root/radiance/ray/src/common/calfunc.c
Revision: 2.29
Committed: Sun Feb 25 18:36:27 2024 UTC (14 months, 3 weeks ago) by greg
Changes since 2.28: +2 -5 lines
perf: Removed unnecessary test, since argument(0) should never be called
2 static const char RCSid[] = "$Id: calfunc.c,v 2.28 2022/04/08 23:32:25 greg Exp $";
5 * calfunc.c - routines for calcomp using functions.
6 *
7 * If VARIABLE is not set, only library functions
8 * can be accessed.
9 *
10 * 2/19/03 Eliminated conditional compiles in favor of esupport extern.
11 */
12
13 #include "copyright.h"
14
15 #include <stdio.h>
16 #include <string.h>
17 #include <errno.h>
18 #include <math.h>
19
20 #include "rterror.h"
21 #include "calcomp.h"
22
23 /* bits in argument flag (better be right!) */
24 #define AFLAGSIZ (8*sizeof(unsigned long))
25 #define ALISTSIZ 10 /* maximum saved argument list */
26
27 typedef struct activation {
28 char *name; /* function name */
29 struct activation *prev; /* previous activation */
30 double *ap; /* argument list */
31 unsigned long an; /* computed argument flags */
32 EPNODE *fun; /* argument function */
33 } ACTIVATION; /* an activation record */
34
35 static ACTIVATION *curact = NULL;
36
37 static double libfunc(char *fname, VARDEF *vp);
38
39 #ifndef MAXLIB
40 #define MAXLIB 64 /* maximum number of library functions */
41 #endif
42
43 static double l_if(char *), l_select(char *);
44 static double l_min(char *), l_max(char *);
45 static double l_rand(char *);
46 static double l_floor(char *), l_ceil(char *);
47 static double l_sqrt(char *);
48 static double l_sin(char *), l_cos(char *), l_tan(char *);
49 static double l_asin(char *), l_acos(char *), l_atan(char *), l_atan2(char *);
50 static double l_exp(char *), l_log(char *), l_log10(char *);
51
52 /* functions must be listed alphabetically */
53 static LIBR library[MAXLIB] = {
54 { "acos", 1, ':', l_acos },
55 { "asin", 1, ':', l_asin },
56 { "atan", 1, ':', l_atan },
57 { "atan2", 2, ':', l_atan2 },
58 { "ceil", 1, ':', l_ceil },
59 { "cos", 1, ':', l_cos },
60 { "exp", 1, ':', l_exp },
61 { "floor", 1, ':', l_floor },
62 { "if", 3, ':', l_if },
63 { "log", 1, ':', l_log },
64 { "log10", 1, ':', l_log10 },
65 { "max", 1, ':', l_max },
66 { "min", 1, ':', l_min },
67 { "rand", 1, ':', l_rand },
68 { "select", 1, ':', l_select },
69 { "sin", 1, ':', l_sin },
70 { "sqrt", 1, ':', l_sqrt },
71 { "tan", 1, ':', l_tan },
72 };
73
74 static int libsize = 18;
75
76 #define resolve(ep) ((ep)->type==VAR?(ep)->v.ln:argf((ep)->v.chan))
77
78
79 int
80 fundefined( /* return # of req'd arguments for function */
81 char *fname
82 )
83 {
84 LIBR *lp;
85 VARDEF *vp;
86
87 if ((vp = varlookup(fname)) != NULL && vp->def != NULL
88 && vp->def->v.kid->type == FUNC)
89 return(nekids(vp->def->v.kid) - 1);
90 lp = vp != NULL ? vp->lib : liblookup(fname);
91 if (lp == NULL)
92 return(0);
93 return(lp->nargs);
94 }
95
96
97 double
98 funvalue( /* return a function value to the user */
99 char *fname,
100 int n,
101 double *a
102 )
103 {
104 ACTIVATION act;
105 VARDEF *vp;
106 double rval;
107 /* push environment */
108 act.name = fname;
109 act.prev = curact;
110 act.ap = a;
111 if (n < AFLAGSIZ)
112 act.an = (1L<<n)-1;
113 else {
114 act.an = ~0;
115 if (n > AFLAGSIZ)
116 wputs("Excess arguments in funvalue()\n");
117 }
118 act.fun = NULL;
119 curact = &act;
120
121 if ((vp = varlookup(fname)) == NULL || vp->def == NULL
122 || vp->def->v.kid->type != FUNC)
123 rval = libfunc(fname, vp);
124 else
125 rval = evalue(vp->def->v.kid->sibling);
126
127 curact = act.prev; /* pop environment */
128 return(rval);
129 }
130
131
132 void
133 funset( /* set a library function */
134 char *fname,
135 int nargs,
136 int assign,
137 double (*fptr)(char *)
138 )
139 {
140 int oldlibsize = libsize;
141 char *cp;
142 LIBR *lp;
143 /* check for context */
144 for (cp = fname; *cp; cp++)
145 ;
146 if (cp == fname)
147 return;
148 while (cp[-1] == CNTXMARK) {
149 *--cp = '\0';
150 if (cp == fname) return;
151 }
152 if ((lp = liblookup(fname)) == NULL) { /* insert */
153 if (fptr == NULL)
154 return; /* nothing! */
155 if (libsize >= MAXLIB) {
156 eputs("Too many library functons!\n");
157 quit(1);
158 }
159 for (lp = &library[libsize]; lp > library; lp--)
160 if (strcmp(lp[-1].fname, fname) > 0)
161 lp[0] = lp[-1];
162 else
163 break;
164 libsize++;
165 }
166 if (fptr == NULL) { /* delete */
167 while (lp < &library[libsize-1]) {
168 lp[0] = lp[1];
169 lp++;
170 }
171 libsize--;
172 } else { /* or assign */
173 lp[0].fname = fname; /* string must be static! */
174 lp[0].nargs = nargs;
175 lp[0].atyp = assign;
176 lp[0].f = fptr;
177 }
178 if (libsize != oldlibsize)
179 libupdate(fname); /* relink library */
180 }
181
182
183 int
184 nargum(void) /* return number of available arguments */
185 {
186 int n;
187
188 if (curact == NULL)
189 return(0);
190 if (curact->fun == NULL) {
191 for (n = 0; (1L<<n) & curact->an; n++)
192 ;
193 return(n);
194 }
195 return(nekids(curact->fun) - 1);
196 }
197
198
199 double
200 argument(int n) /* return nth argument for active function */
201 {
202 ACTIVATION *actp = curact;
203 EPNODE *ep = NULL;
204 double aval;
205
206 if (!actp | (--n < 0)) {
207 eputs("Bad call to argument!\n");
208 quit(1);
209 }
210 if ((n < AFLAGSIZ) & actp->an >> n) /* already computed? */
211 return(actp->ap[n]);
212
213 if (!actp->fun || !(ep = ekid(actp->fun, n+1))) {
214 eputs(actp->name);
215 eputs(": too few arguments\n");
216 quit(1);
217 }
218 curact = actp->prev; /* previous context */
219 aval = evalue(ep); /* compute argument */
220 curact = actp; /* put back calling context */
221 if (n < ALISTSIZ) { /* save value if room */
222 actp->ap[n] = aval;
223 actp->an |= 1L<<n;
224 }
225 return(aval);
226 }
227
228
229 VARDEF *
230 argf(int n) /* return function def for nth argument */
231 {
232 ACTIVATION *actp;
233 EPNODE *ep;
234
235 for (actp = curact; actp != NULL; actp = actp->prev) {
236
237 if (n <= 0)
238 break;
239
240 if (actp->fun == NULL)
241 goto badarg;
242
243 if ((ep = ekid(actp->fun, n)) == NULL) {
244 eputs(actp->name);
245 eputs(": too few arguments\n");
246 quit(1);
247 }
248 if (ep->type == VAR)
249 return(ep->v.ln); /* found it */
250
251 if (ep->type != ARG)
252 goto badarg;
253
254 n = ep->v.chan; /* try previous context */
255 }
256 eputs("Bad call to argf!\n");
257 quit(1);
258
259 badarg:
260 eputs(actp->name);
261 eputs(": argument not a function\n");
262 quit(1);
263 return NULL; /* pro forma return */
264 }
265
266
267 char *
268 argfun(int n) /* return function name for nth argument */
269 {
270 return(argf(n)->name);
271 }
272
273
274 double
275 efunc(EPNODE *ep) /* evaluate a function */
276 {
277 ACTIVATION act;
278 double alist[ALISTSIZ];
279 double rval;
280 VARDEF *dp;
281 /* push environment */
282 dp = resolve(ep->v.kid);
283 act.name = dp->name;
284 act.prev = curact;
285 act.ap = alist;
286 act.an = 0;
287 act.fun = ep;
288 curact = &act;
289
290 if (dp->def == NULL || dp->def->v.kid->type != FUNC)
291 rval = libfunc(act.name, dp);
292 else
293 rval = evalue(dp->def->v.kid->sibling);
294
295 curact = act.prev; /* pop environment */
296 return(rval);
297 }
298
299
300 LIBR *
301 liblookup(char *fname) /* look up a library function */
302 {
303 int upper, lower;
304 int cm, i;
305
306 lower = 0;
307 upper = cm = libsize;
308
309 while ((i = (lower + upper) >> 1) != cm) {
310 cm = strcmp(fname, library[i].fname);
311 if (cm > 0)
312 lower = i;
313 else if (cm < 0)
314 upper = i;
315 else
316 return(&library[i]);
317 cm = i;
318 }
319 return(NULL);
320 }
321
322
323 /*
324 * The following routines are for internal use:
325 */
326
327
328 static double
329 libfunc( /* execute library function */
330 char *fname,
331 VARDEF *vp
332 )
333 {
334 LIBR *lp;
335 double d;
336 int lasterrno;
337
338 if (vp != NULL)
339 lp = vp->lib;
340 else
341 lp = liblookup(fname);
342 if (lp == NULL) {
343 eputs(fname);
344 eputs(": undefined function\n");
345 quit(1);
346 }
347 lasterrno = errno;
348 errno = 0;
349 d = (*lp->f)(lp->fname);
350 #ifdef isnan
351 if (errno == 0) {
352 if (isnan(d))
353 errno = EDOM;
354 else if (isinf(d))
355 errno = ERANGE;
356 }
357 #endif
358 if ((errno == EDOM) | (errno == ERANGE)) {
359 wputs(fname);
360 if (errno == EDOM)
361 wputs(": domain error\n");
362 else if (errno == ERANGE)
363 wputs(": range error\n");
364 else
365 wputs(": error in call\n");
366 return(0.0);
367 }
368 errno = lasterrno;
369 return(d);
370 }
371
372
373 /*
374 * Library functions:
375 */
376
377
378 static double
379 l_if(char *nm) /* if(cond, then, else) conditional expression */
380 /* cond evaluates true if greater than zero */
381 {
382 if (argument(1) > 0.0)
383 return(argument(2));
384 else
385 return(argument(3));
386 }
387
388
389 static double
390 l_select(char *nm) /* return argument #(A1+1) */
391 {
392 int narg = nargum();
393 double a1 = argument(1);
394 int n = (int)(a1 + .5);
395
396 if ((a1 < -.5) | (n >= narg)) {
397 errno = EDOM;
398 return(0.0);
399 }
400 if (!n) /* asking max index? */
401 return(narg-1);
402 return(argument(n+1));
403 }
404
405
406 static double
407 l_max(char *nm) /* general maximum function */
408 {
409 int n = nargum();
410 double vmax = argument(1);
411
412 while (n > 1) {
413 double v = argument(n--);
414 if (vmax < v)
415 vmax = v;
416 }
417 return(vmax);
418 }
419
420
421 static double
422 l_min(char *nm) /* general minimum function */
423 {
424 int n = nargum();
425 double vmin = argument(1);
426
427 while (n > 1) {
428 double v = argument(n--);
429 if (vmin > v)
430 vmin = v;
431 }
432 return(vmin);
433 }
434
435
436 static double
437 l_rand(char *nm) /* random function between 0 and 1 */
438 {
439 double x;
440
441 x = argument(1);
442 x *= 1.0/(1.0 + x*x) + 2.71828182845904;
443 x += .785398163397447 - floor(x);
444 x = 1e5 / x;
445 return(x - floor(x));
446 }
447
448
449 static double
450 l_floor(char *nm) /* return largest integer not greater than arg1 */
451 {
452 return(floor(argument(1)));
453 }
454
455
456 static double
457 l_ceil(char *nm) /* return smallest integer not less than arg1 */
458 {
459 return(ceil(argument(1)));
460 }
461
462
463 static double
464 l_sqrt(char *nm)
465 {
466 return(sqrt(argument(1)));
467 }
468
469
470 static double
471 l_sin(char *nm)
472 {
473 return(sin(argument(1)));
474 }
475
476
477 static double
478 l_cos(char *nm)
479 {
480 return(cos(argument(1)));
481 }
482
483
484 static double
485 l_tan(char *nm)
486 {
487 return(tan(argument(1)));
488 }
489
490
491 static double
492 l_asin(char *nm)
493 {
494 return(asin(argument(1)));
495 }
496
497
498 static double
499 l_acos(char *nm)
500 {
501 return(acos(argument(1)));
502 }
503
504
505 static double
506 l_atan(char *nm)
507 {
508 return(atan(argument(1)));
509 }
510
511
512 static double
513 l_atan2(char *nm)
514 {
515 return(atan2(argument(1), argument(2)));
516 }
517
518
519 static double
520 l_exp(char *nm)
521 {
522 return(exp(argument(1)));
523 }
524
525
526 static double
527 l_log(char *nm)
528 {
529 return(log(argument(1)));
530 }
531
532
533 static double
534 l_log10(char *nm)
535 {
536 return(log10(argument(1)));
537 }
