--- ray/src/common/calfunc.c 2006/05/10 15:21:20 2.15 +++ ray/src/common/calfunc.c 2015/08/01 23:27:04 2.18 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: calfunc.c,v 2.15 2006/05/10 15:21:20 greg Exp $"; +static const char RCSid[] = "$Id: calfunc.c,v 2.18 2015/08/01 23:27:04 greg Exp $"; #endif /* * calfunc.c - routines for calcomp using functions. @@ -73,11 +73,12 @@ static int libsize = 16; int -fundefined(fname) /* return # of arguments for function */ -char *fname; +fundefined( /* return # of arguments for function */ + char *fname +) { - register LIBR *lp; - register VARDEF *vp; + LIBR *lp; + VARDEF *vp; if ((vp = varlookup(fname)) != NULL && vp->def != NULL && vp->def->v.kid->type == FUNC) @@ -90,13 +91,14 @@ char *fname; double -funvalue(fname, n, a) /* return a function value to the user */ -char *fname; -int n; -double *a; +funvalue( /* return a function value to the user */ + char *fname, + int n, + double *a +) { ACTIVATION act; - register VARDEF *vp; + VARDEF *vp; double rval; /* push environment */ act.name = fname; @@ -121,15 +123,16 @@ double *a; void -funset(fname, nargs, assign, fptr) /* set a library function */ -char *fname; -int nargs; -int assign; -double (*fptr)(char *); +funset( /* set a library function */ + char *fname, + int nargs, + int assign, + double (*fptr)(char *) +) { int oldlibsize = libsize; char *cp; - register LIBR *lp; + LIBR *lp; /* check for context */ for (cp = fname; *cp; cp++) ; @@ -143,21 +146,15 @@ double (*fptr)(char *); quit(1); } for (lp = &library[libsize]; lp > library; lp--) - if (strcmp(lp[-1].fname, fname) > 0) { - lp[0].fname = lp[-1].fname; - lp[0].nargs = lp[-1].nargs; - lp[0].atyp = lp[-1].atyp; - lp[0].f = lp[-1].f; - } else + if (strcmp(lp[-1].fname, fname) > 0) + lp[0] = lp[-1]; + else break; libsize++; } if (fptr == NULL) { /* delete */ while (lp < &library[libsize-1]) { - lp[0].fname = lp[1].fname; - lp[0].nargs = lp[1].nargs; - lp[0].atyp = lp[1].atyp; - lp[0].f = lp[1].f; + lp[0] = lp[1]; lp++; } libsize--; @@ -173,9 +170,9 @@ double (*fptr)(char *); int -nargum() /* return number of available arguments */ +nargum(void) /* return number of available arguments */ { - register int n; + int n; if (curact == NULL) return(0); @@ -189,11 +186,10 @@ nargum() /* return number of available arguments */ double -argument(n) /* return nth argument for active function */ -register int n; +argument(int n) /* return nth argument for active function */ { - register ACTIVATION *actp = curact; - register EPNODE *ep = NULL; + ACTIVATION *actp = curact; + EPNODE *ep = NULL; double aval; if (actp == NULL || --n < 0) { @@ -221,11 +217,10 @@ register int n; VARDEF * -argf(n) /* return function def for nth argument */ -int n; +argf(int n) /* return function def for nth argument */ { - register ACTIVATION *actp; - register EPNODE *ep; + ACTIVATION *actp; + EPNODE *ep; for (actp = curact; actp != NULL; actp = actp->prev) { @@ -260,21 +255,19 @@ badarg: char * -argfun(n) /* return function name for nth argument */ -int n; +argfun(int n) /* return function name for nth argument */ { return(argf(n)->name); } double -efunc(ep) /* evaluate a function */ -register EPNODE *ep; +efunc(EPNODE *ep) /* evaluate a function */ { ACTIVATION act; double alist[ALISTSIZ]; double rval; - register VARDEF *dp; + VARDEF *dp; /* push environment */ dp = resolve(ep->v.kid); act.name = dp->name; @@ -295,11 +288,10 @@ register EPNODE *ep; LIBR * -liblookup(fname) /* look up a library function */ -char *fname; +liblookup(char *fname) /* look up a library function */ { int upper, lower; - register int cm, i; + int cm, i; lower = 0; upper = cm = libsize; @@ -324,11 +316,12 @@ char *fname; static double -libfunc(fname, vp) /* execute library function */ -char *fname; -VARDEF *vp; +libfunc( /* execute library function */ + char *fname, + VARDEF *vp +) { - register LIBR *lp; + LIBR *lp; double d; int lasterrno; @@ -345,11 +338,12 @@ VARDEF *vp; errno = 0; d = (*lp->f)(lp->fname); #ifdef isnan - if (errno == 0) + if (errno == 0) { if (isnan(d)) errno = EDOM; else if (isinf(d)) errno = ERANGE; + } #endif if (errno == EDOM || errno == ERANGE) { wputs(fname); @@ -385,7 +379,7 @@ l_if(char *nm) /* if(cond, then, else) conditional ex static double l_select(char *nm) /* return argument #(A1+1) */ { - register int n; + int n; n = (int)(argument(1) + .5); if (n == 0)
