root/Development/ray/src/common/clip.c
Revision: 2.5
Committed: Thu Jun 26 00:58:09 2003 UTC (22 years, 5 months ago) by schorsch
CVS Tags: rad6R0, rad5R4, rad5R3, rad5R2, rad5R1, rad5R0, rad4R2P2, rad4R2P1, rad4R2, rad4R1, rad4R0, rad3R9, rad3R8, rad3R7P2, rad3R7P1, rad3R6P1, rad3R6, HEAD
Error occurred while calculating annotation data.
2 static const char RCSid[] = "$Id: clip.c,v 2.4 2003/02/25 02:47:21 greg Exp $";
5 * clip.c - routine to clip 3D line segments to a box.
6 */
7
8 #include "copyright.h"
9
10 #include "fvect.h"
11
12 #include "plocate.h"
13
14 #define MAXITER 6 /* maximum possible number of iterations */
15
16
17 int
18 clip(ep1, ep2, min, max) /* clip a line segment to a box */
19 RREAL *ep1, *ep2;
20 FVECT min, max;
21 {
22 int itlim = MAXITER;
23 int loc1, loc2;
24 int accept;
25 RREAL *dp;
26 double d;
27 register int i, j;
28
29 /*
30 * The Cohen-Sutherland algorithm is used to determine
31 * what part (if any) of the given line segment is contained
32 * in the box specified by the min and max vectors.
33 * The routine returns non-zero if any segment is left.
34 */
35
36 loc1 = plocate(ep1, min, max);
37 loc2 = plocate(ep2, min, max);
38
39 /* check for trivial accept and reject */
40 /* trivial accept is both points inside */
41 /* trivial reject is both points to one side */
42
43 while (!((accept = !(loc1 | loc2)) || (loc1 & loc2))) {
44
45 if (itlim-- <= 0) /* past theoretical limit? */
46 return(0); /* quit fooling around */
47
48 if (!loc1) { /* make sure first point is outside */
49 dp = ep1; ep1 = ep2; ep2 = dp;
50 i = loc1; loc1 = loc2; loc2 = i;
51 }
52
53 for (i = 0; i < 3; i++) { /* chop segment */
54
55 if (loc1 & position(i) & BELOW) {
56 d = (min[i] - ep1[i])/(ep2[i] - ep1[i]);
57 ep1[i] = min[i];
58 } else if (loc1 & position(i) & ABOVE) {
59 d = (max[i] - ep1[i])/(ep2[i] - ep1[i]);
60 ep1[i] = max[i];
61 } else
62 continue;
63
64 for (j = 0; j < 3; j++)
65 if (j != i)
66 ep1[j] += (ep2[j] - ep1[j])*d;
67 break;
68 }
69 loc1 = plocate(ep1, min, max);
70 }
71 return(accept);
72 }
