root/radiance/ray/src/common/calfunc.c
Revision: 2.21
Committed: Mon Jun 10 13:56:52 2019 UTC (5 years ago) by greg
Changes since 2.20: +45 -4 lines
2 static const char RCSid[] = "$Id: calfunc.c,v 2.20 2019/03/04 20:34:13 greg Exp $";
5 * calfunc.c - routines for calcomp using functions.
6 *
7 * If VARIABLE is not set, only library functions
8 * can be accessed.
9 *
10 * 2/19/03 Eliminated conditional compiles in favor of esupport extern.
11 */
12
13 #include "copyright.h"
14
15 #include <stdio.h>
16 #include <string.h>
17 #include <errno.h>
18 #include <math.h>
19
20 #include "rterror.h"
21 #include "calcomp.h"
22
23 /* bits in argument flag (better be right!) */
24 #define AFLAGSIZ (8*sizeof(unsigned long))
25 #define ALISTSIZ 8 /* maximum saved argument list */
26
27 typedef struct activation {
28 char *name; /* function name */
29 struct activation *prev; /* previous activation */
30 double *ap; /* argument list */
31 unsigned long an; /* computed argument flags */
32 EPNODE *fun; /* argument function */
33 } ACTIVATION; /* an activation record */
34
35 static ACTIVATION *curact = NULL;
36
37 static double libfunc(char *fname, VARDEF *vp);
38
39 #ifndef MAXLIB
40 #define MAXLIB 64 /* maximum number of library functions */
41 #endif
42
43 static double l_if(char *), l_select(char *);
44 static double l_min(char *), l_max(char *);
45 static double l_rand(char *);
46 static double l_floor(char *), l_ceil(char *);
47 static double l_sqrt(char *);
48 static double l_sin(char *), l_cos(char *), l_tan(char *);
49 static double l_asin(char *), l_acos(char *), l_atan(char *), l_atan2(char *);
50 static double l_exp(char *), l_log(char *), l_log10(char *);
51
52 /* functions must be listed alphabetically */
53 static LIBR library[MAXLIB] = {
54 { "acos", 1, ':', l_acos },
55 { "asin", 1, ':', l_asin },
56 { "atan", 1, ':', l_atan },
57 { "atan2", 2, ':', l_atan2 },
58 { "ceil", 1, ':', l_ceil },
59 { "cos", 1, ':', l_cos },
60 { "exp", 1, ':', l_exp },
61 { "floor", 1, ':', l_floor },
62 { "if", 3, ':', l_if },
63 { "log", 1, ':', l_log },
64 { "log10", 1, ':', l_log10 },
65 { "max", 1, ':', l_max },
66 { "min", 1, ':', l_min },
67 { "rand", 1, ':', l_rand },
68 { "select", 1, ':', l_select },
69 { "sin", 1, ':', l_sin },
70 { "sqrt", 1, ':', l_sqrt },
71 { "tan", 1, ':', l_tan },
72 };
73
74 static int libsize = 16;
75
76 #define resolve(ep) ((ep)->type==VAR?(ep)->v.ln:argf((ep)->v.chan))
77
78
79 int
80 fundefined( /* return # of req'd arguments for function */
81 char *fname
82 )
83 {
84 LIBR *lp;
85 VARDEF *vp;
86
87 if ((vp = varlookup(fname)) != NULL && vp->def != NULL
88 && vp->def->v.kid->type == FUNC)
89 return(nekids(vp->def->v.kid) - 1);
90 lp = vp != NULL ? vp->lib : liblookup(fname);
91 if (lp == NULL)
92 return(0);
93 return(lp->nargs);
94 }
95
96
97 double
98 funvalue( /* return a function value to the user */
99 char *fname,
100 int n,
101 double *a
102 )
103 {
104 ACTIVATION act;
105 VARDEF *vp;
106 double rval;
107 /* push environment */
108 act.name = fname;
109 act.prev = curact;
110 act.ap = a;
111 if (n < AFLAGSIZ)
112 act.an = (1L<<n)-1;
113 else {
114 act.an = ~0;
115 if (n > AFLAGSIZ)
116 wputs("Excess arguments in funvalue()\n");
117 }
118 act.fun = NULL;
119 curact = &act;
120
121 if ((vp = varlookup(fname)) == NULL || vp->def == NULL
122 || vp->def->v.kid->type != FUNC)
123 rval = libfunc(fname, vp);
124 else
125 rval = evalue(vp->def->v.kid->sibling);
126
127 curact = act.prev; /* pop environment */
128 return(rval);
129 }
130
131
132 void
133 funset( /* set a library function */
134 char *fname,
135 int nargs,
136 int assign,
137 double (*fptr)(char *)
138 )
139 {
140 int oldlibsize = libsize;
141 char *cp;
142 LIBR *lp;
143 /* check for context */
144 for (cp = fname; *cp; cp++)
145 ;
146 if (cp == fname)
147 return;
148 while (cp[-1] == CNTXMARK) {
149 *--cp = '\0';
150 if (cp == fname) return;
151 }
152 if ((lp = liblookup(fname)) == NULL) { /* insert */
153 if (libsize >= MAXLIB) {
154 eputs("Too many library functons!\n");
155 quit(1);
156 }
157 for (lp = &library[libsize]; lp > library; lp--)
158 if (strcmp(lp[-1].fname, fname) > 0)
159 lp[0] = lp[-1];
160 else
161 break;
162 libsize++;
163 }
164 if (fptr == NULL) { /* delete */
165 while (lp < &library[libsize-1]) {
166 lp[0] = lp[1];
167 lp++;
168 }
169 libsize--;
170 } else { /* or assign */
171 lp[0].fname = fname; /* string must be static! */
172 lp[0].nargs = nargs;
173 lp[0].atyp = assign;
174 lp[0].f = fptr;
175 }
176 if (libsize != oldlibsize)
177 libupdate(fname); /* relink library */
178 }
179
180
181 int
182 nargum(void) /* return number of available arguments */
183 {
184 int n;
185
186 if (curact == NULL)
187 return(0);
188 if (curact->fun == NULL) {
189 for (n = 0; (1L<<n) & curact->an; n++)
190 ;
191 return(n);
192 }
193 return(nekids(curact->fun) - 1);
194 }
195
196
197 double
198 argument(int n) /* return nth argument for active function */
199 {
200 ACTIVATION *actp = curact;
201 EPNODE *ep = NULL;
202 double aval;
203
204 if (!n) /* asking for # arguments? */
205 return((double)nargum());
206
207 if (!actp | (--n < 0)) {
208 eputs("Bad call to argument!\n");
209 quit(1);
210 }
211 if ((n < AFLAGSIZ) & actp->an >> n) /* already computed? */
212 return(actp->ap[n]);
213
214 if (!actp->fun || !(ep = ekid(actp->fun, n+1))) {
215 eputs(actp->name);
216 eputs(": too few arguments\n");
217 quit(1);
218 }
219 curact = actp->prev; /* previous context */
220 aval = evalue(ep); /* compute argument */
221 curact = actp; /* put back calling context */
222 if (n < ALISTSIZ) { /* save value if room */
223 actp->ap[n] = aval;
224 actp->an |= 1L<<n;
225 }
226 return(aval);
227 }
228
229
230 VARDEF *
231 argf(int n) /* return function def for nth argument */
232 {
233 ACTIVATION *actp;
234 EPNODE *ep;
235
236 for (actp = curact; actp != NULL; actp = actp->prev) {
237
238 if (n <= 0)
239 break;
240
241 if (actp->fun == NULL)
242 goto badarg;
243
244 if ((ep = ekid(actp->fun, n)) == NULL) {
245 eputs(actp->name);
246 eputs(": too few arguments\n");
247 quit(1);
248 }
249 if (ep->type == VAR)
250 return(ep->v.ln); /* found it */
251
252 if (ep->type != ARG)
253 goto badarg;
254
255 n = ep->v.chan; /* try previous context */
256 }
257 eputs("Bad call to argf!\n");
258 quit(1);
259
260 badarg:
261 eputs(actp->name);
262 eputs(": argument not a function\n");
263 quit(1);
264 return NULL; /* pro forma return */
265 }
266
267
268 char *
269 argfun(int n) /* return function name for nth argument */
270 {
271 return(argf(n)->name);
272 }
273
274
275 double
276 efunc(EPNODE *ep) /* evaluate a function */
277 {
278 ACTIVATION act;
279 double alist[ALISTSIZ];
280 double rval;
281 VARDEF *dp;
282 /* push environment */
283 dp = resolve(ep->v.kid);
284 act.name = dp->name;
285 act.prev = curact;
286 act.ap = alist;
287 act.an = 0;
288 act.fun = ep;
289 curact = &act;
290
291 if (dp->def == NULL || dp->def->v.kid->type != FUNC)
292 rval = libfunc(act.name, dp);
293 else
294 rval = evalue(dp->def->v.kid->sibling);
295
296 curact = act.prev; /* pop environment */
297 return(rval);
298 }
299
300
301 LIBR *
302 liblookup(char *fname) /* look up a library function */
303 {
304 int upper, lower;
305 int cm, i;
306
307 lower = 0;
308 upper = cm = libsize;
309
310 while ((i = (lower + upper) >> 1) != cm) {
311 cm = strcmp(fname, library[i].fname);
312 if (cm > 0)
313 lower = i;
314 else if (cm < 0)
315 upper = i;
316 else
317 return(&library[i]);
318 cm = i;
319 }
320 return(NULL);
321 }
322
323
324 /*
325 * The following routines are for internal use:
326 */
327
328
329 static double
330 libfunc( /* execute library function */
331 char *fname,
332 VARDEF *vp
333 )
334 {
335 LIBR *lp;
336 double d;
337 int lasterrno;
338
339 if (vp != NULL)
340 lp = vp->lib;
341 else
342 lp = liblookup(fname);
343 if (lp == NULL) {
344 eputs(fname);
345 eputs(": undefined function\n");
346 quit(1);
347 }
348 lasterrno = errno;
349 errno = 0;
350 d = (*lp->f)(lp->fname);
351 #ifdef isnan
352 if (errno == 0) {
353 if (isnan(d))
354 errno = EDOM;
355 else if (isinf(d))
356 errno = ERANGE;
357 }
358 #endif
359 if (errno == EDOM || errno == ERANGE) {
360 wputs(fname);
361 if (errno == EDOM)
362 wputs(": domain error\n");
363 else if (errno == ERANGE)
364 wputs(": range error\n");
365 else
366 wputs(": error in call\n");
367 return(0.0);
368 }
369 errno = lasterrno;
370 return(d);
371 }
372
373
374 /*
375 * Library functions:
376 */
377
378
379 static double
380 l_if(char *nm) /* if(cond, then, else) conditional expression */
381 /* cond evaluates true if greater than zero */
382 {
383 if (argument(1) > 0.0)
384 return(argument(2));
385 else
386 return(argument(3));
387 }
388
389
390 static double
391 l_select(char *nm) /* return argument #(A1+1) */
392 {
393 int n;
394
395 n = (int)(argument(1) + .5);
396 if (n == 0)
397 return(nargum()-1);
398 if (n < 1 || n > nargum()-1) {
399 errno = EDOM;
400 return(0.0);
401 }
402 return(argument(n+1));
403 }
404
405
406 static double
407 l_max(char *nm) /* general maximum function */
408 {
409 int n = nargum();
410 int i = 1;
411 int vmax = argument(1);
412
413 while (i++ < n) {
414 double v = argument(i);
415 if (vmax < v)
416 vmax = v;
417 }
418 return(vmax);
419 }
420
421
422 static double
423 l_min(char *nm) /* general minimum function */
424 {
425 int n = nargum();
426 int i = 1;
427 int vmin = argument(1);
428
429 while (i++ < n) {
430 double v = argument(i);
431 if (vmin > v)
432 vmin = v;
433 }
434 return(vmin);
435 }
436
437
438 static double
439 l_rand(char *nm) /* random function between 0 and 1 */
440 {
441 double x;
442
443 x = argument(1);
444 x *= 1.0/(1.0 + x*x) + 2.71828182845904;
445 x += .785398163397447 - floor(x);
446 x = 1e5 / x;
447 return(x - floor(x));
448 }
449
450
451 static double
452 l_floor(char *nm) /* return largest integer not greater than arg1 */
453 {
454 return(floor(argument(1)));
455 }
456
457
458 static double
459 l_ceil(char *nm) /* return smallest integer not less than arg1 */
460 {
461 return(ceil(argument(1)));
462 }
463
464
465 static double
466 l_sqrt(char *nm)
467 {
468 return(sqrt(argument(1)));
469 }
470
471
472 static double
473 l_sin(char *nm)
474 {
475 return(sin(argument(1)));
476 }
477
478
479 static double
480 l_cos(char *nm)
481 {
482 return(cos(argument(1)));
483 }
484
485
486 static double
487 l_tan(char *nm)
488 {
489 return(tan(argument(1)));
490 }
491
492
493 static double
494 l_asin(char *nm)
495 {
496 return(asin(argument(1)));
497 }
498
499
500 static double
501 l_acos(char *nm)
502 {
503 return(acos(argument(1)));
504 }
505
506
507 static double
508 l_atan(char *nm)
509 {
510 return(atan(argument(1)));
511 }
512
513
514 static double
515 l_atan2(char *nm)
516 {
517 return(atan2(argument(1), argument(2)));
518 }
519
520
521 static double
522 l_exp(char *nm)
523 {
524 return(exp(argument(1)));
525 }
526
527
528 static double
529 l_log(char *nm)
530 {
531 return(log(argument(1)));
532 }
533
534
535 static double
536 l_log10(char *nm)
537 {
538 return(log10(argument(1)));
539 }
