root/radiance/ray/src/common/ccolor.h
Revision: 3.2
Committed: Thu May 17 05:47:59 2012 UTC (12 years ago) by greg
Changes since 3.1: +4 -1 lines
Added spectral color multiplication
1 /* RCSid $Id: ccolor.h,v 3.1 2011/02/18 00:40:25 greg Exp $ */
2 /*
3 * Header file for spectral colors.
4 *
5 */
6
7 #ifndef _MGF_COLOR_H_
8 #define _MGF_COLOR_H_
9 #ifdef __cplusplus
10 extern "C" {
11 #endif
12
13 #define C_CMINWL 380 /* minimum wavelength */
14 #define C_CMAXWL 780 /* maximum wavelength */
15 #define C_CNSS 41 /* number of spectral samples */
16 #define C_CWLI ((C_CMAXWL-C_CMINWL)/(C_CNSS-1))
17 #define C_CMAXV 10000 /* nominal maximum sample value */
18 #define C_CLPWM (683./C_CMAXV) /* peak lumens/watt multiplier */
19
20 #define C_CSSPEC 01 /* flag if spectrum is set */
21 #define C_CDSPEC 02 /* flag if defined w/ spectrum */
22 #define C_CSXY 04 /* flag if xy is set */
23 #define C_CDXY 010 /* flag if defined w/ xy */
24 #define C_CSEFF 020 /* flag if efficacy set */
25
26 typedef struct {
27 int clock; /* incremented each change */
28 void *client_data; /* pointer to private client-owned data */
29 short flags; /* what's been set and how */
30 short ssamp[C_CNSS]; /* spectral samples, min wl to max */
31 long ssum; /* straight sum of spectral values */
32 float cx, cy; /* xy chromaticity value */
33 float eff; /* efficacy (lumens/watt) */
34 } C_COLOR;
35
36 #define C_DEFCOLOR { 1, NULL, C_CDXY|C_CSXY|C_CSSPEC|C_CSEFF,\
37 {C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\
38 C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\
39 C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\
40 C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\
41 C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\
42 C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,\
43 C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV,C_CMAXV},\
44 (long)C_CNSS*C_CMAXV, 1./3., 1./3., 178.006 }
45
46 #define c_cval(c,l) ((double)(c)->ssamp[((l)-C_MINWL)/C_CWLI] / (c)->ssum)
47
48 extern C_COLOR c_dfcolor; /* default color */
49
50 extern void c_ccvt(C_COLOR *, int); /* fix color representation */
51 extern int c_isgrey(C_COLOR *); /* check if color is grey */
52 /* mix two colors */
53 extern void c_cmix(C_COLOR *cres, double w1, C_COLOR *c1,
54 double w2, C_COLOR *c2);
55 /* multiply two colors */
56 extern double c_cmult(C_COLOR *cres, C_COLOR *c1, double y1,
57 C_COLOR *c2, double y2);
58 /* set black body spectrum */
59 extern int c_bbtemp(C_COLOR *clr, double tk);
60 /* convert to RGB color */
61 extern void ccy2rgb(C_COLOR *cin, double cieY, float cout[3]);
62 /* convert from RGB color */
63 extern double rgb2ccy(float cin[3], C_COLOR *cout);
64
65 #ifdef __cplusplus
66 }
67 #endif
68 #endif /* _MGF_COLOR_H_ */
