root/radiance/ray/src/common/calfunc.c
Wed May 10 15:21:20 2006 UTC (19 years, 2 months ago) by greg
Diff to previous 2.14
Fri Nov 14 17:22:06 2003 UTC (21 years, 7 months ago) by schorsch
Diff to previous 2.13
Mon Aug 4 22:37:53 2003 UTC (21 years, 11 months ago) by greg
Changes since 2.12: +24 -24 lines
Diff to previous 2.12
Thu Jul 17 09:21:29 2003 UTC (21 years, 11 months ago) by schorsch
Sat Jun 7 12:50:20 2003 UTC (22 years, 1 month ago) by schorsch
Wed Mar 5 16:16:52 2003 UTC (22 years, 4 months ago) by greg
Tue Feb 25 02:47:21 2003 UTC (22 years, 4 months ago) by greg
Sat Feb 22 02:07:21 2003 UTC (22 years, 4 months ago) by greg
Changes since 2.7: +71 -90 lines
Sun Nov 22 17:29:46 1992 UTC (32 years, 7 months ago) by greg
minor improvement in fundefined()
Sun Nov 22 12:11:48 1992 UTC (32 years, 7 months ago) by greg
calls libupdate() only when necessary
Fri Oct 2 15:58:31 1992 UTC (32 years, 9 months ago) by greg
Changes since 2.4: +2 -27 lines
Thu May 21 10:29:32 1992 UTC (33 years, 1 month ago) by greg
Changes since 2.3: +25 -2 lines
fixes for ev program
Mon May 18 14:15:49 1992 UTC (33 years, 1 month ago) by greg
minor cosmetic changes to libfunc()
Fri May 15 16:38:47 1992 UTC (33 years, 2 months ago) by greg
Changes since 2.1: +19 -11 lines
Tue Nov 12 16:55:16 1991 UTC (33 years, 8 months ago) by greg
Diff to previous 1.9
Fri Aug 2 14:11:17 1991 UTC (33 years, 11 months ago) by greg
Changes since 1.8: +5 -2 lines
Diff to previous 1.8
improved IEEE error reporting slightly
Tue Jul 16 14:26:18 1991 UTC (34 years ago) by greg
Diff to previous 1.7
improved specificity of warning for bad function call
Fri Jun 28 09:31:59 1991 UTC (34 years ago) by greg
Diff to previous 1.6
minor optimization
Fri May 24 13:30:00 1991 UTC (34 years, 1 month ago) by greg
Diff to previous 1.5
added function name to library calls
Fri May 17 08:55:39 1991 UTC (34 years, 2 months ago) by greg
Changes since 1.4: +8 -4 lines
Diff to previous 1.4
fixed bug in functions with more than 31 arguments
Tue Apr 23 15:44:39 1991 UTC (34 years, 2 months ago) by greg
Changes since 1.3: +25 -22 lines
Diff to previous 1.3
Sat Sep 29 11:18:34 1990 UTC (34 years, 9 months ago) by greg
Diff to previous 1.2
removed static requirement for function name -- better anyway
Tue Jun 26 09:15:13 1990 UTC (35 years ago) by greg
Changes since 1.1: +7 -7 lines
Diff to previous 1.1
Thu Feb 2 10:34:28 1989 UTC (36 years, 5 months ago) by greg
