Added prototypes and includes from patch by Randolph Fritz. Added more required includes and reduced other compile warnings.
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
minor improvement in fundefined()
calls libupdate() only when necessary
fixes for ev program
minor cosmetic changes to libfunc()
improved IEEE error reporting slightly
improved specificity of warning for bad function call
minor optimization
added function name to library calls
fixed bug in functions with more than 31 arguments
removed static requirement for function name -- better anyway
