root/radiance/ray/src/common/ccolor.h
Revision: 3.7
Committed: Thu Mar 26 15:57:19 2015 UTC (9 years, 2 months ago) by greg
Changes since 3.6: +7 -1 lines
Added chromaticity encode/decode functions
1 /* RCSid $Id: ccolor.h,v 3.6 2012/06/26 17:59:16 greg Exp $ */
2 /*
3 * Header file for spectral colors.
4 *
5 */
6
7 #ifndef _MGF_COLOR_H_
8 #define _MGF_COLOR_H_
9 #ifdef __cplusplus
10 extern "C" {
11 #endif
12
13 #define C_CMINWL 380 /* minimum wavelength */
14 #define C_CMAXWL 780 /* maximum wavelength */
15 #define C_CNSS 41 /* number of spectral samples */
16 #define C_CWLI ((C_CMAXWL-C_CMINWL)/(C_CNSS-1))
17 #define C_CMAXV 10000 /* nominal maximum sample value */
18 #define C_CLPWM (683./C_CMAXV) /* peak lumens/watt multiplier */
19
20 #define C_CSSPEC 01 /* flag if spectrum is set */
21 #define C_CDSPEC 02 /* flag if defined w/ spectrum */
22 #define C_CSXY 04 /* flag if xy is set */
23 #define C_CDXY 010 /* flag if defined w/ xy */
24 #define C_CSEFF 020 /* flag if efficacy set */
25
26 typedef struct {
27 int clock; /* incremented each change */
28 void *client_data; /* pointer to private client-owned data */
29 short flags; /* what's been set and how */
30 short ssamp[C_CNSS]; /* spectral samples, min wl to max */
31 long ssum; /* straight sum of spectral values */
32 float cx, cy; /* xy chromaticity value */
33 float eff; /* efficacy (lumens/watt) */
34 } C_COLOR;
35
36 typedef unsigned short C_CHROMA; /* encoded (x,y) chromaticity */
37
38 #define C_DEFCOLOR { 1, NULL, C_CDXY|C_CSXY|C_CSSPEC|C_CSEFF,\
39 {C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\
40 C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\
41 C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\
42 C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\
43 C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\
44 C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\
45 C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV},\
46 (long)C_CNSS*C_CMAXV, 1./3., 1./3., 178.006 }
47
48 #define c_cval(c,l) ((c)->ssamp[((l)+(C_CWLI/2.-C_MINWL))/C_CWLI] \
49 / (double)(c)->ssum)
50
51 extern const C_COLOR c_dfcolor; /* default color */
52
53 extern const C_COLOR c_x31, c_y31, c_z31; /* 1931 standard observer */
54
55 /* set CIE (x,y) chromaticity */
56 #define c_cset(c,x,y) ((c)->cx=(x),(c)->cy=(y),(c)->flags=C_CDXY|C_CSXY)
57
58 /* set black body spectrum */
59 extern int c_bbtemp(C_COLOR *clr, double tk);
60 /* assign arbitrary spectrum */
61 extern double c_sset(C_COLOR *clr, double wlmin, double wlmax,
62 const float spec[], int nwl);
63 extern void c_ccvt(C_COLOR *clr, int fl); /* fix color representation */
64 extern int c_isgrey(C_COLOR *clr); /* check if color is grey */
65 /* mix two colors */
66 extern void c_cmix(C_COLOR *cres, double w1, C_COLOR *c1,
67 double w2, C_COLOR *c2);
68 /* multiply two colors */
69 extern double c_cmult(C_COLOR *cres, C_COLOR *c1, double y1,
70 C_COLOR *c2, double y2);
71 /* convert to sharpened RGB */
72 extern void c_toSharpRGB(C_COLOR *cin, double cieY, float cout[3]);
73 /* convert from sharpened RGB */
74 extern double c_fromSharpRGB(float cin[3], C_COLOR *cout);
75 /* encode (x,y) chromaticity */
76 extern C_CHROMA c_encodeChroma(C_COLOR *clr);
77 /* decode (x,y) chromaticity */
78 extern void c_decodeChroma(C_COLOR *cres, C_CHROMA ccode);
79
80 /* The following two routines are not defined in ccolor.c */
81 /* convert to RGB color */
82 extern void ccy2rgb(C_COLOR *cin, double cieY, float cout[3]);
83 /* convert from RGB color */
84 extern double rgb2ccy(float cin[3], C_COLOR *cout);
85
86 #ifdef __cplusplus
87 }
88 #endif
89 #endif /* _MGF_COLOR_H_ */
