root/radiance/ray/src/common/ccolor.c
Revision: 3.5
Committed: Tue Jun 26 17:59:16 2012 UTC (11 years, 11 months ago) by greg
Changes since 3.4: +18 -18 lines
Made CIE 1931 curves external
2 static const char RCSid[] = "$Id: ccolor.c,v 3.4 2012/05/18 20:43:13 greg Exp $";
5 * Spectral color handling routines
6 */
7
8 #include <stdio.h>
9 #include <math.h>
10 #include "ccolor.h"
11
12 /* Sharp primary matrix */
13 float XYZtoSharp[3][3] = {
14 { 1.2694, -0.0988, -0.1706},
15 {-0.8364, 1.8006, 0.0357},
16 { 0.0297, -0.0315, 1.0018}
17 };
18 /* inverse Sharp primary matrix */
19 float XYZfromSharp[3][3] = {
20 { 0.8156, 0.0472, 0.1372},
21 { 0.3791, 0.5769, 0.0440},
22 {-0.0123, 0.0167, 0.9955}
23 };
24
25 const C_COLOR c_dfcolor = C_DEFCOLOR;
26
27 /* CIE 1931 Standard Observer curves */
28 const C_COLOR c_x31 = { 1, NULL, C_CDSPEC|C_CSSPEC|C_CSXY|C_CSEFF,
29 {14,42,143,435,1344,2839,3483,3362,2908,1954,956,
30 320,49,93,633,1655,2904,4334,5945,7621,9163,10263,
31 10622,10026,8544,6424,4479,2835,1649,874,468,227,
32 114,58,29,14,7,3,2,1,0}, 106836L, .467, .368, 362.230
33 };
34 const C_COLOR c_y31 = { 1, NULL, C_CDSPEC|C_CSSPEC|C_CSXY|C_CSEFF,
35 {0,1,4,12,40,116,230,380,600,910,1390,2080,3230,
36 5030,7100,8620,9540,9950,9950,9520,8700,7570,6310,
37 5030,3810,2650,1750,1070,610,320,170,82,41,21,10,
38 5,2,1,1,0,0}, 106856L, .398, .542, 493.525
39 };
40 const C_COLOR c_z31 = { 1, NULL, C_CDSPEC|C_CSSPEC|C_CSXY|C_CSEFF,
41 {65,201,679,2074,6456,13856,17471,17721,16692,
42 12876,8130,4652,2720,1582,782,422,203,87,39,21,17,
43 11,8,3,2,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0},
44 106770L, .147, .077, 54.363
45 };
46 /* Derived CIE 1931 Primaries (imaginary) */
47 static const C_COLOR cie_xp = { 1, NULL, C_CDSPEC|C_CSSPEC|C_CSXY,
48 {-174,-198,-195,-197,-202,-213,-235,-272,-333,
49 -444,-688,-1232,-2393,-4497,-6876,-6758,-5256,
50 -3100,-815,1320,3200,4782,5998,6861,7408,7754,
51 7980,8120,8199,8240,8271,8292,8309,8283,8469,
52 8336,8336,8336,8336,8336,8336},
53 127424L, 1., .0,
54 };
55 static const C_COLOR cie_yp = { 1, NULL, C_CDSPEC|C_CSSPEC|C_CSXY,
56 {-451,-431,-431,-430,-427,-417,-399,-366,-312,
57 -204,57,691,2142,4990,8810,9871,9122,7321,5145,
58 3023,1123,-473,-1704,-2572,-3127,-3474,-3704,
59 -3846,-3927,-3968,-3999,-4021,-4038,-4012,-4201,
60 -4066,-4066,-4066,-4066,-4066,-4066},
61 -23035L, .0, 1.,
62 };
63 static const C_COLOR cie_zp = { 1, NULL, C_CDSPEC|C_CSSPEC|C_CSXY,
64 {4051,4054,4052,4053,4054,4056,4059,4064,4071,
65 4074,4056,3967,3677,2933,1492,313,-440,-795,
66 -904,-918,-898,-884,-869,-863,-855,-855,-851,
67 -848,-847,-846,-846,-846,-845,-846,-843,-845,
68 -845,-845,-845,-845,-845},
69 36057L, .0, .0,
70 };
71
72
73 /* convert to sharpened RGB color for low-error operations */
74 void
75 c_toSharpRGB(C_COLOR *cin, double cieY, float cout[3])
76 {
77 double xyz[3];
78
79 c_ccvt(cin, C_CSXY);
80
81 xyz[0] = cin->cx/cin->cy * cieY;
82 xyz[1] = cieY;
83 xyz[2] = (1. - cin->cx - cin->cy)/cin->cy * cieY;
84
85 cout[0] = XYZtoSharp[0][0]*xyz[0] + XYZtoSharp[0][1]*xyz[1] +
86 XYZtoSharp[0][2]*xyz[2];
87 cout[1] = XYZtoSharp[1][0]*xyz[0] + XYZtoSharp[1][1]*xyz[1] +
88 XYZtoSharp[1][2]*xyz[2];
89 cout[2] = XYZtoSharp[2][0]*xyz[0] + XYZtoSharp[2][1]*xyz[1] +
90 XYZtoSharp[2][2]*xyz[2];
91 }
92
93 /* convert back from sharpened RGB color */
94 double
95 c_fromSharpRGB(float cin[3], C_COLOR *cout)
96 {
97 double xyz[3], sf;
98
99 xyz[0] = XYZfromSharp[0][0]*cin[0] + XYZfromSharp[0][1]*cin[1] +
100 XYZfromSharp[0][2]*cin[2];
101 xyz[1] = XYZfromSharp[1][0]*cin[0] + XYZfromSharp[1][1]*cin[1] +
102 XYZfromSharp[1][2]*cin[2];
103 xyz[2] = XYZfromSharp[2][0]*cin[0] + XYZfromSharp[2][1]*cin[1] +
104 XYZfromSharp[2][2]*cin[2];
105
106 sf = 1./(xyz[0] + xyz[1] + xyz[2]);
107
108 cout->cx = xyz[0] * sf;
109 cout->cy = xyz[1] * sf;
110 cout->flags = C_CDXY|C_CSXY;
111
112 return(xyz[1]);
113 }
114
115 /* assign arbitrary spectrum */
116 double
117 c_sset(C_COLOR *clr, double wlmin, double wlmax, const float spec[], int nwl)
118 {
119 double yval, scale;
120 float va[C_CNSS];
121 int i, pos, n, imax, wl;
122 double wl0, wlstep;
123 double boxpos, boxstep;
124 /* check arguments */
125 if ((nwl <= 1) | (spec == NULL) | (wlmin >= C_CMAXWL) |
126 (wlmax <= C_CMINWL) | (wlmin >= wlmax))
127 return(0.);
128 wlstep = (wlmax - wlmin)/(nwl-1);
129 while (wlmin < C_CMINWL) {
130 wlmin += wlstep;
131 --nwl; ++spec;
132 }
133 while (wlmax > C_CMAXWL) {
134 wlmax -= wlstep;
135 --nwl;
136 }
137 imax = nwl; /* box filter if necessary */
138 boxpos = 0;
139 boxstep = 1;
140 if (wlstep < C_CWLI) {
141 imax = (wlmax - wlmin)/C_CWLI + 1e-7;
142 boxpos = (wlmin - C_CMINWL)/C_CWLI;
143 boxstep = wlstep/C_CWLI;
144 wlstep = C_CWLI;
145 }
146 scale = 0.; /* get values and maximum */
147 yval = 0.;
148 pos = 0;
149 for (i = 0; i < imax; i++) {
150 va[i] = 0.; n = 0;
151 while (boxpos < i+.5 && pos < nwl) {
152 va[i] += spec[pos++];
153 n++;
154 boxpos += boxstep;
155 }
156 if (n > 1)
157 va[i] /= (double)n;
158 if (va[i] > scale)
159 scale = va[i];
160 else if (va[i] < -scale)
161 scale = -va[i];
162 yval += va[i] * c_y31.ssamp[i];
163 }
164 if (scale <= 1e-7)
165 return(0.);
166 yval /= (double)c_y31.ssum;
167 scale = C_CMAXV / scale;
168 clr->ssum = 0; /* convert to our spacing */
169 wl0 = wlmin;
170 pos = 0;
171 for (i = 0, wl = C_CMINWL; i < C_CNSS; i++, wl += C_CWLI)
172 if ((wl < wlmin) | (wl > wlmax))
173 clr->ssamp[i] = 0;
174 else {
175 while (wl0 + wlstep < wl+1e-7) {
176 wl0 += wlstep;
177 pos++;
178 }
179 if ((wl+1e-7 >= wl0) & (wl-1e-7 <= wl0))
180 clr->ssamp[i] = scale*va[pos] + .5;
181 else /* interpolate if necessary */
182 clr->ssamp[i] = .5 + scale / wlstep *
183 ( va[pos]*(wl0+wlstep - wl) +
184 va[pos+1]*(wl - wl0) );
185 clr->ssum += clr->ssamp[i];
186 }
187 clr->flags = C_CDSPEC|C_CSSPEC;
188 return(yval);
189 }
190
191 /* check if color is grey */
192 int
193 c_isgrey(C_COLOR *clr)
194 {
195 if (!(clr->flags & (C_CSXY|C_CSSPEC)))
196 return(1); /* no settings == grey */
197
198 c_ccvt(clr, C_CSXY);
199
200 return(clr->cx >= .323 && clr->cx <= .343 &&
201 clr->cy >= .323 && clr->cy <= .343);
202 }
203
204 /* convert color representations */
205 void
206 c_ccvt(C_COLOR *clr, int fl)
207 {
208 double x, y, z;
209 int i;
210
211 fl &= ~clr->flags; /* ignore what's done */
212 if (!fl) /* everything's done! */
213 return;
214 if (!(clr->flags & (C_CSXY|C_CSSPEC))) {
215 *clr = c_dfcolor; /* nothing was set! */
216 return;
217 }
218 if (fl & C_CSXY) { /* cspec -> cxy */
219 x = y = z = 0.;
220 for (i = 0; i < C_CNSS; i++) {
221 x += c_x31.ssamp[i] * clr->ssamp[i];
222 y += c_y31.ssamp[i] * clr->ssamp[i];
223 z += c_z31.ssamp[i] * clr->ssamp[i];
224 }
225 x /= (double)c_x31.ssum;
226 y /= (double)c_y31.ssum;
227 z /= (double)c_z31.ssum;
228 z += x + y;
229 clr->cx = x / z;
230 clr->cy = y / z;
231 clr->flags |= C_CSXY;
232 } else if (fl & C_CSSPEC) { /* cxy -> cspec */
233 x = clr->cx;
234 y = clr->cy;
235 z = 1. - x - y;
236 clr->ssum = 0;
237 for (i = 0; i < C_CNSS; i++) {
238 clr->ssamp[i] = x*cie_xp.ssamp[i] + y*cie_yp.ssamp[i]
239 + z*cie_zp.ssamp[i] + .5;
240 if (clr->ssamp[i] < 0) /* out of gamut! */
241 clr->ssamp[i] = 0;
242 else
243 clr->ssum += clr->ssamp[i];
244 }
245 clr->flags |= C_CSSPEC;
246 }
247 if (fl & C_CSEFF) { /* compute efficacy */
248 if (clr->flags & C_CSSPEC) { /* from spectrum */
249 y = 0.;
250 for (i = 0; i < C_CNSS; i++)
251 y += c_y31.ssamp[i] * clr->ssamp[i];
252 clr->eff = C_CLPWM * y / clr->ssum;
253 } else /* clr->flags & C_CSXY */ { /* from (x,y) */
254 clr->eff = clr->cx*c_x31.eff + clr->cy*c_y31.eff +
255 (1. - clr->cx - clr->cy)*c_z31.eff;
256 }
257 clr->flags |= C_CSEFF;
258 }
259 }
260
261 /* mix two colors according to weights given -- cres may be c1 or c2 */
262 void
263 c_cmix(C_COLOR *cres, double w1, C_COLOR *c1, double w2, C_COLOR *c2)
264 {
265 double scale;
266 int i;
267
268 if ((c1->flags|c2->flags) & C_CDSPEC) { /* spectral mixing */
269 float cmix[C_CNSS];
270
271 c_ccvt(c1, C_CSSPEC|C_CSEFF);
272 c_ccvt(c2, C_CSSPEC|C_CSEFF);
273 w1 /= c1->eff*c1->ssum;
274 w2 /= c2->eff*c2->ssum;
275 scale = 0.;
276 for (i = 0; i < C_CNSS; i++) {
277 cmix[i] = w1*c1->ssamp[i] + w2*c2->ssamp[i];
278 if (cmix[i] > scale)
279 scale = cmix[i];
280 else if (cmix[i] < -scale)
281 scale = -cmix[i];
282 }
283 scale = C_CMAXV / scale;
284 cres->ssum = 0;
285 for (i = 0; i < C_CNSS; i++)
286 cres->ssum += cres->ssamp[i] = scale*cmix[i] + .5;
287 cres->flags = C_CDSPEC|C_CSSPEC;
288 } else { /* CIE xy mixing */
289 c_ccvt(c1, C_CSXY);
290 c_ccvt(c2, C_CSXY);
291 w1 *= c2->cy;
292 w2 *= c1->cy;
293 scale = w1 + w2;
294 if (scale == 0.) {
295 *cres = c_dfcolor;
296 return;
297 }
298 scale = 1. / scale;
299 cres->cx = (w1*c1->cx + w2*c2->cx) * scale;
300 cres->cy = (w1*c1->cy + w2*c2->cy) * scale;
301 cres->flags = C_CDXY|C_CSXY;
302 }
303 }
304
305 /* multiply two colors -- cres may be c1 or c2 */
306 double
307 c_cmult(C_COLOR *cres, C_COLOR *c1, double y1, C_COLOR *c2, double y2)
308 {
309 double yres;
310 int i;
311
312 if ((c1->flags|c2->flags) & C_CDSPEC) {
313 long cmix[C_CNSS], cmax = 0; /* spectral multiply */
314
315 c_ccvt(c1, C_CSSPEC|C_CSEFF);
316 c_ccvt(c2, C_CSSPEC|C_CSEFF);
317 for (i = 0; i < C_CNSS; i++) {
318 cmix[i] = c1->ssamp[i] * c2->ssamp[i];
319 if (cmix[i] > cmax)
320 cmax = cmix[i];
321 else if (cmix[i] < -cmax)
322 cmax = -cmix[i];
323 }
324 cmax /= C_CMAXV;
325 if (!cmax) {
326 *cres = c_dfcolor;
327 return(0.);
328 }
329 cres->ssum = 0;
330 for (i = 0; i < C_CNSS; i++)
331 cres->ssum += cres->ssamp[i] = cmix[i] / cmax;
332 cres->flags = C_CDSPEC|C_CSSPEC;
333
334 c_ccvt(cres, C_CSEFF); /* don't touch below */
335 yres = y1 * y2 * c_y31.ssum * C_CLPWM /
336 (c1->eff*c1->ssum * c2->eff*c2->ssum) *
337 cres->eff*( cres->ssum*(double)cmax +
338 C_CNSS/2.0*(cmax-1) );
339 } else {
340 float rgb1[3], rgb2[3]; /* CIE xy multiply */
341
342 c_toSharpRGB(c1, y1, rgb1);
343 c_toSharpRGB(c2, y2, rgb2);
344
345 rgb2[0] *= rgb1[0]; rgb2[1] *= rgb1[1]; rgb2[2] *= rgb1[2];
346
347 yres = c_fromSharpRGB(rgb2, cres);
348 }
349 return(yres);
350 }
351
352 #define C1 3.741832e-16 /* W-m^2 */
353 #define C2 1.4388e-2 /* m-K */
354
355 #define bbsp(l,t) (C1/((l)*(l)*(l)*(l)*(l)*(exp(C2/((t)*(l)))-1.)))
356 #define bblm(t) (C2*0.2/(t))
357
358 /* set black body spectrum */
359 int
360 c_bbtemp(C_COLOR *clr, double tk)
361 {
362 double sf, wl;
363 int i;
364
365 if (tk < 1000)
366 return(0);
367 wl = bblm(tk); /* scalefactor based on peak */
368 if (wl < C_CMINWL*1e-9)
369 wl = C_CMINWL*1e-9;
370 else if (wl > C_CMAXWL*1e-9)
371 wl = C_CMAXWL*1e-9;
372 sf = C_CMAXV/bbsp(wl,tk);
373 clr->ssum = 0;
374 for (i = 0; i < C_CNSS; i++) {
375 wl = (C_CMINWL + i*C_CWLI)*1e-9;
376 clr->ssum += clr->ssamp[i] = sf*bbsp(wl,tk) + .5;
377 }
378 clr->flags = C_CDSPEC|C_CSSPEC;
379 return(1);
380 }
381
382 #undef C1
383 #undef C2
384 #undef bbsp
385 #undef bblm
