root/radiance/ray/src/common/calfunc.c
Revision: 1.3
Committed: Sat Sep 29 11:18:34 1990 UTC (34 years, 10 months ago) by greg
removed static requirement for function name -- better anyway
1 /* Copyright (c) 1986 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * calfunc.c - routines for calcomp using functions.
9 *
10 * The define BIGLIB pulls in a large number of the
11 * available math routines.
12 *
13 * If VARIABLE is not defined, only library functions
14 * can be accessed.
15 *
16 * 4/2/86
17 */
18
19 #include <stdio.h>
20
21 #include <errno.h>
22
23 #include "calcomp.h"
24
25
26 #define ALISTSIZ 6 /* maximum saved argument list */
27
28 typedef struct activation {
29 char *name; /* function name */
30 struct activation *prev; /* previous activation */
31 double *ap; /* argument list */
32 unsigned long an; /* computed argument flags */
33 EPNODE *fun; /* argument function */
34 } ACTIVATION; /* an activation record */
35
36 static ACTIVATION *curact = NULL;
37
38 static double libfunc();
39
40 #define MAXLIB 64 /* maximum number of library functions */
41
42 static double l_if(), l_select(), l_rand();
43 static double l_floor(), l_ceil();
44 #ifdef BIGLIB
45 static double l_sqrt();
46 static double l_sin(), l_cos(), l_tan();
47 static double l_asin(), l_acos(), l_atan(), l_atan2();
48 static double l_exp(), l_log(), l_log10();
49 #endif
50
51 #ifdef BIGLIB
52 /* functions must be listed alphabetically */
53 static LIBR library[MAXLIB] = {
54 { "acos", 1, l_acos },
55 { "asin", 1, l_asin },
56 { "atan", 1, l_atan },
57 { "atan2", 2, l_atan2 },
58 { "ceil", 1, l_ceil },
59 { "cos", 1, l_cos },
60 { "exp", 1, l_exp },
61 { "floor", 1, l_floor },
62 { "if", 3, l_if },
63 { "log", 1, l_log },
64 { "log10", 1, l_log10 },
65 { "rand", 1, l_rand },
66 { "select", 1, l_select },
67 { "sin", 1, l_sin },
68 { "sqrt", 1, l_sqrt },
69 { "tan", 1, l_tan },
70 };
71
72 static int libsize = 16;
73
74 #else
75 /* functions must be listed alphabetically */
76 static LIBR library[MAXLIB] = {
77 { "ceil", 1, l_ceil },
78 { "floor", 1, l_floor },
79 { "if", 3, l_if },
80 { "rand", 1, l_rand },
81 { "select", 1, l_select },
82 };
83
84 static int libsize = 5;
85
86 #endif
87
88 extern char *savestr(), *emalloc();
89
90 extern LIBR *liblookup();
91
92 extern VARDEF *argf();
93
94 #ifdef VARIABLE
95 #define resolve(ep) ((ep)->type==VAR?(ep)->v.ln:argf((ep)->v.chan))
96 #else
97 #define resolve(ep) ((ep)->v.ln)
98 #define varlookup(name) NULL
99 #endif
100
101
102 int
103 fundefined(fname) /* return # of arguments for function */
104 char *fname;
105 {
106 LIBR *lp;
107 register VARDEF *vp;
108
109 if ((vp = varlookup(fname)) == NULL || vp->def == NULL
110 || vp->def->v.kid->type != FUNC)
111 if ((lp = liblookup(fname)) == NULL)
112 return(0);
113 else
114 return(lp->nargs);
115 else
116 return(nekids(vp->def->v.kid) - 1);
117 }
118
119
120 double
121 funvalue(fname, n, a) /* return a function value to the user */
122 char *fname;
123 int n;
124 double *a;
125 {
126 ACTIVATION act;
127 register VARDEF *vp;
128 double rval;
129 /* push environment */
130 act.name = fname;
131 act.prev = curact;
132 act.ap = a;
133 act.an = (1L<<n)-1;
134 act.fun = NULL;
135 curact = &act;
136
137 if ((vp = varlookup(fname)) == NULL || vp->def == NULL
138 || vp->def->v.kid->type != FUNC)
139 rval = libfunc(fname, vp);
140 else
141 rval = evalue(vp->def->v.kid->sibling);
142
143 curact = act.prev; /* pop environment */
144 return(rval);
145 }
146
147
148 funset(fname, nargs, fptr) /* set a library function */
149 char *fname;
150 int nargs;
151 double (*fptr)();
152 {
153 register LIBR *lp;
154
155 if ((lp = liblookup(fname)) == NULL) {
156 if (libsize >= MAXLIB) {
157 eputs("Too many library functons!\n");
158 quit(1);
159 }
160 for (lp = &library[libsize]; lp > library; lp--)
161 if (strcmp(lp[-1].fname, fname) > 0) {
162 lp[0].fname = lp[-1].fname;
163 lp[0].nargs = lp[-1].nargs;
164 lp[0].f = lp[-1].f;
165 } else
166 break;
167 libsize++;
168 }
169 lp[0].fname = savestr(fname);
170 lp[0].nargs = nargs;
171 lp[0].f = fptr;
172 }
173
174
175 int
176 nargum() /* return number of available arguments */
177 {
178 register int n;
179
180 if (curact == NULL)
181 return(0);
182 if (curact->fun == NULL) {
183 for (n = 0; (1L<<n) & curact->an; n++)
184 ;
185 return(n);
186 }
187 return(nekids(curact->fun) - 1);
188 }
189
190
191 double
192 argument(n) /* return nth argument for active function */
193 register int n;
194 {
195 register ACTIVATION *actp = curact;
196 EPNODE *ep;
197 double aval;
198
199 if (actp == NULL || --n < 0) {
200 eputs("Bad call to argument!\n");
201 quit(1);
202 }
203 /* already computed? */
204 if (1L<<n & actp->an)
205 return(actp->ap[n]);
206
207 if (actp->fun == NULL || (ep = ekid(actp->fun, n+1)) == NULL) {
208 eputs(actp->name);
209 eputs(": too few arguments\n");
210 quit(1);
211 }
212 curact = actp->prev; /* pop environment */
213 aval = evalue(ep); /* compute argument */
214 curact = actp; /* push back environment */
215 if (n < ALISTSIZ) { /* save value */
216 actp->ap[n] = aval;
217 actp->an |= 1L<<n;
218 }
219 return(aval);
220 }
221
222
223 #ifdef VARIABLE
224 VARDEF *
225 argf(n) /* return function def for nth argument */
226 int n;
227 {
228 register ACTIVATION *actp;
229 register EPNODE *ep;
230
231 for (actp = curact; actp != NULL; actp = actp->prev) {
232
233 if (n <= 0)
234 break;
235
236 if (actp->fun == NULL)
237 goto badarg;
238
239 if ((ep = ekid(actp->fun, n)) == NULL) {
240 eputs(actp->name);
241 eputs(": too few arguments\n");
242 quit(1);
243 }
244 if (ep->type == VAR)
245 return(ep->v.ln); /* found it */
246
247 if (ep->type != ARG)
248 goto badarg;
249
250 n = ep->v.chan; /* try previous context */
251 }
252 eputs("Bad call to argf!\n");
253 quit(1);
254
255 badarg:
256 eputs(actp->name);
257 eputs(": argument not a function\n");
258 quit(1);
259 }
260
261
262 char *
263 argfun(n) /* return function name for nth argument */
264 int n;
265 {
266 return(argf(n)->name);
267 }
268 #endif
269
270
271 double
272 efunc(ep) /* evaluate a function */
273 register EPNODE *ep;
274 {
275 ACTIVATION act;
276 double alist[ALISTSIZ];
277 double rval;
278 register VARDEF *dp;
279 /* push environment */
280 dp = resolve(ep->v.kid);
281 act.name = dp->name;
282 act.prev = curact;
283 act.ap = alist;
284 act.an = 0;
285 act.fun = ep;
286 curact = &act;
287
288 if (dp->def == NULL || dp->def->v.kid->type != FUNC)
289 rval = libfunc(act.name, dp);
290 else
291 rval = evalue(dp->def->v.kid->sibling);
292
293 curact = act.prev; /* pop environment */
294 return(rval);
295 }
296
297
298 LIBR *
299 liblookup(fname) /* look up a library function */
300 char *fname;
301 {
302 int upper, lower;
303 register int cm, i;
304
305 lower = 0;
306 upper = cm = libsize;
307
308 while ((i = (lower + upper) >> 1) != cm) {
309 cm = strcmp(fname, library[i].fname);
310 if (cm > 0)
311 lower = i;
312 else if (cm < 0)
313 upper = i;
314 else
315 return(&library[i]);
316 cm = i;
317 }
318 return(NULL);
319 }
320
321
322 #ifndef VARIABLE
323 VARDEF *
324 varinsert(vname) /* dummy variable insert */
325 char *vname;
326 {
327 register VARDEF *vp;
328
329 vp = (VARDEF *)emalloc(sizeof(VARDEF));
330 vp->name = savestr(vname);
331 vp->nlinks = 1;
332 vp->def = NULL;
333 vp->lib = NULL;
334 vp->next = NULL;
335 return(vp);
336 }
337
338
339 varfree(vp) /* free dummy variable */
340 register VARDEF *vp;
341 {
342 freestr(vp->name);
343 efree((char *)vp);
344 }
345 #endif
346
347
348
349 /*
350 * The following routines are for internal use:
351 */
352
353
354 static double
355 libfunc(fname, vp) /* execute library function */
356 char *fname;
357 register VARDEF *vp;
358 {
359 VARDEF dumdef;
360 double d;
361 int lasterrno;
362
363 if (vp == NULL) {
364 vp = &dumdef;
365 vp->lib = NULL;
366 }
367 if (((vp->lib == NULL || strcmp(fname, vp->lib->fname)) &&
368 (vp->lib = liblookup(fname)) == NULL) ||
369 vp->lib->f == NULL) {
370 eputs(fname);
371 eputs(": undefined function\n");
372 quit(1);
373 }
374 lasterrno = errno;
375 errno = 0;
376 d = (*vp->lib->f)();
377 #ifdef IEEE
378 if (!finite(d))
379 errno = EDOM;
380 #endif
381 if (errno) {
382 wputs(fname);
383 wputs(": bad call\n");
384 return(0.0);
385 }
386 errno = lasterrno;
387 return(d);
388 }
389
390
391 /*
392 * Library functions:
393 */
394
395
396 static double
397 l_if() /* if(cond, then, else) conditional expression */
398 /* cond evaluates true if greater than zero */
399 {
400 if (argument(1) > 0.0)
401 return(argument(2));
402 else
403 return(argument(3));
404 }
405
406
407 static double
408 l_select() /* return argument #(A1+1) */
409 {
410 register int n;
411
412 n = argument(1) + .5;
413 if (n == 0)
414 return(nargum()-1);
415 if (n < 1 || n > nargum()-1) {
416 errno = EDOM;
417 return(0.0);
418 }
419 return(argument(n+1));
420 }
421
422
423 static double
424 l_rand() /* random function between 0 and 1 */
425 {
426 extern double floor();
427 double x;
428
429 x = argument(1);
430 x *= 1.0/(1.0 + x*x) + 2.71828182845904;
431 x += .785398163397447 - floor(x);
432 x = 1e5 / x;
433 return(x - floor(x));
434 }
435
436
437 static double
438 l_floor() /* return largest integer not greater than arg1 */
439 {
440 extern double floor();
441
442 return(floor(argument(1)));
443 }
444
445
446 static double
447 l_ceil() /* return smallest integer not less than arg1 */
448 {
449 extern double ceil();
450
451 return(ceil(argument(1)));
452 }
453
454
455 #ifdef BIGLIB
456 static double
457 l_sqrt()
458 {
459 extern double sqrt();
460
461 return(sqrt(argument(1)));
462 }
463
464
465 static double
466 l_sin()
467 {
468 extern double sin();
469
470 return(sin(argument(1)));
471 }
472
473
474 static double
475 l_cos()
476 {
477 extern double cos();
478
479 return(cos(argument(1)));
480 }
481
482
483 static double
484 l_tan()
485 {
486 extern double tan();
487
488 return(tan(argument(1)));
489 }
490
491
492 static double
493 l_asin()
494 {
495 extern double asin();
496
497 return(asin(argument(1)));
498 }
499
500
501 static double
502 l_acos()
503 {
504 extern double acos();
505
506 return(acos(argument(1)));
507 }
508
509
510 static double
511 l_atan()
512 {
513 extern double atan();
514
515 return(atan(argument(1)));
516 }
517
518
519 static double
520 l_atan2()
521 {
522 extern double atan2();
523
524 return(atan2(argument(1), argument(2)));
525 }
526
527
528 static double
529 l_exp()
530 {
531 extern double exp();
532
533 return(exp(argument(1)));
534 }
535
536
537 static double
538 l_log()
539 {
540 extern double log();
541
542 return(log(argument(1)));
543 }
544
545
546 static double
547 l_log10()
548 {
549 extern double log10();
550
551 return(log10(argument(1)));
552 }
553 #endif
