root/radiance/ray/src/common/calfunc.c
Wed May 10 15:21:20 2006 UTC (18 years ago) by greg
Diff to previous 2.14 , to selected 1.8
Diff to previous 2.13 , to selected 1.8
Changes since 2.12: +24 -24 lines
Diff to previous 2.12 , to selected 1.8
Diff to previous 2.11 , to selected 1.8
Diff to previous 2.10 , to selected 1.8
Wed Mar 5 16:16:52 2003 UTC (21 years, 2 months ago) by greg
Diff to previous 2.9 , to selected 1.8
Diff to previous 2.8 , to selected 1.8
Changes since 2.7: +71 -90 lines
Diff to previous 2.7 , to selected 1.8
Sun Nov 22 17:29:46 1992 UTC (31 years, 6 months ago) by greg
Diff to previous 2.6 , to selected 1.8
minor improvement in fundefined()
Sun Nov 22 12:11:48 1992 UTC (31 years, 6 months ago) by greg
Diff to previous 2.5 , to selected 1.8
calls libupdate() only when necessary
Fri Oct 2 15:58:31 1992 UTC (31 years, 7 months ago) by greg
Changes since 2.4: +2 -27 lines
Diff to previous 2.4 , to selected 1.8
Thu May 21 10:29:32 1992 UTC (32 years ago) by greg
Changes since 2.3: +25 -2 lines
Diff to previous 2.3 , to selected 1.8
fixes for ev program
Mon May 18 14:15:49 1992 UTC (32 years ago) by greg
Diff to previous 2.2 , to selected 1.8
minor cosmetic changes to libfunc()
Fri May 15 16:38:47 1992 UTC (32 years ago) by greg
Changes since 2.1: +19 -11 lines
Diff to previous 2.1 , to selected 1.8
Tue Nov 12 16:55:16 1991 UTC (32 years, 6 months ago) by greg
Diff to previous 1.9 , to selected 1.8
Fri Aug 2 14:11:17 1991 UTC (32 years, 9 months ago) by greg
Changes since 1.8: +5 -2 lines
Diff to previous 1.8
improved IEEE error reporting slightly
Revision 1.8 - (view) (download) (annotate) - [selected]
Tue Jul 16 14:26:18 1991 UTC (32 years, 10 months ago) by greg
Diff to previous 1.7
improved specificity of warning for bad function call
Fri Jun 28 09:31:59 1991 UTC (32 years, 10 months ago) by greg
Diff to previous 1.6 , to selected 1.8
minor optimization
Fri May 24 13:30:00 1991 UTC (33 years ago) by greg
Diff to previous 1.5 , to selected 1.8
added function name to library calls
Fri May 17 08:55:39 1991 UTC (33 years ago) by greg
Changes since 1.4: +8 -4 lines
Diff to previous 1.4 , to selected 1.8
fixed bug in functions with more than 31 arguments
Tue Apr 23 15:44:39 1991 UTC (33 years, 1 month ago) by greg
Changes since 1.3: +25 -22 lines
Diff to previous 1.3 , to selected 1.8
Sat Sep 29 11:18:34 1990 UTC (33 years, 7 months ago) by greg
Diff to previous 1.2 , to selected 1.8
removed static requirement for function name -- better anyway
Tue Jun 26 09:15:13 1990 UTC (33 years, 11 months ago) by greg
Changes since 1.1: +7 -7 lines
Diff to previous 1.1 , to selected 1.8
Thu Feb 2 10:34:28 1989 UTC (35 years, 3 months ago) by greg
Diff to selected 1.8
