root/radiance/ray/src/common/ccyrgb.c
Revision: 3.5
Committed: Wed Nov 15 18:02:52 2023 UTC (18 months, 1 week ago) by greg
Changes since 3.4: +45 -2 lines
2 static const char RCSid[] = "$Id: ccyrgb.c,v 3.4 2012/05/17 17:11:33 greg Exp $";
5 * Convert MGF color to Radiance RGB and spectral representations
6 */
7
8 #include <stdio.h>
9 #include "color.h"
10 #include "ccolor.h"
11
12 void
13 ccy2rgb( /* convert MGF color to RGB */
14 C_COLOR *cin, /* input MGF chrominance */
15 double cieY, /* input luminance or reflectance */
16 COLOR cout /* output RGB color */
17 )
18 {
19 double d;
20 COLOR xyz;
21 /* get CIE XYZ representation */
22 c_ccvt(cin, C_CSXY);
23 d = cin->cx/cin->cy;
24 xyz[CIEX] = d * cieY;
25 xyz[CIEY] = cieY;
26 xyz[CIEZ] = (1./cin->cy - d - 1.) * cieY;
27 cie_rgb(cout, xyz);
28 }
29
30 /* Convert RGB to MGF color and value */
31 double
32 rgb2ccy(COLOR cin, C_COLOR *cout)
33 {
34 COLOR xyz;
35 double df;
36
37 rgb_cie(xyz, cin);
38 *cout = c_dfcolor;
39 df = xyz[CIEX] + xyz[CIEY] + xyz[CIEZ];
40 if (df <= .0)
41 return(.0);
42 df = 1./df;
43 cout->cx = xyz[CIEX]*df;
44 cout->cy = xyz[CIEZ]*df;
45 cout->flags = (C_CSXY|C_CDXY);
46
47 return(xyz[CIEY]);
48 }
49
50 void
51 ccy2scolor( /* convert MGF color, Y to spectral color */
52 C_COLOR *cin, /* input MGF color or spectrum */
53 double cieY, /* input luminance or reflectance */
54 SCOLOR sco /* output spectral color */
55 )
56 {
57 COLORV nf, sorig[C_CNSS];
58 int i;
59
60 if (cin->flags & C_CDXY || NCSAMP <= 3) {
61 COLOR col; /* tristimulus in or out, so... */
62 ccy2rgb(cin, cieY, col);
63 setscolor(sco, colval(col,RED), colval(col,GRN), colval(col,BLU));
64 return;
65 }
66 c_ccvt(cin, C_CSXY);
67 nf = cieY*C_CNSS/(cin->ssum*3*cin->cy);
68 for (i = C_CNSS; i--; ) /* may as well reverse order */
69 sorig[C_CNSS-1-i] = nf*(COLORV)cin->ssamp[i];
70
71 convertscolor(sco, NCSAMP, WLPART[0], WLPART[3],
72 sorig, C_CNSS, C_CMAXWL+.5*C_CWLI, C_CMINWL-.5*C_CWLI);
73 }
74
75 /* Convert spectral color to MGF color and Y value */
76 double
77 scolor2ccy(SCOLOR sci, C_COLOR *cout)
78 {
79 float hinc, cspec[MAXCSAMP];
80 int i = NCSAMP;
81
82 if (i <= 3) /* defined as RGB, so... */
83 return(rgb2ccy(sci, cout));
84
85 while (i-- > 0) /* need to reverse array */
86 cspec[i] = sci[NCSAMP-1-i];
87
88 hinc = (WLPART[0]-WLPART[3])/(float)(2*NCSAMP);
89
90 return(c_sset(cout, WLPART[3]+hinc, WLPART[0]-hinc, cspec, NCSAMP));
91 }
