1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: ccolor.c,v 3.10 2017/04/05 00:54:50 greg Exp $"; |
3 |
#endif |
4 |
5 |
* Spectral color handling routines |
6 |
7 |
8 |
#include <stdio.h> |
9 |
#include <stdlib.h> |
10 |
#include <math.h> |
11 |
#include "ccolor.h" |
12 |
13 |
#undef frand |
14 |
#define frand() (rand()*(1./(RAND_MAX+.5))) |
15 |
16 |
/* Sharp primary matrix */ |
17 |
float XYZtoSharp[3][3] = { |
18 |
{ 1.2694, -0.0988, -0.1706}, |
19 |
{-0.8364, 1.8006, 0.0357}, |
20 |
{ 0.0297, -0.0315, 1.0018} |
21 |
22 |
/* inverse Sharp primary matrix */ |
23 |
float XYZfromSharp[3][3] = { |
24 |
{ 0.8156, 0.0472, 0.1372}, |
25 |
{ 0.3791, 0.5769, 0.0440}, |
26 |
{-0.0123, 0.0167, 0.9955} |
27 |
28 |
29 |
const C_COLOR c_dfcolor = C_DEFCOLOR; |
30 |
31 |
const C_CHROMA c_dfchroma = 49750; /* c_encodeChroma(&c_dfcolor) */ |
32 |
33 |
/* CIE 1931 Standard Observer curves */ |
34 |
const C_COLOR c_x31 = { 1, NULL, C_CDSPEC|C_CSSPEC|C_CSXY|C_CSEFF, |
35 |
{14,42,143,435,1344,2839,3483,3362,2908,1954,956, |
36 |
320,49,93,633,1655,2904,4334,5945,7621,9163,10263, |
37 |
10622,10026,8544,6424,4479,2835,1649,874,468,227, |
38 |
114,58,29,14,7,3,2,1,0}, 106836L, .467, .368, 362.230 |
39 |
40 |
const C_COLOR c_y31 = { 1, NULL, C_CDSPEC|C_CSSPEC|C_CSXY|C_CSEFF, |
41 |
{0,1,4,12,40,116,230,380,600,910,1390,2080,3230, |
42 |
5030,7100,8620,9540,9950,9950,9520,8700,7570,6310, |
43 |
5030,3810,2650,1750,1070,610,320,170,82,41,21,10, |
44 |
5,2,1,1,0,0}, 106856L, .398, .542, 493.525 |
45 |
46 |
const C_COLOR c_z31 = { 1, NULL, C_CDSPEC|C_CSSPEC|C_CSXY|C_CSEFF, |
47 |
{65,201,679,2074,6456,13856,17471,17721,16692, |
48 |
12876,8130,4652,2720,1582,782,422,203,87,39,21,17, |
49 |
11,8,3,2,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0}, |
50 |
106770L, .147, .077, 54.363 |
51 |
52 |
/* Derived CIE 1931 Primaries (imaginary) */ |
53 |
static const C_COLOR cie_xp = { 1, NULL, C_CDSPEC|C_CSSPEC|C_CSXY, |
54 |
{-174,-198,-195,-197,-202,-213,-235,-272,-333, |
55 |
-444,-688,-1232,-2393,-4497,-6876,-6758,-5256, |
56 |
-3100,-815,1320,3200,4782,5998,6861,7408,7754, |
57 |
7980,8120,8199,8240,8271,8292,8309,8283,8469, |
58 |
8336,8336,8336,8336,8336,8336}, |
59 |
127424L, 1., .0, |
60 |
61 |
static const C_COLOR cie_yp = { 1, NULL, C_CDSPEC|C_CSSPEC|C_CSXY, |
62 |
{-451,-431,-431,-430,-427,-417,-399,-366,-312, |
63 |
-204,57,691,2142,4990,8810,9871,9122,7321,5145, |
64 |
3023,1123,-473,-1704,-2572,-3127,-3474,-3704, |
65 |
-3846,-3927,-3968,-3999,-4021,-4038,-4012,-4201, |
66 |
-4066,-4066,-4066,-4066,-4066,-4066}, |
67 |
-23035L, .0, 1., |
68 |
69 |
static const C_COLOR cie_zp = { 1, NULL, C_CDSPEC|C_CSSPEC|C_CSXY, |
70 |
{4051,4054,4052,4053,4054,4056,4059,4064,4071, |
71 |
4074,4056,3967,3677,2933,1492,313,-440,-795, |
72 |
-904,-918,-898,-884,-869,-863,-855,-855,-851, |
73 |
-848,-847,-846,-846,-846,-845,-846,-843,-845, |
74 |
-845,-845,-845,-845,-845}, |
75 |
36057L, .0, .0, |
76 |
77 |
78 |
79 |
/* convert to sharpened RGB color for low-error operations */ |
80 |
void |
81 |
c_toSharpRGB(C_COLOR *cin, double cieY, float cout[3]) |
82 |
83 |
double xyz[3]; |
84 |
85 |
c_ccvt(cin, C_CSXY); |
86 |
87 |
xyz[0] = cin->cx/cin->cy * cieY; |
88 |
xyz[1] = cieY; |
89 |
xyz[2] = (1. - cin->cx - cin->cy)/cin->cy * cieY; |
90 |
91 |
cout[0] = XYZtoSharp[0][0]*xyz[0] + XYZtoSharp[0][1]*xyz[1] + |
92 |
XYZtoSharp[0][2]*xyz[2]; |
93 |
cout[1] = XYZtoSharp[1][0]*xyz[0] + XYZtoSharp[1][1]*xyz[1] + |
94 |
XYZtoSharp[1][2]*xyz[2]; |
95 |
cout[2] = XYZtoSharp[2][0]*xyz[0] + XYZtoSharp[2][1]*xyz[1] + |
96 |
XYZtoSharp[2][2]*xyz[2]; |
97 |
98 |
99 |
/* convert back from sharpened RGB color */ |
100 |
double |
101 |
c_fromSharpRGB(float cin[3], C_COLOR *cout) |
102 |
103 |
double xyz[3], sf; |
104 |
105 |
xyz[1] = XYZfromSharp[1][0]*cin[0] + XYZfromSharp[1][1]*cin[1] + |
106 |
XYZfromSharp[1][2]*cin[2]; |
107 |
if (xyz[1] <= 1e-6) { |
108 |
*cout = c_dfcolor; /* punting, here... */ |
109 |
return xyz[1]; |
110 |
111 |
xyz[0] = XYZfromSharp[0][0]*cin[0] + XYZfromSharp[0][1]*cin[1] + |
112 |
XYZfromSharp[0][2]*cin[2]; |
113 |
xyz[2] = XYZfromSharp[2][0]*cin[0] + XYZfromSharp[2][1]*cin[1] + |
114 |
XYZfromSharp[2][2]*cin[2]; |
115 |
116 |
sf = 1./(xyz[0] + xyz[1] + xyz[2]); |
117 |
118 |
cout->cx = xyz[0] * sf; |
119 |
cout->cy = xyz[1] * sf; |
120 |
cout->flags = C_CDXY|C_CSXY; |
121 |
122 |
return(xyz[1]); |
123 |
124 |
125 |
/* assign arbitrary spectrum and return Y value */ |
126 |
double |
127 |
c_sset(C_COLOR *clr, double wlmin, double wlmax, const float spec[], int nwl) |
128 |
129 |
double yval, scale; |
130 |
float va[C_CNSS]; |
131 |
int i, pos, n, imax, wl; |
132 |
double wl0, wlstep; |
133 |
double boxpos, boxstep; |
134 |
/* check arguments */ |
135 |
if ((nwl <= 1) | (spec == NULL) | (wlmin >= C_CMAXWL) | |
136 |
(wlmax <= C_CMINWL) | (wlmin >= wlmax)) |
137 |
return(0.); |
138 |
wlstep = (wlmax - wlmin)/(nwl-1); |
139 |
while (wlmin < C_CMINWL) { |
140 |
wlmin += wlstep; |
141 |
--nwl; ++spec; |
142 |
143 |
while (wlmax > C_CMAXWL) { |
144 |
wlmax -= wlstep; |
145 |
--nwl; |
146 |
147 |
if ((nwl <= 1) | (wlmin >= wlmax)) |
148 |
return(0.); |
149 |
imax = nwl; /* box filter if necessary */ |
150 |
boxpos = 0; |
151 |
boxstep = 1; |
152 |
if (wlstep < C_CWLI) { |
153 |
imax = (wlmax - wlmin)/C_CWLI + 1e-7; |
154 |
boxpos = (wlmin - C_CMINWL)/C_CWLI; |
155 |
boxstep = wlstep/C_CWLI; |
156 |
wlstep = C_CWLI; |
157 |
158 |
scale = 0.; /* get values and maximum */ |
159 |
yval = 0.; |
160 |
pos = 0; |
161 |
for (i = 0; i < imax; i++) { |
162 |
va[i] = 0.; n = 0; |
163 |
while (boxpos < i+.5 && pos < nwl) { |
164 |
va[i] += spec[pos++]; |
165 |
n++; |
166 |
boxpos += boxstep; |
167 |
168 |
if (n > 1) |
169 |
va[i] /= (double)n; |
170 |
if (va[i] > scale) |
171 |
scale = va[i]; |
172 |
else if (va[i] < -scale) |
173 |
scale = -va[i]; |
174 |
yval += va[i] * c_y31.ssamp[i]; |
175 |
176 |
if (scale <= 1e-7) |
177 |
return(0.); |
178 |
yval /= (double)c_y31.ssum; |
179 |
scale = C_CMAXV / scale; |
180 |
clr->ssum = 0; /* convert to our spacing */ |
181 |
wl0 = wlmin; |
182 |
pos = 0; |
183 |
for (i = 0, wl = C_CMINWL; i < C_CNSS; i++, wl += C_CWLI) |
184 |
if ((wl < wlmin) | (wl > wlmax)) |
185 |
clr->ssamp[i] = 0; |
186 |
else { |
187 |
while (wl0 + wlstep < wl+1e-7) { |
188 |
wl0 += wlstep; |
189 |
pos++; |
190 |
191 |
if ((wl+1e-7 >= wl0) & (wl-1e-7 <= wl0)) |
192 |
clr->ssamp[i] = scale*va[pos] + frand(); |
193 |
else /* interpolate if necessary */ |
194 |
clr->ssamp[i] = frand() + scale / wlstep * |
195 |
( va[pos]*(wl0+wlstep - wl) + |
196 |
va[pos+1]*(wl - wl0) ); |
197 |
clr->ssum += clr->ssamp[i]; |
198 |
199 |
clr->flags = C_CDSPEC|C_CSSPEC; |
200 |
return(yval); |
201 |
202 |
203 |
/* check if color is grey */ |
204 |
int |
205 |
c_isgrey(C_COLOR *clr) |
206 |
207 |
if (!(clr->flags & (C_CSXY|C_CSSPEC))) |
208 |
return(1); /* no settings == grey */ |
209 |
210 |
c_ccvt(clr, C_CSXY); |
211 |
212 |
return(clr->cx >= .323 && clr->cx <= .343 && |
213 |
clr->cy >= .323 && clr->cy <= .343); |
214 |
215 |
216 |
/* convert color representations */ |
217 |
void |
218 |
c_ccvt(C_COLOR *clr, int fl) |
219 |
220 |
double x, y, z; |
221 |
int i; |
222 |
223 |
fl &= ~clr->flags; /* ignore what's done */ |
224 |
if (!fl) /* everything's done! */ |
225 |
return; |
226 |
if (!(clr->flags & (C_CSXY|C_CSSPEC))) { |
227 |
*clr = c_dfcolor; /* nothing was set! */ |
228 |
return; |
229 |
230 |
if (fl & C_CSXY) { /* cspec -> cxy */ |
231 |
x = y = z = 0.; |
232 |
for (i = 0; i < C_CNSS; i++) { |
233 |
x += c_x31.ssamp[i] * clr->ssamp[i]; |
234 |
y += c_y31.ssamp[i] * clr->ssamp[i]; |
235 |
z += c_z31.ssamp[i] * clr->ssamp[i]; |
236 |
237 |
x /= (double)c_x31.ssum; |
238 |
y /= (double)c_y31.ssum; |
239 |
z /= (double)c_z31.ssum; |
240 |
z += x + y; |
241 |
if (z > 1e-6) { |
242 |
clr->cx = x / z; |
243 |
clr->cy = y / z; |
244 |
} else |
245 |
clr->cx = clr->cy = 1./3.; |
246 |
clr->flags |= C_CSXY; |
247 |
248 |
if (fl & C_CSSPEC) { /* cxy -> cspec */ |
249 |
x = clr->cx; |
250 |
y = clr->cy; |
251 |
z = 1. - x - y; |
252 |
clr->ssum = 0; |
253 |
254 |
clr->ssamp[i] = x*cie_xp.ssamp[i] + y*cie_yp.ssamp[i] |
255 |
+ z*cie_zp.ssamp[i] + frand(); |
256 |
if (clr->ssamp[i] < 0) /* out of gamut! */ |
257 |
258 |
else |
259 |
260 |
261 |
clr->flags |= C_CSSPEC; |
262 |
263 |
if (fl & C_CSEFF) { /* compute efficacy */ |
264 |
if (clr->flags & C_CSSPEC) { /* from spectrum */ |
265 |
y = 0.; |
266 |
for (i = 0; i < C_CNSS; i++) |
267 |
268 |
clr->eff = C_CLPWM * y / (clr->ssum + 0.0001); |
269 |
} else /* clr->flags & C_CSXY */ { /* from (x,y) */ |
270 |
clr->eff = clr->cx*c_x31.eff + clr->cy*c_y31.eff + |
271 |
(1. - clr->cx - clr->cy)*c_z31.eff; |
272 |
273 |
clr->flags |= C_CSEFF; |
274 |
275 |
276 |
277 |
/* mix two colors according to weights given -- cres may be c1 or c2 */ |
278 |
void |
279 |
c_cmix(C_COLOR *cres, double w1, C_COLOR *c1, double w2, C_COLOR *c2) |
280 |
281 |
double scale; |
282 |
int i; |
283 |
284 |
if (w1 == 0) { |
285 |
*cres = *c2; |
286 |
return; |
287 |
288 |
if (w2 == 0) { |
289 |
*cres = *c1; |
290 |
return; |
291 |
292 |
if ((c1->flags|c2->flags) & C_CDSPEC) { /* spectral mixing */ |
293 |
float cmix[C_CNSS]; |
294 |
295 |
c_ccvt(c1, C_CSSPEC|C_CSEFF); |
296 |
c_ccvt(c2, C_CSSPEC|C_CSEFF); |
297 |
if (c1->ssum*c2->ssum == 0) { |
298 |
*cres = c_dfcolor; |
299 |
return; |
300 |
301 |
w1 /= c1->eff*c1->ssum; |
302 |
w2 /= c2->eff*c2->ssum; |
303 |
scale = 0.; |
304 |
305 |
cmix[i] = w1*c1->ssamp[i] + w2*c2->ssamp[i]; |
306 |
if (cmix[i] > scale) |
307 |
scale = cmix[i]; |
308 |
else if (cmix[i] < -scale) |
309 |
scale = -cmix[i]; |
310 |
311 |
312 |
cres->ssum = 0; |
313 |
314 |
cres->ssum += cres->ssamp[i] = scale*cmix[i] + frand(); |
315 |
cres->flags = C_CDSPEC|C_CSSPEC; |
316 |
} else { /* CIE xy mixing */ |
317 |
c_ccvt(c1, C_CSXY); |
318 |
c_ccvt(c2, C_CSXY); |
319 |
w1 *= c2->cy; |
320 |
w2 *= c1->cy; |
321 |
scale = w1 + w2; |
322 |
if (scale == 0.) { |
323 |
324 |
return; |
325 |
326 |
scale = 1. / scale; |
327 |
cres->cx = (w1*c1->cx + w2*c2->cx) * scale; |
328 |
cres->cy = (w1*c1->cy + w2*c2->cy) * scale; |
329 |
cres->flags = C_CDXY|C_CSXY; |
330 |
331 |
332 |
333 |
/* multiply two colors -- cres may be c1 or c2 */ |
334 |
double |
335 |
c_cmult(C_COLOR *cres, C_COLOR *c1, double y1, C_COLOR *c2, double y2) |
336 |
337 |
double yres; |
338 |
int i; |
339 |
340 |
if ((c1->flags|c2->flags) & C_CDSPEC) { |
341 |
long cmix[C_CNSS], cmax = 0; /* spectral multiply */ |
342 |
343 |
344 |
345 |
346 |
cmix[i] = c1->ssamp[i] * c2->ssamp[i]; |
347 |
if (cmix[i] > cmax) |
348 |
cmax = cmix[i]; |
349 |
else if (cmix[i] < -cmax) |
350 |
cmax = -cmix[i]; |
351 |
352 |
cmax /= C_CMAXV; |
353 |
if (!cmax) { |
354 |
355 |
return(0.); |
356 |
357 |
cres->ssum = 0; |
358 |
359 |
cres->ssum += cres->ssamp[i] = cmix[i] / cmax; |
360 |
361 |
362 |
c_ccvt(cres, C_CSEFF); /* below is correct */ |
363 |
yres = y1 * y2 * c_y31.ssum * C_CLPWM / |
364 |
(c1->eff*c1->ssum * c2->eff*c2->ssum) * |
365 |
cres->eff*( cres->ssum*(double)cmax + |
366 |
C_CNSS/2.0*(cmax-1) ); |
367 |
} else { |
368 |
float rgb1[3], rgb2[3]; /* CIE xy multiply */ |
369 |
370 |
c_toSharpRGB(c1, y1, rgb1); |
371 |
c_toSharpRGB(c2, y2, rgb2); |
372 |
373 |
rgb2[0] *= rgb1[0]; rgb2[1] *= rgb1[1]; rgb2[2] *= rgb1[2]; |
374 |
375 |
yres = c_fromSharpRGB(rgb2, cres); |
376 |
377 |
return(yres); |
378 |
379 |
380 |
#define C1 3.741832e-16 /* W-m^2 */ |
381 |
#define C2 1.4388e-2 /* m-K */ |
382 |
383 |
#define bbsp(l,t) (C1/((l)*(l)*(l)*(l)*(l)*(exp(C2/((t)*(l)))-1.))) |
384 |
#define bblm(t) (C2*0.2/(t)) |
385 |
386 |
/* set black body spectrum */ |
387 |
int |
388 |
c_bbtemp(C_COLOR *clr, double tk) |
389 |
390 |
double sf, wl; |
391 |
int i; |
392 |
393 |
if (tk < 1000) |
394 |
return(0); |
395 |
wl = bblm(tk); /* scalefactor based on peak */ |
396 |
if (wl < C_CMINWL*1e-9) |
397 |
wl = C_CMINWL*1e-9; |
398 |
else if (wl > C_CMAXWL*1e-9) |
399 |
wl = C_CMAXWL*1e-9; |
400 |
sf = C_CMAXV/bbsp(wl,tk); |
401 |
clr->ssum = 0; |
402 |
403 |
wl = (C_CMINWL + i*C_CWLI)*1e-9; |
404 |
clr->ssum += clr->ssamp[i] = sf*bbsp(wl,tk) + frand(); |
405 |
406 |
407 |
return(1); |
408 |
409 |
410 |
#undef C1 |
411 |
#undef C2 |
412 |
#undef bbsp |
413 |
#undef bblm |
414 |
415 |
#define UV_NORMF 410. |
416 |
417 |
/* encode (x,y) chromaticity */ |
418 |
C_CHROMA |
419 |
c_encodeChroma(C_COLOR *clr) |
420 |
421 |
double df; |
422 |
int ub, vb; |
423 |
424 |
425 |
df = UV_NORMF/(-2.*clr->cx + 12.*clr->cy + 3.); |
426 |
ub = 4.*clr->cx*df + frand(); |
427 |
if (ub > 0xff) ub = 0xff; |
428 |
else ub *= (ub > 0); |
429 |
vb = 9.*clr->cy*df + frand(); |
430 |
if (vb > 0xff) vb = 0xff; |
431 |
else vb *= (vb > 0); |
432 |
433 |
return(vb<<8 | ub); |
434 |
435 |
436 |
/* decode (x,y) chromaticity */ |
437 |
void |
438 |
c_decodeChroma(C_COLOR *cres, C_CHROMA ccode) |
439 |
440 |
double up = (ccode & 0xff)*(1./UV_NORMF); |
441 |
double vp = (ccode>>8 & 0xff)*(1./UV_NORMF); |
442 |
double df = 1./(6.*up - 16.*vp + 12.); |
443 |
444 |
cres->cx = 9.*up * df; |
445 |
cres->cy = 4.*vp * df; |
446 |
447 |
448 |
449 |
#undef UV_NORMF |
