| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id$";
| 3 |
#endif
| 4 |
| 5 |
* clip.c - routine to clip 3D line segments to a box.
| 6 |
| 7 |
| 8 |
#include "copyright.h"
| 9 |
| 10 |
#include "fvect.h"
| 11 |
| 12 |
#include "plocate.h"
| 13 |
| 14 |
#define MAXITER 6 /* maximum possible number of iterations */
| 15 |
| 16 |
| 17 |
int
| 18 |
clip(ep1, ep2, min, max) /* clip a line segment to a box */
| 19 |
FLOAT *ep1, *ep2;
| 20 |
FVECT min, max;
| 21 |
| 22 |
int itlim = MAXITER;
| 23 |
int loc1, loc2;
| 24 |
int accept;
| 25 |
FLOAT *dp;
| 26 |
double d;
| 27 |
register int i, j;
| 28 |
| 29 |
| 30 |
* The Cohen-Sutherland algorithm is used to determine
| 31 |
* what part (if any) of the given line segment is contained
| 32 |
* in the box specified by the min and max vectors.
| 33 |
* The routine returns non-zero if any segment is left.
| 34 |
| 35 |
| 36 |
loc1 = plocate(ep1, min, max);
| 37 |
loc2 = plocate(ep2, min, max);
| 38 |
| 39 |
/* check for trivial accept and reject */
| 40 |
/* trivial accept is both points inside */
| 41 |
/* trivial reject is both points to one side */
| 42 |
| 43 |
while (!((accept = !(loc1 | loc2)) || (loc1 & loc2))) {
| 44 |
| 45 |
if (itlim-- <= 0) /* past theoretical limit? */
| 46 |
return(0); /* quit fooling around */
| 47 |
| 48 |
if (!loc1) { /* make sure first point is outside */
| 49 |
dp = ep1; ep1 = ep2; ep2 = dp;
| 50 |
i = loc1; loc1 = loc2; loc2 = i;
| 51 |
| 52 |
| 53 |
for (i = 0; i < 3; i++) { /* chop segment */
| 54 |
| 55 |
if (loc1 & position(i) & BELOW) {
| 56 |
d = (min[i] - ep1[i])/(ep2[i] - ep1[i]);
| 57 |
ep1[i] = min[i];
| 58 |
} else if (loc1 & position(i) & ABOVE) {
| 59 |
d = (max[i] - ep1[i])/(ep2[i] - ep1[i]);
| 60 |
ep1[i] = max[i];
| 61 |
} else
| 62 |
continue;
| 63 |
| 64 |
for (j = 0; j < 3; j++)
| 65 |
if (j != i)
| 66 |
ep1[j] += (ep2[j] - ep1[j])*d;
| 67 |
break;
| 68 |
| 69 |
| 70 |
| 71 |
return(accept);
| 72 |
