--- ray/src/common/ccolor.c 2012/05/17 05:47:59 3.2 +++ ray/src/common/ccolor.c 2012/05/17 17:10:23 3.3 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: ccolor.c,v 3.2 2012/05/17 05:47:59 greg Exp $"; +static const char RCSid[] = "$Id: ccolor.c,v 3.3 2012/05/17 17:10:23 greg Exp $"; #endif /* * Spectral color handling routines @@ -110,6 +110,82 @@ c_fromSharpRGB(float cin[3], C_COLOR *cout) return(xyz[1]); } +/* assign arbitrary spectrum */ +double +c_sset(C_COLOR *clr, double wlmin, double wlmax, const float spec[], int nwl) +{ + double yval, scale; + float va[C_CNSS]; + int i, pos, n, imax, wl; + double wl0, wlstep; + double boxpos, boxstep; + /* check arguments */ + if ((nwl <= 1) | (spec == NULL) | (wlmin >= C_CMAXWL) | + (wlmax <= C_CMINWL) | (wlmin >= wlmax)) + return(0.); + wlstep = (wlmax - wlmin)/(nwl-1); + while (wlmin < C_CMINWL) { + wlmin += wlstep; + --nwl; ++spec; + } + while (wlmax > C_CMAXWL) { + wlmax -= wlstep; + --nwl; + } + imax = nwl; /* box filter if necessary */ + boxpos = 0; + boxstep = 1; + if (wlstep < C_CWLI) { + imax = (wlmax - wlmin)/C_CWLI + 1e-7; + boxpos = (wlmin - C_CMINWL)/C_CWLI; + boxstep = wlstep/C_CWLI; + wlstep = C_CWLI; + } + scale = 0.; /* get values and maximum */ + yval = 0.; + pos = 0; + for (i = 0; i < imax; i++) { + va[i] = 0.; n = 0; + while (boxpos < i+.5 && pos < nwl) { + va[i] += spec[pos++]; + n++; + boxpos += boxstep; + } + if (n > 1) + va[i] /= (double)n; + if (va[i] > scale) + scale = va[i]; + else if (va[i] < -scale) + scale = -va[i]; + yval += va[i] * cie_yf.ssamp[i]; + } + if (scale <= 1e-7) + return(0.); + yval /= (double)cie_yf.ssum; + scale = C_CMAXV / scale; + clr->ssum = 0; /* convert to our spacing */ + wl0 = wlmin; + pos = 0; + for (i = 0, wl = C_CMINWL; i < C_CNSS; i++, wl += C_CWLI) + if ((wl < wlmin) | (wl > wlmax)) + clr->ssamp[i] = 0; + else { + while (wl0 + wlstep < wl+1e-7) { + wl0 += wlstep; + pos++; + } + if ((wl+1e-7 >= wl0) & (wl-1e-7 <= wl0)) + clr->ssamp[i] = scale*va[pos] + .5; + else /* interpolate if necessary */ + clr->ssamp[i] = .5 + scale / wlstep * + ( va[pos]*(wl0+wlstep - wl) + + va[pos+1]*(wl - wl0) ); + clr->ssum += clr->ssamp[i]; + } + clr->flags = C_CDSPEC|C_CSSPEC; + return(yval); +} + /* check if color is grey */ int c_isgrey(C_COLOR *clr) @@ -199,6 +275,8 @@ c_cmix(C_COLOR *cres, double w1, C_COLOR *c1, double w cmix[i] = w1*c1->ssamp[i] + w2*c2->ssamp[i]; if (cmix[i] > scale) scale = cmix[i]; + else if (cmix[i] < -scale) + scale = -cmix[i]; } scale = C_CMAXV / scale; cres->ssum = 0; @@ -238,6 +316,8 @@ c_cmult(C_COLOR *cres, C_COLOR *c1, double y1, C_COLOR cmix[i] = c1->ssamp[i] * c2->ssamp[i]; if (cmix[i] > cmax) cmax = cmix[i]; + else if (cmix[i] < -cmax) + cmax = -cmix[i]; } cmax /= C_CMAXV; if (!cmax) { @@ -250,7 +330,7 @@ c_cmult(C_COLOR *cres, C_COLOR *c1, double y1, C_COLOR cres->flags = C_CDSPEC|C_CSSPEC; c_ccvt(cres, C_CSEFF); /* nasty, but true */ - yres = (y1 * y2 * cie_yf.ssum * C_CLPWM) / + yres = y1 * y2 * cie_yf.ssum * C_CLPWM / (c1->eff*c1->ssum * c2->eff*c2->ssum) * cres->eff*( cres->ssum*(double)cmax + C_CNSS/2.0*(cmax-1) );
