root/Development/ray/src/common/clip.c
Revision: 2.5
Committed: Thu Jun 26 00:58:09 2003 UTC (22 years, 4 months ago) by schorsch
CVS Tags: rad6R0, rad5R4, rad5R3, rad5R2, rad5R1, rad5R0, rad4R2P2, rad4R2P1, rad4R2, rad4R1, rad4R0, rad3R9, rad3R8, rad3R7P2, rad3R7P1, rad3R6P1, rad3R6, HEAD
# User Rev Content
1 greg 1.1 #ifndef lint
2 schorsch 2.5 static const char RCSid[] = "$Id: clip.c,v 2.4 2003/02/25 02:47:21 greg Exp $";
3 greg 1.1 #endif
4     /*
5     * clip.c - routine to clip 3D line segments to a box.
6 greg 2.3 */
7
8 greg 2.4 #include "copyright.h"
9 greg 1.1
10 greg 1.2 #include "fvect.h"
11
12 greg 1.1 #include "plocate.h"
13
14 greg 2.2 #define MAXITER 6 /* maximum possible number of iterations */
15 greg 1.1
16 greg 2.2
17 greg 2.3 int
18 greg 1.1 clip(ep1, ep2, min, max) /* clip a line segment to a box */
19 schorsch 2.5 RREAL *ep1, *ep2;
20 greg 1.2 FVECT min, max;
21 greg 1.1 {
22 greg 2.2 int itlim = MAXITER;
23 greg 1.1 int loc1, loc2;
24     int accept;
25 schorsch 2.5 RREAL *dp;
26 greg 1.1 double d;
27     register int i, j;
28
29     /*
30     * The Cohen-Sutherland algorithm is used to determine
31     * what part (if any) of the given line segment is contained
32     * in the box specified by the min and max vectors.
33     * The routine returns non-zero if any segment is left.
34     */
35
36     loc1 = plocate(ep1, min, max);
37     loc2 = plocate(ep2, min, max);
38
39     /* check for trivial accept and reject */
40     /* trivial accept is both points inside */
41     /* trivial reject is both points to one side */
42
43     while (!((accept = !(loc1 | loc2)) || (loc1 & loc2))) {
44
45 greg 2.2 if (itlim-- <= 0) /* past theoretical limit? */
46     return(0); /* quit fooling around */
47
48 greg 1.1 if (!loc1) { /* make sure first point is outside */
49     dp = ep1; ep1 = ep2; ep2 = dp;
50     i = loc1; loc1 = loc2; loc2 = i;
51     }
52
53     for (i = 0; i < 3; i++) { /* chop segment */
54
55     if (loc1 & position(i) & BELOW) {
56     d = (min[i] - ep1[i])/(ep2[i] - ep1[i]);
57     ep1[i] = min[i];
58     } else if (loc1 & position(i) & ABOVE) {
59     d = (max[i] - ep1[i])/(ep2[i] - ep1[i]);
60     ep1[i] = max[i];
61     } else
62     continue;
63
64     for (j = 0; j < 3; j++)
65     if (j != i)
66     ep1[j] += (ep2[j] - ep1[j])*d;
67     break;
68     }
69     loc1 = plocate(ep1, min, max);
70     }
71     return(accept);
72     }
