root/radiance/ray/src/common/clip.c
Revision: 1.1
Committed: Thu Feb 2 10:33:01 1989 UTC (35 years, 4 months ago) by greg
1 /* Copyright (c) 1986 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * clip.c - routine to clip 3D line segments to a box.
9 *
10 * 8/28/85
11 */
12
13 #include "plocate.h"
14
15
16 clip(ep1, ep2, min, max) /* clip a line segment to a box */
17 double *ep1, *ep2;
18 double min[3], max[3];
19 {
20 int loc1, loc2;
21 int accept;
22 double *dp;
23 double d;
24 register int i, j;
25
26 /*
27 * The Cohen-Sutherland algorithm is used to determine
28 * what part (if any) of the given line segment is contained
29 * in the box specified by the min and max vectors.
30 * The routine returns non-zero if any segment is left.
31 */
32
33 loc1 = plocate(ep1, min, max);
34 loc2 = plocate(ep2, min, max);
35
36 /* check for trivial accept and reject */
37 /* trivial accept is both points inside */
38 /* trivial reject is both points to one side */
39
40 while (!((accept = !(loc1 | loc2)) || (loc1 & loc2))) {
41
42 if (!loc1) { /* make sure first point is outside */
43 dp = ep1; ep1 = ep2; ep2 = dp;
44 i = loc1; loc1 = loc2; loc2 = i;
45 }
46
47 for (i = 0; i < 3; i++) { /* chop segment */
48
49 if (loc1 & position(i) & BELOW) {
50 d = (min[i] - ep1[i])/(ep2[i] - ep1[i]);
51 ep1[i] = min[i];
52 } else if (loc1 & position(i) & ABOVE) {
53 d = (max[i] - ep1[i])/(ep2[i] - ep1[i]);
54 ep1[i] = max[i];
55 } else
56 continue;
57
58 for (j = 0; j < 3; j++)
59 if (j != i)
60 ep1[j] += (ep2[j] - ep1[j])*d;
61 break;
62 }
63 loc1 = plocate(ep1, min, max);
64 }
65 return(accept);
66 }
