root/Development/ray/src/common/calfunc.c
Revision: 2.17
Committed: Sat Apr 20 02:31:41 2013 UTC (12 years, 7 months ago) by greg
CVS Tags: rad4R2P2, rad4R2P1, rad4R2
Changes since 2.16: +5 -11 lines
Changed from member copy to structure copy
# User Rev Content
1 greg 1.1 #ifndef lint
2 greg 2.17 static const char RCSid[] = "$Id: calfunc.c,v 2.16 2012/10/24 00:39:09 greg Exp $";
3 greg 1.1 #endif
4     /*
5     * calfunc.c - routines for calcomp using functions.
6     *
7 greg 2.8 * If VARIABLE is not set, only library functions
8     * can be accessed.
9     *
10     * 2/19/03 Eliminated conditional compiles in favor of esupport extern.
11     */
12
13 greg 2.9 #include "copyright.h"
14 greg 1.1
15     #include <stdio.h>
16 schorsch 2.11 #include <string.h>
17 greg 1.1 #include <errno.h>
18 greg 2.5 #include <math.h>
19
20 schorsch 2.12 #include "rterror.h"
21 greg 1.1 #include "calcomp.h"
22
23 greg 1.5 /* bits in argument flag (better be right!) */
24     #define AFLAGSIZ (8*sizeof(unsigned long))
25 greg 1.1 #define ALISTSIZ 6 /* maximum saved argument list */
26
27     typedef struct activation {
28     char *name; /* function name */
29     struct activation *prev; /* previous activation */
30     double *ap; /* argument list */
31     unsigned long an; /* computed argument flags */
32     EPNODE *fun; /* argument function */
33     } ACTIVATION; /* an activation record */
34
35     static ACTIVATION *curact = NULL;
36
37 schorsch 2.12 static double libfunc(char *fname, VARDEF *vp);
38 greg 1.1
39 greg 2.8 #ifndef MAXLIB
40 greg 1.1 #define MAXLIB 64 /* maximum number of library functions */
41 greg 2.8 #endif
42 greg 1.1
43 greg 2.13 static double l_if(char *), l_select(char *), l_rand(char *);
44     static double l_floor(char *), l_ceil(char *);
45     static double l_sqrt(char *);
46     static double l_sin(char *), l_cos(char *), l_tan(char *);
47     static double l_asin(char *), l_acos(char *), l_atan(char *), l_atan2(char *);
48     static double l_exp(char *), l_log(char *), l_log10(char *);
49 greg 1.1
50     /* functions must be listed alphabetically */
51     static LIBR library[MAXLIB] = {
52 greg 1.4 { "acos", 1, ':', l_acos },
53     { "asin", 1, ':', l_asin },
54     { "atan", 1, ':', l_atan },
55     { "atan2", 2, ':', l_atan2 },
56     { "ceil", 1, ':', l_ceil },
57     { "cos", 1, ':', l_cos },
58     { "exp", 1, ':', l_exp },
59     { "floor", 1, ':', l_floor },
60     { "if", 3, ':', l_if },
61     { "log", 1, ':', l_log },
62     { "log10", 1, ':', l_log10 },
63     { "rand", 1, ':', l_rand },
64     { "select", 1, ':', l_select },
65     { "sin", 1, ':', l_sin },
66     { "sqrt", 1, ':', l_sqrt },
67     { "tan", 1, ':', l_tan },
68 greg 1.1 };
69
70     static int libsize = 16;
71
72     #define resolve(ep) ((ep)->type==VAR?(ep)->v.ln:argf((ep)->v.chan))
73
74
75     int
76 greg 2.16 fundefined( /* return # of arguments for function */
77     char *fname
78     )
79 greg 1.1 {
80 greg 2.16 LIBR *lp;
81     VARDEF *vp;
82 greg 1.1
83 greg 2.7 if ((vp = varlookup(fname)) != NULL && vp->def != NULL
84     && vp->def->v.kid->type == FUNC)
85 greg 1.1 return(nekids(vp->def->v.kid) - 1);
86 greg 2.7 lp = vp != NULL ? vp->lib : liblookup(fname);
87     if (lp == NULL)
88     return(0);
89     return(lp->nargs);
90 greg 1.1 }
91
92
93     double
94 greg 2.16 funvalue( /* return a function value to the user */
95     char *fname,
96     int n,
97     double *a
98     )
99 greg 1.1 {
100     ACTIVATION act;
101 greg 2.16 VARDEF *vp;
102 greg 1.1 double rval;
103     /* push environment */
104     act.name = fname;
105     act.prev = curact;
106     act.ap = a;
107 greg 1.5 if (n >= AFLAGSIZ)
108     act.an = ~0;
109     else
110     act.an = (1L<<n)-1;
111 greg 1.1 act.fun = NULL;
112     curact = &act;
113
114     if ((vp = varlookup(fname)) == NULL || vp->def == NULL
115     || vp->def->v.kid->type != FUNC)
116     rval = libfunc(fname, vp);
117     else
118     rval = evalue(vp->def->v.kid->sibling);
119
120     curact = act.prev; /* pop environment */
121     return(rval);
122     }
123
124
125 greg 2.8 void
126 greg 2.16 funset( /* set a library function */
127     char *fname,
128     int nargs,
129     int assign,
130     double (*fptr)(char *)
131     )
132 greg 1.1 {
133 greg 2.6 int oldlibsize = libsize;
134 greg 2.8 char *cp;
135 greg 2.16 LIBR *lp;
136 greg 2.8 /* check for context */
137     for (cp = fname; *cp; cp++)
138     ;
139     if (cp == fname)
140     return;
141     if (cp[-1] == CNTXMARK)
142     *--cp = '\0';
143 greg 2.2 if ((lp = liblookup(fname)) == NULL) { /* insert */
144 greg 1.1 if (libsize >= MAXLIB) {
145     eputs("Too many library functons!\n");
146     quit(1);
147     }
148     for (lp = &library[libsize]; lp > library; lp--)
149 greg 2.17 if (strcmp(lp[-1].fname, fname) > 0)
150     lp[0] = lp[-1];
151     else
152 greg 1.1 break;
153     libsize++;
154     }
155 greg 2.2 if (fptr == NULL) { /* delete */
156     while (lp < &library[libsize-1]) {
157 greg 2.17 lp[0] = lp[1];
158 greg 2.2 lp++;
159     }
160     libsize--;
161     } else { /* or assign */
162     lp[0].fname = fname; /* string must be static! */
163     lp[0].nargs = nargs;
164     lp[0].atyp = assign;
165     lp[0].f = fptr;
166     }
167 greg 2.6 if (libsize != oldlibsize)
168     libupdate(fname); /* relink library */
169 greg 1.1 }
170
171
172     int
173 greg 2.16 nargum(void) /* return number of available arguments */
174 greg 1.1 {
175 greg 2.16 int n;
176 greg 1.1
177     if (curact == NULL)
178     return(0);
179     if (curact->fun == NULL) {
180     for (n = 0; (1L<<n) & curact->an; n++)
181     ;
182     return(n);
183     }
184     return(nekids(curact->fun) - 1);
185     }
186
187
188     double
189 greg 2.16 argument(int n) /* return nth argument for active function */
190 greg 1.1 {
191 greg 2.16 ACTIVATION *actp = curact;
192     EPNODE *ep = NULL;
193 greg 1.1 double aval;
194
195     if (actp == NULL || --n < 0) {
196     eputs("Bad call to argument!\n");
197     quit(1);
198     }
199     /* already computed? */
200 greg 1.5 if (n < AFLAGSIZ && 1L<<n & actp->an)
201 greg 1.1 return(actp->ap[n]);
202
203     if (actp->fun == NULL || (ep = ekid(actp->fun, n+1)) == NULL) {
204     eputs(actp->name);
205     eputs(": too few arguments\n");
206     quit(1);
207     }
208     curact = actp->prev; /* pop environment */
209     aval = evalue(ep); /* compute argument */
210     curact = actp; /* push back environment */
211     if (n < ALISTSIZ) { /* save value */
212     actp->ap[n] = aval;
213     actp->an |= 1L<<n;
214     }
215     return(aval);
216     }
217
218
219     VARDEF *
220 greg 2.16 argf(int n) /* return function def for nth argument */
221 greg 1.1 {
222 greg 2.16 ACTIVATION *actp;
223     EPNODE *ep;
224 greg 1.1
225     for (actp = curact; actp != NULL; actp = actp->prev) {
226
227     if (n <= 0)
228     break;
229
230     if (actp->fun == NULL)
231     goto badarg;
232
233     if ((ep = ekid(actp->fun, n)) == NULL) {
234     eputs(actp->name);
235     eputs(": too few arguments\n");
236     quit(1);
237     }
238     if (ep->type == VAR)
239     return(ep->v.ln); /* found it */
240
241     if (ep->type != ARG)
242     goto badarg;
243
244     n = ep->v.chan; /* try previous context */
245     }
246     eputs("Bad call to argf!\n");
247     quit(1);
248
249     badarg:
250     eputs(actp->name);
251     eputs(": argument not a function\n");
252     quit(1);
253 schorsch 2.11 return NULL; /* pro forma return */
254 greg 1.1 }
255
256
257     char *
258 greg 2.16 argfun(int n) /* return function name for nth argument */
259 greg 1.1 {
260     return(argf(n)->name);
261     }
262
263
264     double
265 greg 2.16 efunc(EPNODE *ep) /* evaluate a function */
266 greg 1.1 {
267     ACTIVATION act;
268     double alist[ALISTSIZ];
269     double rval;
270 greg 2.16 VARDEF *dp;
271 greg 1.1 /* push environment */
272     dp = resolve(ep->v.kid);
273     act.name = dp->name;
274     act.prev = curact;
275     act.ap = alist;
276     act.an = 0;
277     act.fun = ep;
278     curact = &act;
279
280     if (dp->def == NULL || dp->def->v.kid->type != FUNC)
281     rval = libfunc(act.name, dp);
282     else
283     rval = evalue(dp->def->v.kid->sibling);
284
285     curact = act.prev; /* pop environment */
286     return(rval);
287     }
288
289
290     LIBR *
291 greg 2.16 liblookup(char *fname) /* look up a library function */
292 greg 1.1 {
293     int upper, lower;
294 greg 2.16 int cm, i;
295 greg 1.1
296     lower = 0;
297     upper = cm = libsize;
298
299     while ((i = (lower + upper) >> 1) != cm) {
300     cm = strcmp(fname, library[i].fname);
301     if (cm > 0)
302     lower = i;
303     else if (cm < 0)
304     upper = i;
305     else
306     return(&library[i]);
307     cm = i;
308     }
309     return(NULL);
310     }
311
312
313     /*
314     * The following routines are for internal use:
315     */
316
317
318     static double
319 greg 2.16 libfunc( /* execute library function */
320     char *fname,
321     VARDEF *vp
322     )
323 greg 1.1 {
324 greg 2.16 LIBR *lp;
325 greg 1.1 double d;
326     int lasterrno;
327
328 greg 2.3 if (vp != NULL)
329     lp = vp->lib;
330     else
331     lp = liblookup(fname);
332     if (lp == NULL) {
333 greg 1.1 eputs(fname);
334     eputs(": undefined function\n");
335     quit(1);
336     }
337     lasterrno = errno;
338     errno = 0;
339 greg 2.3 d = (*lp->f)(lp->fname);
340 greg 2.15 #ifdef isnan
341 greg 1.9 if (errno == 0)
342     if (isnan(d))
343     errno = EDOM;
344     else if (isinf(d))
345     errno = ERANGE;
346 greg 1.1 #endif
347 greg 2.10 if (errno == EDOM || errno == ERANGE) {
348 greg 1.1 wputs(fname);
349 greg 1.8 if (errno == EDOM)
350     wputs(": domain error\n");
351     else if (errno == ERANGE)
352     wputs(": range error\n");
353     else
354     wputs(": error in call\n");
355 greg 1.1 return(0.0);
356     }
357     errno = lasterrno;
358     return(d);
359     }
360
361
362     /*
363     * Library functions:
364     */
365
366
367     static double
368 greg 2.13 l_if(char *nm) /* if(cond, then, else) conditional expression */
369 greg 1.1 /* cond evaluates true if greater than zero */
370     {
371     if (argument(1) > 0.0)
372     return(argument(2));
373     else
374     return(argument(3));
375     }
376
377
378     static double
379 greg 2.13 l_select(char *nm) /* return argument #(A1+1) */
380 greg 1.1 {
381 greg 2.16 int n;
382 greg 1.1
383 schorsch 2.11 n = (int)(argument(1) + .5);
384 greg 1.1 if (n == 0)
385     return(nargum()-1);
386     if (n < 1 || n > nargum()-1) {
387     errno = EDOM;
388     return(0.0);
389     }
390     return(argument(n+1));
391     }
392
393
394     static double
395 greg 2.13 l_rand(char *nm) /* random function between 0 and 1 */
396 greg 1.1 {
397     double x;
398
399     x = argument(1);
400     x *= 1.0/(1.0 + x*x) + 2.71828182845904;
401     x += .785398163397447 - floor(x);
402     x = 1e5 / x;
403     return(x - floor(x));
404     }
405
406
407     static double
408 greg 2.13 l_floor(char *nm) /* return largest integer not greater than arg1 */
409 greg 1.1 {
410     return(floor(argument(1)));
411     }
412
413
414     static double
415 greg 2.13 l_ceil(char *nm) /* return smallest integer not less than arg1 */
416 greg 1.1 {
417     return(ceil(argument(1)));
418     }
419
420
421     static double
422 greg 2.13 l_sqrt(char *nm)
423 greg 1.1 {
424     return(sqrt(argument(1)));
425     }
426
427
428     static double
429 greg 2.13 l_sin(char *nm)
430 greg 1.1 {
431     return(sin(argument(1)));
432     }
433
434
435     static double
436 greg 2.13 l_cos(char *nm)
437 greg 1.1 {
438     return(cos(argument(1)));
439     }
440
441
442     static double
443 greg 2.13 l_tan(char *nm)
444 greg 1.1 {
445     return(tan(argument(1)));
446     }
447
448
449     static double
450 greg 2.13 l_asin(char *nm)
451 greg 1.1 {
452     return(asin(argument(1)));
453     }
454
455
456     static double
457 greg 2.13 l_acos(char *nm)
458 greg 1.1 {
459     return(acos(argument(1)));
460     }
461
462
463     static double
464 greg 2.13 l_atan(char *nm)
465 greg 1.1 {
466     return(atan(argument(1)));
467     }
468
469
470     static double
471 greg 2.13 l_atan2(char *nm)
472 greg 1.1 {
473     return(atan2(argument(1), argument(2)));
474     }
475
476
477     static double
478 greg 2.13 l_exp(char *nm)
479 greg 1.1 {
480     return(exp(argument(1)));
481     }
482
483
484     static double
485 greg 2.13 l_log(char *nm)
486 greg 1.1 {
487     return(log(argument(1)));
488     }
489
490
491     static double
492 greg 2.13 l_log10(char *nm)
493 greg 1.1 {
494     return(log10(argument(1)));
495     }
