root/radiance/ray/src/common/calfunc.c
Revision: 1.4
Committed: Tue Apr 23 15:44:39 1991 UTC (34 years ago) by greg
Changes since 1.3: +25 -22 lines
1 /* Copyright (c) 1986 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * calfunc.c - routines for calcomp using functions.
9 *
10 * The define BIGLIB pulls in a large number of the
11 * available math routines.
12 *
13 * If VARIABLE is not defined, only library functions
14 * can be accessed.
15 *
16 * 4/2/86
17 */
18
19 #include <stdio.h>
20
21 #include <errno.h>
22
23 #include "calcomp.h"
24
25
26 #define ALISTSIZ 6 /* maximum saved argument list */
27
28 typedef struct activation {
29 char *name; /* function name */
30 struct activation *prev; /* previous activation */
31 double *ap; /* argument list */
32 unsigned long an; /* computed argument flags */
33 EPNODE *fun; /* argument function */
34 } ACTIVATION; /* an activation record */
35
36 static ACTIVATION *curact = NULL;
37
38 static double libfunc();
39
40 #define MAXLIB 64 /* maximum number of library functions */
41
42 static double l_if(), l_select(), l_rand();
43 static double l_floor(), l_ceil();
44 #ifdef BIGLIB
45 static double l_sqrt();
46 static double l_sin(), l_cos(), l_tan();
47 static double l_asin(), l_acos(), l_atan(), l_atan2();
48 static double l_exp(), l_log(), l_log10();
49 #endif
50
51 #ifdef BIGLIB
52 /* functions must be listed alphabetically */
53 static LIBR library[MAXLIB] = {
54 { "acos", 1, ':', l_acos },
55 { "asin", 1, ':', l_asin },
56 { "atan", 1, ':', l_atan },
57 { "atan2", 2, ':', l_atan2 },
58 { "ceil", 1, ':', l_ceil },
59 { "cos", 1, ':', l_cos },
60 { "exp", 1, ':', l_exp },
61 { "floor", 1, ':', l_floor },
62 { "if", 3, ':', l_if },
63 { "log", 1, ':', l_log },
64 { "log10", 1, ':', l_log10 },
65 { "rand", 1, ':', l_rand },
66 { "select", 1, ':', l_select },
67 { "sin", 1, ':', l_sin },
68 { "sqrt", 1, ':', l_sqrt },
69 { "tan", 1, ':', l_tan },
70 };
71
72 static int libsize = 16;
73
74 #else
75 /* functions must be listed alphabetically */
76 static LIBR library[MAXLIB] = {
77 { "ceil", 1, ':', l_ceil },
78 { "floor", 1, ':', l_floor },
79 { "if", 3, ':', l_if },
80 { "rand", 1, ':', l_rand },
81 { "select", 1, ':', l_select },
82 };
83
84 static int libsize = 5;
85
86 #endif
87
88 extern char *savestr(), *emalloc();
89
90 extern LIBR *liblookup();
91
92 extern VARDEF *argf();
93
94 #ifdef VARIABLE
95 #define resolve(ep) ((ep)->type==VAR?(ep)->v.ln:argf((ep)->v.chan))
96 #else
97 #define resolve(ep) ((ep)->v.ln)
98 #define varlookup(name) NULL
99 #endif
100
101
102 int
103 fundefined(fname) /* return # of arguments for function */
104 char *fname;
105 {
106 LIBR *lp;
107 register VARDEF *vp;
108
109 if ((vp = varlookup(fname)) == NULL || vp->def == NULL
110 || vp->def->v.kid->type != FUNC)
111 if ((lp = liblookup(fname)) == NULL)
112 return(0);
113 else
114 return(lp->nargs);
115 else
116 return(nekids(vp->def->v.kid) - 1);
117 }
118
119
120 double
121 funvalue(fname, n, a) /* return a function value to the user */
122 char *fname;
123 int n;
124 double *a;
125 {
126 ACTIVATION act;
127 register VARDEF *vp;
128 double rval;
129 /* push environment */
130 act.name = fname;
131 act.prev = curact;
132 act.ap = a;
133 act.an = (1L<<n)-1;
134 act.fun = NULL;
135 curact = &act;
136
137 if ((vp = varlookup(fname)) == NULL || vp->def == NULL
138 || vp->def->v.kid->type != FUNC)
139 rval = libfunc(fname, vp);
140 else
141 rval = evalue(vp->def->v.kid->sibling);
142
143 curact = act.prev; /* pop environment */
144 return(rval);
145 }
146
147
148 funset(fname, nargs, assign, fptr) /* set a library function */
149 char *fname;
150 int nargs;
151 int assign;
152 double (*fptr)();
153 {
154 register LIBR *lp;
155
156 if ((lp = liblookup(fname)) == NULL) {
157 if (libsize >= MAXLIB) {
158 eputs("Too many library functons!\n");
159 quit(1);
160 }
161 for (lp = &library[libsize]; lp > library; lp--)
162 if (strcmp(lp[-1].fname, fname) > 0) {
163 lp[0].fname = lp[-1].fname;
164 lp[0].nargs = lp[-1].nargs;
165 lp[0].atyp = lp[-1].atyp;
166 lp[0].f = lp[-1].f;
167 } else
168 break;
169 libsize++;
170 }
171 lp[0].fname = savestr(fname);
172 lp[0].nargs = nargs;
173 lp[0].atyp = assign;
174 lp[0].f = fptr;
175 }
176
177
178 int
179 nargum() /* return number of available arguments */
180 {
181 register int n;
182
183 if (curact == NULL)
184 return(0);
185 if (curact->fun == NULL) {
186 for (n = 0; (1L<<n) & curact->an; n++)
187 ;
188 return(n);
189 }
190 return(nekids(curact->fun) - 1);
191 }
192
193
194 double
195 argument(n) /* return nth argument for active function */
196 register int n;
197 {
198 register ACTIVATION *actp = curact;
199 EPNODE *ep;
200 double aval;
201
202 if (actp == NULL || --n < 0) {
203 eputs("Bad call to argument!\n");
204 quit(1);
205 }
206 /* already computed? */
207 if (1L<<n & actp->an)
208 return(actp->ap[n]);
209
210 if (actp->fun == NULL || (ep = ekid(actp->fun, n+1)) == NULL) {
211 eputs(actp->name);
212 eputs(": too few arguments\n");
213 quit(1);
214 }
215 curact = actp->prev; /* pop environment */
216 aval = evalue(ep); /* compute argument */
217 curact = actp; /* push back environment */
218 if (n < ALISTSIZ) { /* save value */
219 actp->ap[n] = aval;
220 actp->an |= 1L<<n;
221 }
222 return(aval);
223 }
224
225
226 #ifdef VARIABLE
227 VARDEF *
228 argf(n) /* return function def for nth argument */
229 int n;
230 {
231 register ACTIVATION *actp;
232 register EPNODE *ep;
233
234 for (actp = curact; actp != NULL; actp = actp->prev) {
235
236 if (n <= 0)
237 break;
238
239 if (actp->fun == NULL)
240 goto badarg;
241
242 if ((ep = ekid(actp->fun, n)) == NULL) {
243 eputs(actp->name);
244 eputs(": too few arguments\n");
245 quit(1);
246 }
247 if (ep->type == VAR)
248 return(ep->v.ln); /* found it */
249
250 if (ep->type != ARG)
251 goto badarg;
252
253 n = ep->v.chan; /* try previous context */
254 }
255 eputs("Bad call to argf!\n");
256 quit(1);
257
258 badarg:
259 eputs(actp->name);
260 eputs(": argument not a function\n");
261 quit(1);
262 }
263
264
265 char *
266 argfun(n) /* return function name for nth argument */
267 int n;
268 {
269 return(argf(n)->name);
270 }
271 #endif
272
273
274 double
275 efunc(ep) /* evaluate a function */
276 register EPNODE *ep;
277 {
278 ACTIVATION act;
279 double alist[ALISTSIZ];
280 double rval;
281 register VARDEF *dp;
282 /* push environment */
283 dp = resolve(ep->v.kid);
284 act.name = dp->name;
285 act.prev = curact;
286 act.ap = alist;
287 act.an = 0;
288 act.fun = ep;
289 curact = &act;
290
291 if (dp->def == NULL || dp->def->v.kid->type != FUNC)
292 rval = libfunc(act.name, dp);
293 else
294 rval = evalue(dp->def->v.kid->sibling);
295
296 curact = act.prev; /* pop environment */
297 return(rval);
298 }
299
300
301 LIBR *
302 liblookup(fname) /* look up a library function */
303 char *fname;
304 {
305 int upper, lower;
306 register int cm, i;
307
308 lower = 0;
309 upper = cm = libsize;
310
311 while ((i = (lower + upper) >> 1) != cm) {
312 cm = strcmp(fname, library[i].fname);
313 if (cm > 0)
314 lower = i;
315 else if (cm < 0)
316 upper = i;
317 else
318 return(&library[i]);
319 cm = i;
320 }
321 return(NULL);
322 }
323
324
325 #ifndef VARIABLE
326 VARDEF *
327 varinsert(vname) /* dummy variable insert */
328 char *vname;
329 {
330 register VARDEF *vp;
331
332 vp = (VARDEF *)emalloc(sizeof(VARDEF));
333 vp->name = savestr(vname);
334 vp->nlinks = 1;
335 vp->def = NULL;
336 vp->lib = NULL;
337 vp->next = NULL;
338 return(vp);
339 }
340
341
342 varfree(vp) /* free dummy variable */
343 register VARDEF *vp;
344 {
345 freestr(vp->name);
346 efree((char *)vp);
347 }
348 #endif
349
350
351
352 /*
353 * The following routines are for internal use:
354 */
355
356
357 static double
358 libfunc(fname, vp) /* execute library function */
359 char *fname;
360 register VARDEF *vp;
361 {
362 VARDEF dumdef;
363 double d;
364 int lasterrno;
365
366 if (vp == NULL) {
367 vp = &dumdef;
368 vp->lib = NULL;
369 }
370 if (((vp->lib == NULL || strcmp(fname, vp->lib->fname)) &&
371 (vp->lib = liblookup(fname)) == NULL) ||
372 vp->lib->f == NULL) {
373 eputs(fname);
374 eputs(": undefined function\n");
375 quit(1);
376 }
377 lasterrno = errno;
378 errno = 0;
379 d = (*vp->lib->f)();
380 #ifdef IEEE
381 if (!finite(d))
382 errno = EDOM;
383 #endif
384 if (errno) {
385 wputs(fname);
386 wputs(": bad call\n");
387 return(0.0);
388 }
389 errno = lasterrno;
390 return(d);
391 }
392
393
394 /*
395 * Library functions:
396 */
397
398
399 static double
400 l_if() /* if(cond, then, else) conditional expression */
401 /* cond evaluates true if greater than zero */
402 {
403 if (argument(1) > 0.0)
404 return(argument(2));
405 else
406 return(argument(3));
407 }
408
409
410 static double
411 l_select() /* return argument #(A1+1) */
412 {
413 register int n;
414
415 n = argument(1) + .5;
416 if (n == 0)
417 return(nargum()-1);
418 if (n < 1 || n > nargum()-1) {
419 errno = EDOM;
420 return(0.0);
421 }
422 return(argument(n+1));
423 }
424
425
426 static double
427 l_rand() /* random function between 0 and 1 */
428 {
429 extern double floor();
430 double x;
431
432 x = argument(1);
433 x *= 1.0/(1.0 + x*x) + 2.71828182845904;
434 x += .785398163397447 - floor(x);
435 x = 1e5 / x;
436 return(x - floor(x));
437 }
438
439
440 static double
441 l_floor() /* return largest integer not greater than arg1 */
442 {
443 extern double floor();
444
445 return(floor(argument(1)));
446 }
447
448
449 static double
450 l_ceil() /* return smallest integer not less than arg1 */
451 {
452 extern double ceil();
453
454 return(ceil(argument(1)));
455 }
456
457
458 #ifdef BIGLIB
459 static double
460 l_sqrt()
461 {
462 extern double sqrt();
463
464 return(sqrt(argument(1)));
465 }
466
467
468 static double
469 l_sin()
470 {
471 extern double sin();
472
473 return(sin(argument(1)));
474 }
475
476
477 static double
478 l_cos()
479 {
480 extern double cos();
481
482 return(cos(argument(1)));
483 }
484
485
486 static double
487 l_tan()
488 {
489 extern double tan();
490
491 return(tan(argument(1)));
492 }
493
494
495 static double
496 l_asin()
497 {
498 extern double asin();
499
500 return(asin(argument(1)));
501 }
502
503
504 static double
505 l_acos()
506 {
507 extern double acos();
508
509 return(acos(argument(1)));
510 }
511
512
513 static double
514 l_atan()
515 {
516 extern double atan();
517
518 return(atan(argument(1)));
519 }
520
521
522 static double
523 l_atan2()
524 {
525 extern double atan2();
526
527 return(atan2(argument(1), argument(2)));
528 }
529
530
531 static double
532 l_exp()
533 {
534 extern double exp();
535
536 return(exp(argument(1)));
537 }
538
539
540 static double
541 l_log()
542 {
543 extern double log();
544
545 return(log(argument(1)));
546 }
547
548
549 static double
550 l_log10()
551 {
552 extern double log10();
553
554 return(log10(argument(1)));
555 }
556 #endif
