root/radiance/ray/src/common/color.c
Revision: 2.18
Committed: Tue Apr 10 23:38:40 2018 UTC (6 years, 2 months ago) by greg
Changes since 2.17: +5 -6 lines
Made reading uncompressed scanlines a bit faster
2 static const char RCSid[] = "$Id: color.c,v 2.17 2014/05/31 20:13:31 greg Exp $";
5 * color.c - routines for color calculations.
6 *
7 * Externals declared in color.h
8 */
9
10 #include "copyright.h"
11
12 #include <stdio.h>
13 #include <stdlib.h>
14 #include <math.h>
15 #include "color.h"
16
17 #ifdef getc_unlocked /* avoid horrendous overhead of flockfile */
18 #undef getc
19 #undef putc
20 #define getc getc_unlocked
21 #define putc putc_unlocked
22 #define ferror ferror_unlocked
23 #endif
24
25 #define MINELEN 8 /* minimum scanline length for encoding */
26 #define MAXELEN 0x7fff /* maximum scanline length for encoding */
27 #define MINRUN 4 /* minimum run length */
28
29
30 char *
31 tempbuffer( /* get a temporary buffer */
32 unsigned int len
33 )
34 {
35 static char *tempbuf = NULL;
36 static unsigned tempbuflen = 0;
37
38 if (len > tempbuflen) {
39 if (tempbuflen > 0)
40 tempbuf = (char *)realloc((void *)tempbuf, len);
41 else
42 tempbuf = (char *)malloc(len);
43 tempbuflen = tempbuf==NULL ? 0 : len;
44 }
45 return(tempbuf);
46 }
47
48
49 int
50 fwritecolrs( /* write out a colr scanline */
51 COLR *scanline,
52 int len,
53 FILE *fp
54 )
55 {
56 int i, j, beg, cnt = 1;
57 int c2;
58
59 if ((len < MINELEN) | (len > MAXELEN)) /* OOBs, write out flat */
60 return(fwrite((char *)scanline,sizeof(COLR),len,fp) - len);
61 /* put magic header */
62 putc(2, fp);
63 putc(2, fp);
64 putc(len>>8, fp);
65 putc(len&255, fp);
66 /* put components seperately */
67 for (i = 0; i < 4; i++) {
68 for (j = 0; j < len; j += cnt) { /* find next run */
69 for (beg = j; beg < len; beg += cnt) {
70 for (cnt = 1; cnt < 127 && beg+cnt < len &&
71 scanline[beg+cnt][i] == scanline[beg][i]; cnt++)
72 ;
73 if (cnt >= MINRUN)
74 break; /* long enough */
75 }
76 if (beg-j > 1 && beg-j < MINRUN) {
77 c2 = j+1;
78 while (scanline[c2++][i] == scanline[j][i])
79 if (c2 == beg) { /* short run */
80 putc(128+beg-j, fp);
81 putc(scanline[j][i], fp);
82 j = beg;
83 break;
84 }
85 }
86 while (j < beg) { /* write out non-run */
87 if ((c2 = beg-j) > 128) c2 = 128;
88 putc(c2, fp);
89 while (c2--)
90 putc(scanline[j++][i], fp);
91 }
92 if (cnt >= MINRUN) { /* write out run */
93 putc(128+cnt, fp);
94 putc(scanline[beg][i], fp);
95 } else
96 cnt = 0;
97 }
98 }
99 return(ferror(fp) ? -1 : 0);
100 }
101
102
103 static int
104 oldreadcolrs( /* read in an old colr scanline */
105 COLR *scanline,
106 int len,
107 FILE *fp
108 )
109 {
110 int rshift = 0;
111 int i;
112
113 while (len > 0) {
114 scanline[0][RED] = getc(fp);
115 scanline[0][GRN] = getc(fp);
116 scanline[0][BLU] = getc(fp);
117 scanline[0][EXP] = i = getc(fp);
118 if (i == EOF)
119 return(-1);
120 if (scanline[0][RED] == 1 &&
121 scanline[0][GRN] == 1 &&
122 scanline[0][BLU] == 1) {
123 for (i = scanline[0][EXP] << rshift; i > 0; i--) {
124 copycolr(scanline[0], scanline[-1]);
125 scanline++;
126 len--;
127 }
128 rshift += 8;
129 } else {
130 scanline++;
131 len--;
132 rshift = 0;
133 }
134 }
135 return(0);
136 }
137
138
139 int
140 freadcolrs( /* read in an encoded colr scanline */
141 COLR *scanline,
142 int len,
143 FILE *fp
144 )
145 {
146 int i, j;
147 int code, val;
148 /* determine scanline type */
149 if ((len < MINELEN) | (len > MAXELEN))
150 return(oldreadcolrs(scanline, len, fp));
151 if ((i = getc(fp)) == EOF)
152 return(-1);
153 if (i != 2) {
154 ungetc(i, fp);
155 return(oldreadcolrs(scanline, len, fp));
156 }
157 scanline[0][GRN] = getc(fp);
158 scanline[0][BLU] = getc(fp);
159 if ((i = getc(fp)) == EOF)
160 return(-1);
161 if (scanline[0][GRN] != 2 || scanline[0][BLU] & 128) {
162 scanline[0][RED] = 2;
163 scanline[0][EXP] = i;
164 return(oldreadcolrs(scanline+1, len-1, fp));
165 }
166 if ((scanline[0][BLU]<<8 | i) != len)
167 return(-1); /* length mismatch! */
168 /* read each component */
169 for (i = 0; i < 4; i++)
170 for (j = 0; j < len; ) {
171 if ((code = getc(fp)) == EOF)
172 return(-1);
173 if (code > 128) { /* run */
174 code &= 127;
175 if ((val = getc(fp)) == EOF)
176 return -1;
177 if (j + code > len)
178 return -1; /* overrun */
179 while (code--)
180 scanline[j++][i] = val;
181 } else { /* non-run */
182 if (j + code > len)
183 return -1; /* overrun */
184 while (code--) {
185 if ((val = getc(fp)) == EOF)
186 return -1;
187 scanline[j++][i] = val;
188 }
189 }
190 }
191 return(0);
192 }
193
194
195 int
196 fwritescan( /* write out a scanline */
197 COLOR *scanline,
198 int len,
199 FILE *fp
200 )
201 {
202 COLR *clrscan;
203 int n;
204 COLR *sp;
205 /* get scanline buffer */
206 if ((sp = (COLR *)tempbuffer(len*sizeof(COLR))) == NULL)
207 return(-1);
208 clrscan = sp;
209 /* convert scanline */
210 n = len;
211 while (n-- > 0) {
212 setcolr(sp[0], scanline[0][RED],
213 scanline[0][GRN],
214 scanline[0][BLU]);
215 scanline++;
216 sp++;
217 }
218 return(fwritecolrs(clrscan, len, fp));
219 }
220
221
222 int
223 freadscan( /* read in a scanline */
224 COLOR *scanline,
225 int len,
226 FILE *fp
227 )
228 {
229 COLR *clrscan;
230
231 if ((clrscan = (COLR *)tempbuffer(len*sizeof(COLR))) == NULL)
232 return(-1);
233 if (freadcolrs(clrscan, len, fp) < 0)
234 return(-1);
235 /* convert scanline */
236 colr_color(scanline[0], clrscan[0]);
237 while (--len > 0) {
238 scanline++; clrscan++;
239 if (clrscan[0][RED] == clrscan[-1][RED] &&
240 clrscan[0][GRN] == clrscan[-1][GRN] &&
241 clrscan[0][BLU] == clrscan[-1][BLU] &&
242 clrscan[0][EXP] == clrscan[-1][EXP])
243 copycolor(scanline[0], scanline[-1]);
244 else
245 colr_color(scanline[0], clrscan[0]);
246 }
247 return(0);
248 }
249
250
251 void
252 setcolr( /* assign a short color value */
253 COLR clr,
254 double r,
255 double g,
256 double b
257 )
258 {
259 double d;
260 int e;
261
262 d = r > g ? r : g;
263 if (b > d) d = b;
264
265 if (d <= 1e-32) {
266 clr[RED] = clr[GRN] = clr[BLU] = 0;
267 clr[EXP] = 0;
268 return;
269 }
270
271 d = frexp(d, &e) * 255.9999 / d;
272
273 if (r > 0.0)
274 clr[RED] = r * d;
275 else
276 clr[RED] = 0;
277 if (g > 0.0)
278 clr[GRN] = g * d;
279 else
280 clr[GRN] = 0;
281 if (b > 0.0)
282 clr[BLU] = b * d;
283 else
284 clr[BLU] = 0;
285
286 clr[EXP] = e + COLXS;
287 }
288
289
290 void
291 colr_color( /* convert short to float color */
292 COLOR col,
293 COLR clr
294 )
295 {
296 double f;
297
298 if (clr[EXP] == 0)
299 col[RED] = col[GRN] = col[BLU] = 0.0;
300 else {
301 f = ldexp(1.0, (int)clr[EXP]-(COLXS+8));
302 col[RED] = (clr[RED] + 0.5)*f;
303 col[GRN] = (clr[GRN] + 0.5)*f;
304 col[BLU] = (clr[BLU] + 0.5)*f;
305 }
306 }
307
308
309 int
310 bigdiff( /* c1 delta c2 > md? */
311 COLOR c1,
312 COLOR c2,
313 double md
314 )
315 {
316 int i;
317
318 for (i = 0; i < 3; i++)
319 if (colval(c1,i)-colval(c2,i) > md*colval(c2,i) ||
320 colval(c2,i)-colval(c1,i) > md*colval(c1,i))
321 return(1);
322 return(0);
323 }
