root/radiance/ray/src/common/ccolor.c
Revision: 3.13
Committed: Thu Jan 4 16:14:50 2024 UTC (15 months, 4 weeks ago) by greg
Changes since 3.12: +8 -8 lines
fix(mgf2rad): Made color equivalence check more stringent
# User Rev Content
1 greg 3.1 #ifndef lint
2 greg 3.13 static const char RCSid[] = "$Id: ccolor.c,v 3.12 2024/01/04 01:55:42 greg Exp $";
3 greg 3.1 #endif
4     /*
5     * Spectral color handling routines
6     */
7
8     #include <stdio.h>
9 greg 3.9 #include <stdlib.h>
10 greg 3.1 #include <math.h>
11     #include "ccolor.h"
12
13 greg 3.9 #undef frand
14     #define frand() (rand()*(1./(RAND_MAX+.5)))
15
16 greg 3.4 /* Sharp primary matrix */
17     float XYZtoSharp[3][3] = {
18     { 1.2694, -0.0988, -0.1706},
19     {-0.8364, 1.8006, 0.0357},
20     { 0.0297, -0.0315, 1.0018}
21     };
22     /* inverse Sharp primary matrix */
23     float XYZfromSharp[3][3] = {
24     { 0.8156, 0.0472, 0.1372},
25     { 0.3791, 0.5769, 0.0440},
26     {-0.0123, 0.0167, 0.9955}
27     };
28 greg 3.1
29 greg 3.5 const C_COLOR c_dfcolor = C_DEFCOLOR;
30 greg 3.1
31 greg 3.9 const C_CHROMA c_dfchroma = 49750; /* c_encodeChroma(&c_dfcolor) */
32
33 greg 3.1 /* CIE 1931 Standard Observer curves */
34 greg 3.5 const C_COLOR c_x31 = { 1, NULL, C_CDSPEC|C_CSSPEC|C_CSXY|C_CSEFF,
35 greg 3.1 {14,42,143,435,1344,2839,3483,3362,2908,1954,956,
36     320,49,93,633,1655,2904,4334,5945,7621,9163,10263,
37     10622,10026,8544,6424,4479,2835,1649,874,468,227,
38     114,58,29,14,7,3,2,1,0}, 106836L, .467, .368, 362.230
39     };
40 greg 3.5 const C_COLOR c_y31 = { 1, NULL, C_CDSPEC|C_CSSPEC|C_CSXY|C_CSEFF,
41 greg 3.1 {0,1,4,12,40,116,230,380,600,910,1390,2080,3230,
42     5030,7100,8620,9540,9950,9950,9520,8700,7570,6310,
43     5030,3810,2650,1750,1070,610,320,170,82,41,21,10,
44     5,2,1,1,0,0}, 106856L, .398, .542, 493.525
45     };
46 greg 3.5 const C_COLOR c_z31 = { 1, NULL, C_CDSPEC|C_CSSPEC|C_CSXY|C_CSEFF,
47 greg 3.1 {65,201,679,2074,6456,13856,17471,17721,16692,
48     12876,8130,4652,2720,1582,782,422,203,87,39,21,17,
49     11,8,3,2,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0},
50     106770L, .147, .077, 54.363
51     };
52     /* Derived CIE 1931 Primaries (imaginary) */
53 greg 3.2 static const C_COLOR cie_xp = { 1, NULL, C_CDSPEC|C_CSSPEC|C_CSXY,
54 greg 3.1 {-174,-198,-195,-197,-202,-213,-235,-272,-333,
55     -444,-688,-1232,-2393,-4497,-6876,-6758,-5256,
56     -3100,-815,1320,3200,4782,5998,6861,7408,7754,
57     7980,8120,8199,8240,8271,8292,8309,8283,8469,
58     8336,8336,8336,8336,8336,8336},
59     127424L, 1., .0,
60     };
61 greg 3.2 static const C_COLOR cie_yp = { 1, NULL, C_CDSPEC|C_CSSPEC|C_CSXY,
62 greg 3.1 {-451,-431,-431,-430,-427,-417,-399,-366,-312,
63     -204,57,691,2142,4990,8810,9871,9122,7321,5145,
64     3023,1123,-473,-1704,-2572,-3127,-3474,-3704,
65     -3846,-3927,-3968,-3999,-4021,-4038,-4012,-4201,
66     -4066,-4066,-4066,-4066,-4066,-4066},
67     -23035L, .0, 1.,
68     };
69 greg 3.2 static const C_COLOR cie_zp = { 1, NULL, C_CDSPEC|C_CSSPEC|C_CSXY,
70 greg 3.1 {4051,4054,4052,4053,4054,4056,4059,4064,4071,
71     4074,4056,3967,3677,2933,1492,313,-440,-795,
72     -904,-918,-898,-884,-869,-863,-855,-855,-851,
73     -848,-847,-846,-846,-846,-845,-846,-843,-845,
74     -845,-845,-845,-845,-845},
75     36057L, .0, .0,
76     };
77
78 greg 3.2
79 greg 3.4 /* convert to sharpened RGB color for low-error operations */
80     void
81 greg 3.2 c_toSharpRGB(C_COLOR *cin, double cieY, float cout[3])
82     {
83     double xyz[3];
84
85     c_ccvt(cin, C_CSXY);
86
87     xyz[0] = cin->cx/cin->cy * cieY;
88     xyz[1] = cieY;
89     xyz[2] = (1. - cin->cx - cin->cy)/cin->cy * cieY;
90
91 greg 3.4 cout[0] = XYZtoSharp[0][0]*xyz[0] + XYZtoSharp[0][1]*xyz[1] +
92     XYZtoSharp[0][2]*xyz[2];
93     cout[1] = XYZtoSharp[1][0]*xyz[0] + XYZtoSharp[1][1]*xyz[1] +
94     XYZtoSharp[1][2]*xyz[2];
95     cout[2] = XYZtoSharp[2][0]*xyz[0] + XYZtoSharp[2][1]*xyz[1] +
96     XYZtoSharp[2][2]*xyz[2];
97 greg 3.2 }
98
99 greg 3.4 /* convert back from sharpened RGB color */
100     double
101 greg 3.2 c_fromSharpRGB(float cin[3], C_COLOR *cout)
102     {
103     double xyz[3], sf;
104
105 greg 3.8 xyz[1] = XYZfromSharp[1][0]*cin[0] + XYZfromSharp[1][1]*cin[1] +
106     XYZfromSharp[1][2]*cin[2];
107     if (xyz[1] <= 1e-6) {
108     *cout = c_dfcolor; /* punting, here... */
109     return xyz[1];
110     }
111 greg 3.4 xyz[0] = XYZfromSharp[0][0]*cin[0] + XYZfromSharp[0][1]*cin[1] +
112     XYZfromSharp[0][2]*cin[2];
113     xyz[2] = XYZfromSharp[2][0]*cin[0] + XYZfromSharp[2][1]*cin[1] +
114     XYZfromSharp[2][2]*cin[2];
115 greg 3.8
116 greg 3.2 sf = 1./(xyz[0] + xyz[1] + xyz[2]);
117
118     cout->cx = xyz[0] * sf;
119     cout->cy = xyz[1] * sf;
120     cout->flags = C_CDXY|C_CSXY;
121
122     return(xyz[1]);
123     }
124
125 greg 3.6 /* assign arbitrary spectrum and return Y value */
126 greg 3.3 double
127     c_sset(C_COLOR *clr, double wlmin, double wlmax, const float spec[], int nwl)
128     {
129     double yval, scale;
130     float va[C_CNSS];
131     int i, pos, n, imax, wl;
132     double wl0, wlstep;
133     double boxpos, boxstep;
134     /* check arguments */
135     if ((nwl <= 1) | (spec == NULL) | (wlmin >= C_CMAXWL) |
136     (wlmax <= C_CMINWL) | (wlmin >= wlmax))
137     return(0.);
138 greg 3.12 wlstep = (wlmax - wlmin)/(nwl-1.);
139 greg 3.3 while (wlmin < C_CMINWL) {
140     wlmin += wlstep;
141     --nwl; ++spec;
142     }
143     while (wlmax > C_CMAXWL) {
144     wlmax -= wlstep;
145     --nwl;
146     }
147 greg 3.6 if ((nwl <= 1) | (wlmin >= wlmax))
148     return(0.);
149 greg 3.3 imax = nwl; /* box filter if necessary */
150     boxpos = 0;
151     boxstep = 1;
152     if (wlstep < C_CWLI) {
153     imax = (wlmax - wlmin)/C_CWLI + 1e-7;
154     boxpos = (wlmin - C_CMINWL)/C_CWLI;
155     boxstep = wlstep/C_CWLI;
156     wlstep = C_CWLI;
157     }
158     scale = 0.; /* get values and maximum */
159     yval = 0.;
160     pos = 0;
161     for (i = 0; i < imax; i++) {
162     va[i] = 0.; n = 0;
163     while (boxpos < i+.5 && pos < nwl) {
164     va[i] += spec[pos++];
165     n++;
166     boxpos += boxstep;
167     }
168     if (n > 1)
169     va[i] /= (double)n;
170     if (va[i] > scale)
171     scale = va[i];
172     else if (va[i] < -scale)
173     scale = -va[i];
174 greg 3.5 yval += va[i] * c_y31.ssamp[i];
175 greg 3.3 }
176     if (scale <= 1e-7)
177     return(0.);
178 greg 3.5 yval /= (double)c_y31.ssum;
179 greg 3.3 scale = C_CMAXV / scale;
180     clr->ssum = 0; /* convert to our spacing */
181     wl0 = wlmin;
182     pos = 0;
183     for (i = 0, wl = C_CMINWL; i < C_CNSS; i++, wl += C_CWLI)
184     if ((wl < wlmin) | (wl > wlmax))
185     clr->ssamp[i] = 0;
186     else {
187 greg 3.12 while (wl0 + wlstep < wl+.01) {
188 greg 3.3 wl0 += wlstep;
189     pos++;
190     }
191 greg 3.12 if ((wl+.01 >= wl0) & (wl-.01 <= wl0))
192 greg 3.9 clr->ssamp[i] = scale*va[pos] + frand();
193 greg 3.3 else /* interpolate if necessary */
194 greg 3.9 clr->ssamp[i] = frand() + scale / wlstep *
195 greg 3.3 ( va[pos]*(wl0+wlstep - wl) +
196     va[pos+1]*(wl - wl0) );
197     clr->ssum += clr->ssamp[i];
198     }
199     clr->flags = C_CDSPEC|C_CSSPEC;
200     return(yval);
201     }
202
203 greg 3.12
204     /* check if colors are equivalent */
205     int
206     c_equiv(C_COLOR *c1, C_COLOR *c2)
207     {
208     long thresh;
209     int i;
210
211     if (c1 == c2)
212     return(1);
213 greg 3.13 if ((c1->flags ^ c2->flags) & (C_CDXY|C_CDSPEC))
214     return(0); /* defined differently, so no */
215     c_ccvt(c1, C_CSXY);
216     c_ccvt(c2, C_CSXY); /* first check chromaticities */
217 greg 3.12 if (fabs(c1->cx - c2->cx) + fabs(c1->cy - c2->cy) > .015)
218     return(0); /* mismatch means definitely different */
219 greg 3.13 if (c1->flags & C_CDXY)
220     return(1); /* done if defined as (x,y) */
221 greg 3.12 thresh = C_CMAXV/200*(c1->ssum + c2->ssum);
222 greg 3.13 for (i = 0; i < C_CNSS; i++) /* else compare spectra */
223 greg 3.12 if (labs(c1->ssamp[i]*c2->ssum - c2->ssamp[i]*c1->ssum) > thresh)
224     return(0);
225     return(1);
226     }
227
228
229 greg 3.1 /* check if color is grey */
230     int
231     c_isgrey(C_COLOR *clr)
232     {
233     if (!(clr->flags & (C_CSXY|C_CSSPEC)))
234     return(1); /* no settings == grey */
235
236     c_ccvt(clr, C_CSXY);
237
238     return(clr->cx >= .323 && clr->cx <= .343 &&
239     clr->cy >= .323 && clr->cy <= .343);
240     }
241
242     /* convert color representations */
243     void
244     c_ccvt(C_COLOR *clr, int fl)
245     {
246     double x, y, z;
247     int i;
248
249 greg 3.12 fl &= ~clr->flags; /* ignore what's done */
250     if (!fl) /* everything's done! */
251 greg 3.1 return;
252     if (!(clr->flags & (C_CSXY|C_CSSPEC))) {
253 greg 3.12 *clr = c_dfcolor; /* nothing was set! */
254 greg 3.1 return;
255     }
256     if (fl & C_CSXY) { /* cspec -> cxy */
257     x = y = z = 0.;
258     for (i = 0; i < C_CNSS; i++) {
259 greg 3.5 x += c_x31.ssamp[i] * clr->ssamp[i];
260     y += c_y31.ssamp[i] * clr->ssamp[i];
261     z += c_z31.ssamp[i] * clr->ssamp[i];
262 greg 3.1 }
263 greg 3.5 x /= (double)c_x31.ssum;
264     y /= (double)c_y31.ssum;
265     z /= (double)c_z31.ssum;
266 greg 3.1 z += x + y;
267 greg 3.11 if (z > 1e-6) {
268     clr->cx = x / z;
269     clr->cy = y / z;
270     } else
271     clr->cx = clr->cy = 1./3.;
272 greg 3.1 clr->flags |= C_CSXY;
273 greg 3.6 }
274     if (fl & C_CSSPEC) { /* cxy -> cspec */
275 greg 3.1 x = clr->cx;
276     y = clr->cy;
277     z = 1. - x - y;
278     clr->ssum = 0;
279     for (i = 0; i < C_CNSS; i++) {
280     clr->ssamp[i] = x*cie_xp.ssamp[i] + y*cie_yp.ssamp[i]
281 greg 3.9 + z*cie_zp.ssamp[i] + frand();
282 greg 3.1 if (clr->ssamp[i] < 0) /* out of gamut! */
283     clr->ssamp[i] = 0;
284     else
285     clr->ssum += clr->ssamp[i];
286     }
287     clr->flags |= C_CSSPEC;
288     }
289     if (fl & C_CSEFF) { /* compute efficacy */
290     if (clr->flags & C_CSSPEC) { /* from spectrum */
291     y = 0.;
292     for (i = 0; i < C_CNSS; i++)
293 greg 3.5 y += c_y31.ssamp[i] * clr->ssamp[i];
294 greg 3.11 clr->eff = C_CLPWM * y / (clr->ssum + 0.0001);
295 greg 3.1 } else /* clr->flags & C_CSXY */ { /* from (x,y) */
296 greg 3.5 clr->eff = clr->cx*c_x31.eff + clr->cy*c_y31.eff +
297     (1. - clr->cx - clr->cy)*c_z31.eff;
298 greg 3.1 }
299     clr->flags |= C_CSEFF;
300     }
301     }
302
303 greg 3.2 /* mix two colors according to weights given -- cres may be c1 or c2 */
304 greg 3.1 void
305     c_cmix(C_COLOR *cres, double w1, C_COLOR *c1, double w2, C_COLOR *c2)
306     {
307     double scale;
308     int i;
309
310 greg 3.11 if (w1 == 0) {
311     *cres = *c2;
312     return;
313     }
314     if (w2 == 0) {
315     *cres = *c1;
316     return;
317     }
318 greg 3.1 if ((c1->flags|c2->flags) & C_CDSPEC) { /* spectral mixing */
319 greg 3.2 float cmix[C_CNSS];
320
321 greg 3.1 c_ccvt(c1, C_CSSPEC|C_CSEFF);
322     c_ccvt(c2, C_CSSPEC|C_CSEFF);
323 greg 3.11 if (c1->ssum*c2->ssum == 0) {
324     *cres = c_dfcolor;
325     return;
326     }
327 greg 3.1 w1 /= c1->eff*c1->ssum;
328     w2 /= c2->eff*c2->ssum;
329     scale = 0.;
330     for (i = 0; i < C_CNSS; i++) {
331     cmix[i] = w1*c1->ssamp[i] + w2*c2->ssamp[i];
332     if (cmix[i] > scale)
333     scale = cmix[i];
334 greg 3.3 else if (cmix[i] < -scale)
335     scale = -cmix[i];
336 greg 3.1 }
337     scale = C_CMAXV / scale;
338     cres->ssum = 0;
339     for (i = 0; i < C_CNSS; i++)
340 greg 3.9 cres->ssum += cres->ssamp[i] = scale*cmix[i] + frand();
341 greg 3.1 cres->flags = C_CDSPEC|C_CSSPEC;
342     } else { /* CIE xy mixing */
343     c_ccvt(c1, C_CSXY);
344     c_ccvt(c2, C_CSXY);
345     w1 *= c2->cy;
346     w2 *= c1->cy;
347     scale = w1 + w2;
348     if (scale == 0.) {
349     *cres = c_dfcolor;
350     return;
351     }
352     scale = 1. / scale;
353     cres->cx = (w1*c1->cx + w2*c2->cx) * scale;
354     cres->cy = (w1*c1->cy + w2*c2->cy) * scale;
355     cres->flags = C_CDXY|C_CSXY;
356     }
357     }
358
359 greg 3.2 /* multiply two colors -- cres may be c1 or c2 */
360     double
361     c_cmult(C_COLOR *cres, C_COLOR *c1, double y1, C_COLOR *c2, double y2)
362     {
363     double yres;
364     int i;
365
366     if ((c1->flags|c2->flags) & C_CDSPEC) {
367     long cmix[C_CNSS], cmax = 0; /* spectral multiply */
368
369     c_ccvt(c1, C_CSSPEC|C_CSEFF);
370     c_ccvt(c2, C_CSSPEC|C_CSEFF);
371     for (i = 0; i < C_CNSS; i++) {
372     cmix[i] = c1->ssamp[i] * c2->ssamp[i];
373     if (cmix[i] > cmax)
374     cmax = cmix[i];
375 greg 3.3 else if (cmix[i] < -cmax)
376     cmax = -cmix[i];
377 greg 3.2 }
378     cmax /= C_CMAXV;
379     if (!cmax) {
380     *cres = c_dfcolor;
381     return(0.);
382     }
383     cres->ssum = 0;
384     for (i = 0; i < C_CNSS; i++)
385     cres->ssum += cres->ssamp[i] = cmix[i] / cmax;
386     cres->flags = C_CDSPEC|C_CSSPEC;
387
388 greg 3.6 c_ccvt(cres, C_CSEFF); /* below is correct */
389 greg 3.5 yres = y1 * y2 * c_y31.ssum * C_CLPWM /
390 greg 3.2 (c1->eff*c1->ssum * c2->eff*c2->ssum) *
391     cres->eff*( cres->ssum*(double)cmax +
392     C_CNSS/2.0*(cmax-1) );
393     } else {
394     float rgb1[3], rgb2[3]; /* CIE xy multiply */
395
396     c_toSharpRGB(c1, y1, rgb1);
397     c_toSharpRGB(c2, y2, rgb2);
398
399     rgb2[0] *= rgb1[0]; rgb2[1] *= rgb1[1]; rgb2[2] *= rgb1[2];
400
401     yres = c_fromSharpRGB(rgb2, cres);
402     }
403     return(yres);
404     }
405
406 greg 3.1 #define C1 3.741832e-16 /* W-m^2 */
407     #define C2 1.4388e-2 /* m-K */
408
409     #define bbsp(l,t) (C1/((l)*(l)*(l)*(l)*(l)*(exp(C2/((t)*(l)))-1.)))
410 greg 3.2 #define bblm(t) (C2*0.2/(t))
411 greg 3.1
412     /* set black body spectrum */
413     int
414     c_bbtemp(C_COLOR *clr, double tk)
415     {
416     double sf, wl;
417     int i;
418
419     if (tk < 1000)
420     return(0);
421     wl = bblm(tk); /* scalefactor based on peak */
422     if (wl < C_CMINWL*1e-9)
423     wl = C_CMINWL*1e-9;
424     else if (wl > C_CMAXWL*1e-9)
425     wl = C_CMAXWL*1e-9;
426     sf = C_CMAXV/bbsp(wl,tk);
427     clr->ssum = 0;
428     for (i = 0; i < C_CNSS; i++) {
429     wl = (C_CMINWL + i*C_CWLI)*1e-9;
430 greg 3.9 clr->ssum += clr->ssamp[i] = sf*bbsp(wl,tk) + frand();
431 greg 3.1 }
432     clr->flags = C_CDSPEC|C_CSSPEC;
433     return(1);
434     }
435
436     #undef C1
437     #undef C2
438     #undef bbsp
439     #undef bblm
440 greg 3.7
441     #define UV_NORMF 410.
442
443     /* encode (x,y) chromaticity */
444     C_CHROMA
445     c_encodeChroma(C_COLOR *clr)
446     {
447     double df;
448     int ub, vb;
449
450     c_ccvt(clr, C_CSXY);
451     df = UV_NORMF/(-2.*clr->cx + 12.*clr->cy + 3.);
452 greg 3.9 ub = 4.*clr->cx*df + frand();
453     if (ub > 0xff) ub = 0xff;
454 greg 3.10 else ub *= (ub > 0);
455 greg 3.9 vb = 9.*clr->cy*df + frand();
456     if (vb > 0xff) vb = 0xff;
457 greg 3.10 else vb *= (vb > 0);
458 greg 3.7
459     return(vb<<8 | ub);
460     }
461
462     /* decode (x,y) chromaticity */
463     void
464     c_decodeChroma(C_COLOR *cres, C_CHROMA ccode)
465     {
466 greg 3.9 double up = (ccode & 0xff)*(1./UV_NORMF);
467     double vp = (ccode>>8 & 0xff)*(1./UV_NORMF);
468 greg 3.7 double df = 1./(6.*up - 16.*vp + 12.);
469
470     cres->cx = 9.*up * df;
471     cres->cy = 4.*vp * df;
472     cres->flags = C_CDXY|C_CSXY;
473     }
474
475     #undef UV_NORMF
