root/radiance/ray/src/common/ccolor.h
Sat Jan 23 18:58:35 2016 UTC (8 years, 3 months ago) by greg
CVS Tags: rad5R1, rad5R2, rad5R3, rad5R4
Changes since 3.7: +2 -1 lines
Diff to previous 3.7
Added randomization to chroma encoding
Thu Mar 26 15:57:19 2015 UTC (9 years, 1 month ago) by greg
Changes since 3.6: +7 -1 lines
Diff to previous 3.6
Added chromaticity encode/decode functions
Tue Jun 26 17:59:16 2012 UTC (11 years, 10 months ago) by greg
Changes since 3.5: +4 -2 lines
Diff to previous 3.5
Made CIE 1931 curves external
Fri May 18 20:43:13 2012 UTC (11 years, 11 months ago) by greg
Changes since 3.4: +7 -1 lines
Diff to previous 3.4
Exposed c_toSharpRGB() and c_fromSharpRGB()
Thu May 17 21:16:02 2012 UTC (11 years, 11 months ago) by greg
Changes since 3.3: +8 -4 lines
Diff to previous 3.3
Added macro to assign CIE chromaticities
Thu May 17 17:10:23 2012 UTC (11 years, 11 months ago) by greg
Changes since 3.2: +6 -3 lines
Diff to previous 3.2
Added spectrum assignment function c_sset()
Thu May 17 05:47:59 2012 UTC (11 years, 11 months ago) by greg
Changes since 3.1: +4 -1 lines
Diff to previous 3.1
Added spectral color multiplication
Fri Feb 18 00:40:25 2011 UTC (13 years, 2 months ago) by greg
