
29 |
30 |
31 |
void * |
32 |
tempbuffer( /* get a temporary buffer */ |
33 |
unsigned int len |
34 |
35 |
36 |
static void *tempbuf = NULL; |
37 |
static unsigned int tempbuflen = 0; |
38 |
39 |
if (!len) { /* call to free */ |
40 |
if (tempbuflen) { |
41 |
free(tempbuf); |
42 |
tempbuf = NULL; |
43 |
tempbuflen = 0; |
44 |
45 |
return(NULL); |
46 |
47 |
if (len <= tempbuflen) /* big enough already? */ |
48 |
return(tempbuf); |
49 |
/* else free & reallocate */ |
50 |
if (tempbuflen) |
51 |
free(tempbuf); |
52 |
tempbuf = malloc(len); |
53 |
tempbuflen = len*(tempbuf != NULL); |
54 |
return(tempbuf); |
55 |
56 |
57 |
58 |
int |
59 |
fwritecolrs( /* write out a colr scanline */ |
60 |
COLR *scanline, |
61 |
int len, |
62 |
FILE *fp |
63 |
64 |
65 |
int i, j, beg, cnt = 1; |
66 |
int c2; |
67 |
68 |
if ((len < MINELEN) | (len > MAXELEN)) /* OOBs, write out flat */ |
69 |
return(fwrite((char *)scanline,sizeof(COLR),len,fp) - len); |
70 |
/* put magic header */ |
71 |
putc(2, fp); |
72 |
putc(2, fp); |
73 |
putc(len>>8, fp); |
74 |
putc(len&0xff, fp); |
75 |
/* put components seperately */ |
76 |
for (i = 0; i < 4; i++) { |
77 |
for (j = 0; j < len; j += cnt) { /* find next run */ |
78 |
for (beg = j; beg < len; beg += cnt) { |
79 |
for (cnt = 1; (cnt < 127) & (beg+cnt < len) && |
80 |
scanline[beg+cnt][i] == scanline[beg][i]; cnt++) |
81 |
82 |
if (cnt >= MINRUN) |
83 |
break; /* long enough */ |
84 |
85 |
if ((beg-j > 1) & (beg-j < MINRUN)) { |
86 |
c2 = j+1; |
87 |
while (scanline[c2++][i] == scanline[j][i]) |
88 |
if (c2 == beg) { /* short run */ |
89 |
putc(128+beg-j, fp); |
90 |
putc(scanline[j][i], fp); |
91 |
j = beg; |
92 |
break; |
93 |
94 |
95 |
while (j < beg) { /* write out non-run */ |
96 |
if ((c2 = beg-j) > 128) c2 = 128; |
97 |
putc(c2, fp); |
98 |
while (c2--) |
99 |
putc(scanline[j++][i], fp); |
100 |
101 |
if (cnt >= MINRUN) { /* write out run */ |
102 |
putc(128+cnt, fp); |
103 |
putc(scanline[beg][i], fp); |
104 |
} else |
105 |
cnt = 0; |
106 |
107 |
108 |
return(ferror(fp) ? -1 : 0); |
109 |
110 |
111 |
112 |
* An old-format scanline is either a stream of valid RGBE or XYZE real |
113 |
* pixels or at least one real pixel followed by some number of |
114 |
* invalid real pixels of the form (1,1,1,n), where n is a count. |
115 |
* These can themselves be repeated to create a multibyte repeat |
116 |
* count, with the least significant byte first (little-endian order.) |
117 |
* Repeat counts are limited by the size of an int; if a repetition |
118 |
* leads to an overrun, the rest of the the repetition will be |
119 |
* silently ignored. |
120 |
121 |
static int |
122 |
oldreadcolrs( /* read in an old-style colr scanline */ |
123 |
COLR *scanline, |
124 |
int len, |
125 |
FILE *fp |
126 |
127 |
128 |
int rshift = 0; |
129 |
int i; |
130 |
131 |
while (len > 0) { |
132 |
scanline[0][RED] = getc(fp); |
133 |
scanline[0][GRN] = getc(fp); |
134 |
scanline[0][BLU] = getc(fp); |
135 |
scanline[0][EXP] = i = getc(fp); |
136 |
if (i == EOF) |
137 |
return(-1); |
138 |
if (scanline[0][GRN] == 1 && |
139 |
(scanline[0][RED] == 1) & |
140 |
(scanline[0][BLU] == 1)) { |
141 |
i = scanline[0][EXP] << rshift; |
142 |
while (i--) { |
143 |
copycolr(scanline[0], scanline[-1]); |
144 |
if (--len <= 0) |
145 |
return(0); |
146 |
scanline++; |
147 |
148 |
rshift += 8; |
149 |
} else { |
150 |
scanline++; |
151 |
len--; |
152 |
rshift = 0; |
153 |
154 |
155 |
return(0); |
156 |
157 |
158 |
159 |
* There are two scanline formats: old and new. The old format |
160 |
* compresses runs of RGBE or XYZE four-byte real pixels; the new |
161 |
* format breaks the pixels into R, G, B, and E lines (or XYZE lines) |
162 |
* which are individually run-length encoded. |
163 |
164 |
* An old-format scanline always begins with a valid real pixel; at |
165 |
* least one of the RGB (or XYZ) values will have its high-order bit |
166 |
* set. A new-format scanline begins with four bytes which are not a |
167 |
* valid real pixel: (2, 2, lenhigh, lenlow) where lenhigh is always |
168 |
* less than 128 and hence never has a high-order bit set. |
169 |
170 |
* A new-format scanline is broken into its RGBE or XYZE components. |
171 |
* Each is output and run-length encoded separately so that a scanline |
172 |
* is broken into four records. In turn, each record is organized |
173 |
* into chunks of up to 128 characters, which begin with a count byte. |
174 |
* If the count byte is greater than 128, the following data byte is |
175 |
* repeated (count-128) times. If not, the count byte is followed by |
176 |
* that many data bytes. |
177 |
178 |
int |
179 |
freadcolrs( /* read in an encoded colr scanline */ |
180 |
COLR *scanline, |
181 |
int len, |
182 |
FILE *fp |
183 |
184 |
185 |
int i, j; |
186 |
int code, val; |
187 |
/* determine scanline type */ |
188 |
if ((len < MINELEN) | (len > MAXELEN)) |
189 |
return(oldreadcolrs(scanline, len, fp)); |
190 |
if ((i = getc(fp)) == EOF) |
191 |
return(-1); |
192 |
if (i != 2) { |
193 |
ungetc(i, fp); |
194 |
195 |
196 |
197 |
198 |
199 |
return(-1); |
200 |
if ((scanline[0][GRN] != 2) | ((scanline[0][BLU] & 0x80) != 0)) { |
201 |
scanline[0][RED] = 2; |
202 |
scanline[0][EXP] = i; |
203 |
return(oldreadcolrs(scanline+1, len-1, fp)); |
204 |
205 |
if ((scanline[0][BLU]<<8 | i) != len) |
206 |
return(-1); /* length mismatch! */ |
207 |
/* read each component */ |
208 |
for (i = 0; i < 4; i++) |
209 |
for (j = 0; j < len; ) { |
210 |
if ((code = getc(fp)) == EOF) |
211 |
return(-1); |
212 |
if (code > 128) { /* run */ |
213 |
code &= 127; |
214 |
if ((val = getc(fp)) == EOF) |
215 |
return -1; |
216 |
if (j + code > len) |
217 |
return -1; /* overrun */ |
218 |
while (code--) |
219 |
scanline[j++][i] = val; |
220 |
} else { /* non-run */ |
221 |
222 |
223 |
while (code--) { |
224 |
225 |
return -1; |
226 |
227 |
228 |
229 |
230 |
return(0); |
231 |
232 |
233 |
234 |
int |
235 |
fwritescan( /* write out a scanline */ |
236 |
COLOR *scanline, |
237 |
int len, |
238 |
FILE *fp |
239 |
240 |
241 |
COLR *clrscan; |
242 |
int n; |
243 |
COLR *sp; |
244 |
/* get scanline buffer */ |
245 |
if ((sp = (COLR *)tempbuffer(len*sizeof(COLR))) == NULL) |
246 |
return(-1); |
247 |
clrscan = sp; |
248 |
/* convert scanline */ |
249 |
n = len; |
250 |
while (n-- > 0) { |
251 |
setcolr(sp[0], scanline[0][RED], |
252 |
scanline[0][GRN], |
253 |
scanline[0][BLU]); |
254 |
scanline++; |
255 |
sp++; |
256 |
257 |
return(fwritecolrs(clrscan, len, fp)); |
258 |
259 |
260 |
261 |
int |
262 |
freadscan( /* read in a scanline */ |
263 |
COLOR *scanline, |
264 |
int len, |
265 |
FILE *fp |
266 |
267 |
268 |
COLR *clrscan; |
269 |
270 |
if ((clrscan = (COLR *)tempbuffer(len*sizeof(COLR))) == NULL) |
271 |
return(-1); |
272 |
if (freadcolrs(clrscan, len, fp) < 0) |
273 |
return(-1); |
274 |
275 |
colr_color(scanline[0], clrscan[0]); |
276 |
while (--len > 0) { |
277 |
scanline++; clrscan++; |
278 |
if (clrscan[0][GRN] == clrscan[-1][GRN] && |
279 |
(clrscan[0][RED] == clrscan[-1][RED]) & |
280 |
(clrscan[0][BLU] == clrscan[-1][BLU]) & |
281 |
(clrscan[0][EXP] == clrscan[-1][EXP])) |
282 |
copycolor(scanline[0], scanline[-1]); |
283 |
else |
284 |
285 |
286 |
return(0); |
287 |
288 |
289 |
290 |
void |
291 |
setcolr( /* assign a short color value */ |
292 |
COLR clr, |
293 |
double r, |
294 |
double g, |
295 |
double b |
296 |
297 |
298 |
double d; |
299 |
int e; |
300 |
301 |
d = r > g ? r : g; |
302 |
if (b > d) d = b; |
303 |
304 |
if (d <= 1e-32) { |
305 |
clr[RED] = clr[GRN] = clr[BLU] = 0; |
306 |
clr[EXP] = 0; |
307 |
return; |
308 |
309 |
310 |
d = frexp(d, &e) * 256.0 / d; |
311 |
312 |
if (r > 0.0) |
313 |
clr[RED] = r * d; |
314 |
else |
315 |
clr[RED] = 0; |
316 |
if (g > 0.0) |
317 |
clr[GRN] = g * d; |
318 |
else |
319 |
clr[GRN] = 0; |
320 |
if (b > 0.0) |
321 |
clr[BLU] = b * d; |
322 |
else |
323 |
clr[BLU] = 0; |
324 |
325 |
clr[EXP] = e + COLXS; |
326 |
327 |
328 |
329 |
void |
330 |
colr_color( /* convert short to float color */ |
331 |
COLOR col, |
332 |
COLR clr |
333 |
334 |
335 |
double f; |
336 |
337 |
if (clr[EXP] == 0) |
338 |
col[RED] = col[GRN] = col[BLU] = 0.0; |
339 |
else { |
340 |
f = ldexp(1.0, (int)clr[EXP]-(COLXS+8)); |
341 |
col[RED] = (clr[RED] + 0.5)*f; |
342 |
col[GRN] = (clr[GRN] + 0.5)*f; |
343 |
col[BLU] = (clr[BLU] + 0.5)*f; |
344 |
345 |
346 |
347 |
348 |
int |
349 |
bigdiff( /* c1 delta c2 > md? */ |
350 |
COLOR c1, |
351 |
COLOR c2, |
352 |
double md |
353 |
354 |
355 |
int i; |
356 |
357 |
for (i = 0; i < 3; i++) |
358 |
if (colval(c1,i)-colval(c2,i) > md*colval(c2,i) || |
359 |
colval(c2,i)-colval(c1,i) > md*colval(c1,i)) |
360 |
return(1); |
361 |
return(0); |
362 |
