root/radiance/ray/src/common/ccolor.c
Thu Apr 13 00:42:01 2017 UTC (7 years, 1 month ago) by greg
CVS Tags: rad5R1, rad5R2, rad5R3, rad5R4
Changes since 3.10: +19 -4 lines
Diff to previous 3.10
Added checks against divide-by-zero
Wed Apr 5 00:54:50 2017 UTC (7 years, 1 month ago) by greg
Changes since 3.9: +3 -3 lines
Diff to previous 3.9
Minor optimization
Sat Jan 23 18:58:35 2016 UTC (8 years, 4 months ago) by greg
Changes since 3.8: +20 -14 lines
Diff to previous 3.8
Added randomization to chroma encoding
Sun Apr 5 01:32:01 2015 UTC (9 years, 1 month ago) by greg
Changes since 3.7: +8 -4 lines
Diff to previous 3.7
Added color rendering to tensor tree and minor fixes to Klems color rendering
Thu Mar 26 15:57:19 2015 UTC (9 years, 1 month ago) by greg
Changes since 3.6: +37 -1 lines
Diff to previous 3.6
Added chromaticity encode/decode functions
Tue Jul 17 23:40:24 2012 UTC (11 years, 10 months ago) by greg
Changes since 3.5: +7 -4 lines
Diff to previous 3.5
Additional error-checking
Tue Jun 26 17:59:16 2012 UTC (11 years, 10 months ago) by greg
Changes since 3.4: +18 -18 lines
Diff to previous 3.4
Made CIE 1931 curves external
Fri May 18 20:43:13 2012 UTC (12 years ago) by greg
Changes since 3.3: +29 -27 lines
Diff to previous 3.3
Exposed c_toSharpRGB() and c_fromSharpRGB()
Thu May 17 17:10:23 2012 UTC (12 years ago) by greg
Changes since 3.2: +82 -2 lines
Diff to previous 3.2
Added spectrum assignment function c_sset()
Thu May 17 05:47:59 2012 UTC (12 years ago) by greg
Changes since 3.1: +109 -10 lines
Added spectral color multiplication
