1 |
/* clntrpc.h Distribution 1.0 88/9/19 Scry */ |
2 |
3 |
/* The Scry system is copyright (C) 1988, Regents of the |
4 |
University of California. Anyone may reproduce ``Scry'', |
5 |
the software in this distribution, in whole or in part, pro- |
6 |
vided that: |
7 |
8 |
(1) Any copy or redistribution of Scry must show the |
9 |
Regents of the University of California, through its |
10 |
Lawrence Berkeley Laboratory, as the source, and must |
11 |
include this notice; |
12 |
13 |
(2) Any use of this software must reference this distribu- |
14 |
tion, state that the software copyright is held by the |
15 |
Regents of the University of California, and that the |
16 |
software is used by their permission. |
17 |
18 |
It is acknowledged that the U.S. Government has rights |
19 |
in Scry under Contract DE-AC03-765F00098 between the U.S. |
20 |
Department of Energy and the University of California. |
21 |
22 |
Scry is provided as a professional academic contribu- |
23 |
tion for joint exchange. Thus it is experimental, is pro- |
24 |
vided ``as is'', with no warranties of any kind whatsoever, |
25 |
no support, promise of updates, or printed documentation. |
26 |
The Regents of the University of California shall have no |
27 |
liability with respect to the infringement of copyrights by |
28 |
Scry, or any part thereof. */ |
29 |
30 |
31 |
#include <netdb.h> |
32 |
#ifdef CRAY |
33 |
#include <rpc/types.h> |
34 |
#include "in.h" /* YUCK */ |
35 |
#include <sys/socket.h> |
36 |
#include <rpc/xdr.h> |
37 |
#include <rpc/auth.h> |
38 |
#include <rpc/clnt.h> |
39 |
#include <rpc/rpc_msg.h> |
40 |
#include <rpc/auth_unix.h> |
41 |
#include <rpc/svc.h> |
42 |
#include <rpc/svc_auth.h> |
43 |
#else |
44 |
#include <rpc/rpc.h> |
45 |
46 |
#endif |
47 |
#include <sys/time.h> |
48 |
49 |
#define SUNFRONT /* Sun is client */ |
50 |
51 |
#define PCPROGRAM 300000 |
52 |
#define PCPORT 2000 |
53 |
#define TESTVERS 1 /* version */ |
54 |
55 |
/* remote procedure numbers */ |
56 |
57 |
#define AUTHPROC 1 /* authorization procedure */ |
58 |
#define INITPROC 2 /* initialize VTR or videodisk */ |
59 |
#define RECORDPROC 3 /* record frame */ |
60 |
#define CLOSEPROC 4 /* relinquish control */ |
61 |
#define NOCOMPRESS 5 /* send uncompressed image data */ |
62 |
#define COLORSEND 6 /* send and display colormap-compressed scan lines */ |
63 |
#define SENDUDP 7 /* send BTC and colormap-compressed scan lines */ |
64 |
#define DISPLAY 8 /* display BTC and colormap-compressed scan lines */ |
65 |
#define MAPPROC 9 /* send color map */ |
66 |
67 |
/* give up after certain amount of time */ |
68 |
extern struct timeval s_total_timeout ; |
69 |
/* client handle */ |
70 |
extern CLIENT *s_client ; |
71 |
72 |
#define UDP 0 /* UDP protocol */ |
73 |
#define TCP 1 /* TCP protocol */ |
74 |
75 |
extern short s_protocol ; /* which protocol */ |
76 |
77 |
#define PREVIEW 0 /* preview mode */ |
78 |
79 |
extern int s_curr_frame ; /* current frame number */ |
80 |
extern int s_copy_num ; /* number of frames to record image on */ |
81 |
extern int s_record ; /* preview or record */ |
82 |
extern bool_t s_optflag ; /* video workstation has optical disk */ |
83 |
extern bool_t s_lempel_ziv ; /* use Lempel-Ziv compression or not */ |
84 |
85 |
struct netuser /* user description structure */ |
86 |
87 |
int nu_uid ; /* effective user id */ |
88 |
unsigned int nu_glen ; /* number of groups user in */ |
89 |
int *nu_gids ; /* groups user is in */ |
90 |
91 |
92 |
struct record |
93 |
94 |
int in_at ; /* start recording image at */ |
95 |
int out_at ; /* finish recording image at */ |
96 |
97 |
98 |
struct recinfo |
99 |
100 |
bool_t optflag ; |
101 |
int start_frame ; |
102 |
int total ; |
103 |
104 |
105 |
#define NONE 0 /* no compression */ |
106 |
#define BTC 1 /* BTC compression */ |
107 |
#define COLORMAP 2 /* color map compression */ |
108 |
#define LEMPEL_ZIV 4 /* Lempel-Ziv compression */ |
109 |
#define FRAME_FRAME 8 /* frame-to-frame differencing */ |
110 |
111 |
extern short s_compression ; /* type of compression */ |
112 |
113 |
struct mapstore |
114 |
115 |
short mapnum ; /* number of entries in color map */ |
116 |
unsigned short map[256] ; /* entries in color map */ |
117 |
118 |
119 |
120 |
struct scan_packet |
121 |
122 |
bool_t first ; /* first frame - no frame-frame differencing */ |
123 |
int record ; /* preview or record */ |
124 |
short compression ; /* type of compression */ |
125 |
int lempel_ziv ; /* Lempel-Ziv used or not */ |
126 |
short linenum ; /* scan line number (0 to 399) */ |
127 |
int index ; /* used by server as index into piece of |
128 |
incoming buffer */ |
129 |
int total1, total2 ; /* server uses in building up compressed |
130 |
frame buffer from incoming pieces */ |
131 |
/* number of bytes in compressed frame (Lempel-Ziv only) */ |
132 |
int total_lz ; |
133 |
int in_at, out_at ; /* starting, ending numbers to |
134 |
135 |
136 |
unsigned short map[256] ; /* color map */ |
137 |
short num_bytes[100] ; /* number of bytes in each group of |
138 |
4 compressed scan lines */ |
139 |
unsigned char pack[76800] ; /* compressed frame buffer or piece thereof */ |
140 |
/* 2 scan lines stored here when compression |
141 |
not used */ |
142 |
