| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: calfunc.c,v 2.33 2025/08/14 23:32:28 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* calfunc.c - routines for calcomp using functions.
| 6 |
| 7 |
* If VARIABLE is not set, only library functions
| 8 |
* can be accessed.
| 9 |
| 10 |
* 2/19/03 Eliminated conditional compiles in favor of esupport extern.
| 11 |
| 12 |
| 13 |
#include "copyright.h"
| 14 |
| 15 |
#include <stdio.h>
| 16 |
#include <string.h>
| 17 |
#include <errno.h>
| 18 |
#include <stdlib.h>
| 19 |
#include <math.h>
| 20 |
| 21 |
#include "rterror.h"
| 22 |
#include "calcomp.h"
| 23 |
| 24 |
/* bits in argument flag (better be right!) */
| 25 |
#define AFLAGSIZ (8*sizeof(unsigned long))
| 26 |
#define ALISTSIZ 10 /* maximum saved argument list */
| 27 |
| 28 |
typedef struct activation {
| 29 |
char *name; /* function name */
| 30 |
struct activation *prev; /* previous activation */
| 31 |
double *ap; /* argument list */
| 32 |
unsigned long an; /* computed argument flags */
| 33 |
EPNODE *fun; /* argument function */
| 34 |
} ACTIVATION; /* an activation record */
| 35 |
| 36 |
static ACTIVATION *curact = NULL;
| 37 |
static unsigned long curdepth = 0, next_dreport = 100;
| 38 |
| 39 |
static double libfunc(char *fname, VARDEF *vp);
| 40 |
static void report_depth(char *nm);
| 41 |
| 42 |
#ifndef MAXLIB
| 43 |
#define MAXLIB 64 /* maximum number of library functions */
| 44 |
#endif
| 45 |
| 46 |
static double l_if(char *), l_select(char *);
| 47 |
static double l_min(char *), l_max(char *);
| 48 |
static double l_rand(char *);
| 49 |
static double l_floor(char *), l_ceil(char *);
| 50 |
static double l_sqrt(char *);
| 51 |
static double l_sin(char *), l_cos(char *), l_tan(char *);
| 52 |
static double l_asin(char *), l_acos(char *), l_atan(char *), l_atan2(char *);
| 53 |
static double l_exp(char *), l_log(char *), l_log10(char *);
| 54 |
| 55 |
/* functions must be listed alphabetically */
| 56 |
static ELIBR library[MAXLIB] = {
| 57 |
{ "acos", 1, ':', l_acos },
| 58 |
{ "asin", 1, ':', l_asin },
| 59 |
{ "atan", 1, ':', l_atan },
| 60 |
{ "atan2", 2, ':', l_atan2 },
| 61 |
{ "ceil", 1, ':', l_ceil },
| 62 |
{ "cos", 1, ':', l_cos },
| 63 |
{ "exp", 1, ':', l_exp },
| 64 |
{ "floor", 1, ':', l_floor },
| 65 |
{ "if", 3, ':', l_if },
| 66 |
{ "log", 1, ':', l_log },
| 67 |
{ "log10", 1, ':', l_log10 },
| 68 |
{ "max", 1, ':', l_max },
| 69 |
{ "min", 1, ':', l_min },
| 70 |
{ "rand", 1, ':', l_rand },
| 71 |
{ "select", 1, ':', l_select },
| 72 |
{ "sin", 1, ':', l_sin },
| 73 |
{ "sqrt", 1, ':', l_sqrt },
| 74 |
{ "tan", 1, ':', l_tan },
| 75 |
| 76 |
| 77 |
static int libsize = 18;
| 78 |
| 79 |
#define resolve(ep) ((ep)->type==VAR?(ep)->v.ln:eargf((ep)->v.chan))
| 80 |
| 81 |
| 82 |
int
| 83 |
fundefined( /* return # of req'd arguments for function */
| 84 |
char *fname
| 85 |
| 86 |
| 87 |
ELIBR *lp;
| 88 |
VARDEF *vp;
| 89 |
| 90 |
if ((vp = varlookup(fname)) != NULL && vp->def != NULL
| 91 |
&& vp->def->v.kid->type == FUNC)
| 92 |
return(nekids(vp->def->v.kid) - 1);
| 93 |
lp = vp != NULL ? vp->lib : eliblookup(fname);
| 94 |
if (lp == NULL)
| 95 |
return(0);
| 96 |
return(lp->nargs);
| 97 |
| 98 |
| 99 |
| 100 |
double
| 101 |
funvalue( /* return a function value to the user */
| 102 |
char *fname,
| 103 |
int n,
| 104 |
double *a
| 105 |
| 106 |
| 107 |
ACTIVATION act;
| 108 |
VARDEF *vp;
| 109 |
double rval;
| 110 |
/* push environment */
| 111 |
act.name = fname;
| 112 |
act.prev = curact;
| 113 |
act.ap = a;
| 114 |
if (n < AFLAGSIZ)
| 115 |
act.an = (1L<<n)-1;
| 116 |
else {
| 117 |
act.an = ~0;
| 118 |
if (n > AFLAGSIZ)
| 119 |
wputs("Excess arguments in funvalue()\n");
| 120 |
| 121 |
act.fun = NULL;
| 122 |
curact = &act;
| 123 |
if (++curdepth >= next_dreport)
| 124 |
report_depth(act.name);
| 125 |
| 126 |
if ((vp = varlookup(fname)) == NULL || vp->def == NULL
| 127 |
|| vp->def->v.kid->type != FUNC)
| 128 |
rval = libfunc(fname, vp);
| 129 |
else
| 130 |
rval = evalue(vp->def->v.kid->sibling);
| 131 |
| 132 |
curact = act.prev; curdepth--; /* pop environment */
| 133 |
return(rval);
| 134 |
| 135 |
| 136 |
| 137 |
void
| 138 |
funset( /* set a library function */
| 139 |
char *fname,
| 140 |
int nargs,
| 141 |
int assign,
| 142 |
double (*fptr)(char *)
| 143 |
| 144 |
| 145 |
int oldlibsize = libsize;
| 146 |
char *cp;
| 147 |
ELIBR *lp;
| 148 |
/* check for context */
| 149 |
for (cp = fname; *cp; cp++)
| 150 |
| 151 |
if (cp == fname)
| 152 |
return;
| 153 |
while (cp[-1] == CNTXMARK) {
| 154 |
*--cp = '\0';
| 155 |
if (cp == fname) return;
| 156 |
| 157 |
if ((lp = eliblookup(fname)) == NULL) { /* insert */
| 158 |
if (fptr == NULL)
| 159 |
return; /* nothing! */
| 160 |
if (libsize >= MAXLIB) {
| 161 |
eputs("Too many library functons!\n");
| 162 |
quit(1);
| 163 |
| 164 |
for (lp = &library[libsize]; lp > library; lp--)
| 165 |
if (strcmp(lp[-1].fname, fname) > 0)
| 166 |
lp[0] = lp[-1];
| 167 |
else
| 168 |
break;
| 169 |
libsize++;
| 170 |
| 171 |
if (fptr == NULL) { /* delete */
| 172 |
while (lp < &library[libsize-1]) {
| 173 |
lp[0] = lp[1];
| 174 |
lp++;
| 175 |
| 176 |
libsize--;
| 177 |
} else { /* or assign */
| 178 |
lp[0].fname = fname; /* string must be static! */
| 179 |
lp[0].nargs = nargs;
| 180 |
lp[0].atyp = assign;
| 181 |
lp[0].f = fptr;
| 182 |
| 183 |
if (libsize != oldlibsize)
| 184 |
elibupdate(fname); /* relink library */
| 185 |
| 186 |
| 187 |
| 188 |
int
| 189 |
nargum(void) /* return number of available arguments */
| 190 |
| 191 |
int n;
| 192 |
| 193 |
if (curact == NULL)
| 194 |
return(0);
| 195 |
if (curact->fun == NULL) {
| 196 |
for (n = 0; (1L<<n) & curact->an; n++)
| 197 |
| 198 |
return(n);
| 199 |
| 200 |
return(nekids(curact->fun) - 1);
| 201 |
| 202 |
| 203 |
| 204 |
double
| 205 |
argument(int n) /* return nth argument for active function */
| 206 |
| 207 |
ACTIVATION *actp = curact;
| 208 |
EPNODE *ep;
| 209 |
double aval;
| 210 |
| 211 |
if (!actp | (--n < 0)) {
| 212 |
eputs("Bad call to argument!\n");
| 213 |
quit(1);
| 214 |
| 215 |
if ((n < AFLAGSIZ) & actp->an >> n) /* already computed? */
| 216 |
return(actp->ap[n]);
| 217 |
| 218 |
if (!actp->fun || !(ep = ekid(actp->fun, n+1))) {
| 219 |
eputs(actp->name);
| 220 |
eputs("(): too few arguments\n");
| 221 |
quit(1);
| 222 |
| 223 |
curact = actp->prev; curdepth--; /* previous context */
| 224 |
aval = evalue(ep); /* compute argument */
| 225 |
curact = actp; curdepth++; /* put back calling context */
| 226 |
if (n < ALISTSIZ) { /* save value if room */
| 227 |
actp->ap[n] = aval;
| 228 |
actp->an |= 1L<<n;
| 229 |
| 230 |
return(aval);
| 231 |
| 232 |
| 233 |
| 234 |
VARDEF *
| 235 |
eargf(int n) /* return function def for nth argument */
| 236 |
| 237 |
ACTIVATION *actp;
| 238 |
EPNODE *ep;
| 239 |
| 240 |
for (actp = curact; actp != NULL; actp = actp->prev) {
| 241 |
| 242 |
if (n <= 0)
| 243 |
break;
| 244 |
| 245 |
if (actp->fun == NULL)
| 246 |
goto badarg;
| 247 |
| 248 |
if ((ep = ekid(actp->fun, n)) == NULL) {
| 249 |
eputs(actp->name);
| 250 |
| 251 |
quit(1);
| 252 |
| 253 |
if (ep->type == VAR)
| 254 |
return(ep->v.ln); /* found it */
| 255 |
| 256 |
if (ep->type != ARG)
| 257 |
goto badarg;
| 258 |
| 259 |
n = ep->v.chan; /* try previous context */
| 260 |
| 261 |
eputs("Bad call to eargf!\n");
| 262 |
quit(1);
| 263 |
| 264 |
badarg:
| 265 |
eputs(actp->name);
| 266 |
eputs("(): argument not a function\n");
| 267 |
quit(1);
| 268 |
return NULL; /* pro forma return */
| 269 |
| 270 |
| 271 |
| 272 |
char *
| 273 |
eargfun(int n) /* return function name for nth argument */
| 274 |
| 275 |
return(eargf(n)->name);
| 276 |
| 277 |
| 278 |
| 279 |
double
| 280 |
efunc(EPNODE *ep) /* evaluate a function */
| 281 |
| 282 |
ACTIVATION act;
| 283 |
double alist[ALISTSIZ];
| 284 |
double rval;
| 285 |
VARDEF *dp;
| 286 |
| 287 |
dp = resolve(ep->v.kid);
| 288 |
act.name = dp->name;
| 289 |
act.prev = curact;
| 290 |
act.ap = alist;
| 291 |
act.an = 0;
| 292 |
act.fun = ep;
| 293 |
curact = &act;
| 294 |
| 295 |
| 296 |
| 297 |
if (dp->def == NULL || dp->def->v.kid->type != FUNC)
| 298 |
rval = libfunc(act.name, dp);
| 299 |
else
| 300 |
rval = evalue(dp->def->v.kid->sibling);
| 301 |
| 302 |
| 303 |
return(rval);
| 304 |
| 305 |
| 306 |
| 307 |
double
| 308 |
eargument( /* evaluate an argument */
| 309 |
EPNODE *ep
| 310 |
| 311 |
| 312 |
if ((ep->v.chan <= AFLAGSIZ) & curact->an >> (ep->v.chan-1))
| 313 |
return(curact->ap[ep->v.chan-1]);
| 314 |
| 315 |
return(argument(ep->v.chan));
| 316 |
| 317 |
| 318 |
| 319 |
ELIBR *
| 320 |
eliblookup(char *fname) /* look up a library function */
| 321 |
| 322 |
int upper, lower;
| 323 |
int cm, i;
| 324 |
| 325 |
lower = 0;
| 326 |
upper = cm = libsize;
| 327 |
| 328 |
while ((i = (lower + upper) >> 1) != cm) {
| 329 |
cm = strcmp(fname, library[i].fname);
| 330 |
if (cm > 0)
| 331 |
lower = i;
| 332 |
else if (cm < 0)
| 333 |
upper = i;
| 334 |
else
| 335 |
return(&library[i]);
| 336 |
cm = i;
| 337 |
| 338 |
return(NULL);
| 339 |
| 340 |
| 341 |
| 342 |
| 343 |
* The following routines are for internal use:
| 344 |
| 345 |
| 346 |
| 347 |
static void
| 348 |
report_depth(char *nm) /* report current function call depth */
| 349 |
| 350 |
char msg[RMAXWORD+48];
| 351 |
| 352 |
sprintf(msg, "%s(): depth level at %lu\n", nm, next_dreport);
| 353 |
wputs(msg);
| 354 |
next_dreport *= 10;
| 355 |
| 356 |
| 357 |
| 358 |
static double
| 359 |
libfunc( /* execute library function */
| 360 |
char *fname,
| 361 |
VARDEF *vp
| 362 |
| 363 |
| 364 |
ELIBR *lp;
| 365 |
double d;
| 366 |
int lasterrno;
| 367 |
| 368 |
if (vp != NULL)
| 369 |
lp = vp->lib;
| 370 |
else
| 371 |
lp = eliblookup(fname);
| 372 |
if (lp == NULL) {
| 373 |
eputs(fname);
| 374 |
eputs("(): undefined function\n");
| 375 |
quit(1);
| 376 |
| 377 |
lasterrno = errno;
| 378 |
errno = 0;
| 379 |
d = (*lp->f)(lp->fname);
| 380 |
#ifdef isnan
| 381 |
if (errno == 0) {
| 382 |
if (isnan(d))
| 383 |
errno = EDOM;
| 384 |
else if (isinf(d))
| 385 |
errno = ERANGE;
| 386 |
| 387 |
#endif
| 388 |
if ((errno == EDOM) | (errno == ERANGE)) {
| 389 |
wputs(fname);
| 390 |
if (errno == EDOM)
| 391 |
wputs("(): domain error\n");
| 392 |
else if (errno == ERANGE)
| 393 |
wputs("(): range error\n");
| 394 |
else
| 395 |
wputs("(): error in call\n");
| 396 |
return(0.0);
| 397 |
| 398 |
errno = lasterrno;
| 399 |
return(d);
| 400 |
| 401 |
| 402 |
| 403 |
| 404 |
* Library functions:
| 405 |
| 406 |
| 407 |
| 408 |
static double
| 409 |
l_if(char *nm) /* if(cond, then, else) conditional expression */
| 410 |
/* cond evaluates true if greater than zero */
| 411 |
| 412 |
if (argument(1) > 0.0)
| 413 |
return(argument(2));
| 414 |
else
| 415 |
return(argument(3));
| 416 |
| 417 |
| 418 |
| 419 |
static double
| 420 |
l_select(char *nm) /* return argument #(A1+1) */
| 421 |
| 422 |
int narg = nargum();
| 423 |
double a1 = argument(1);
| 424 |
int n = (int)(a1 + .5);
| 425 |
| 426 |
if ((a1 < -.5) | (n >= narg)) {
| 427 |
errno = EDOM;
| 428 |
return(0.0);
| 429 |
| 430 |
if (!n) /* asking max index? */
| 431 |
return(narg-1);
| 432 |
return(argument(n+1));
| 433 |
| 434 |
| 435 |
| 436 |
static double
| 437 |
l_max(char *nm) /* general maximum function */
| 438 |
| 439 |
int n = nargum();
| 440 |
double vmax = argument(1);
| 441 |
| 442 |
while (n > 1) {
| 443 |
double v = argument(n--);
| 444 |
if (vmax < v)
| 445 |
vmax = v;
| 446 |
| 447 |
return(vmax);
| 448 |
| 449 |
| 450 |
| 451 |
static double
| 452 |
l_min(char *nm) /* general minimum function */
| 453 |
| 454 |
int n = nargum();
| 455 |
double vmin = argument(1);
| 456 |
| 457 |
while (n > 1) {
| 458 |
| 459 |
if (vmin > v)
| 460 |
vmin = v;
| 461 |
| 462 |
return(vmin);
| 463 |
| 464 |
| 465 |
| 466 |
static double
| 467 |
l_rand(char *nm) /* random function between 0 and 1 */
| 468 |
| 469 |
double x;
| 470 |
| 471 |
x = argument(1);
| 472 |
x *= 1.0/(1.0 + x*x) + 2.71828182845904;
| 473 |
x += .785398163397447 - floor(x);
| 474 |
x = 1e5 / x;
| 475 |
return(x - floor(x));
| 476 |
| 477 |
| 478 |
| 479 |
static double
| 480 |
l_floor(char *nm) /* return largest integer not greater than arg1 */
| 481 |
| 482 |
return(floor(argument(1)));
| 483 |
| 484 |
| 485 |
| 486 |
static double
| 487 |
l_ceil(char *nm) /* return smallest integer not less than arg1 */
| 488 |
| 489 |
return(ceil(argument(1)));
| 490 |
| 491 |
| 492 |
| 493 |
static double
| 494 |
l_sqrt(char *nm)
| 495 |
| 496 |
return(sqrt(argument(1)));
| 497 |
| 498 |
| 499 |
| 500 |
static double
| 501 |
l_sin(char *nm)
| 502 |
| 503 |
return(sin(argument(1)));
| 504 |
| 505 |
| 506 |
| 507 |
static double
| 508 |
l_cos(char *nm)
| 509 |
| 510 |
return(cos(argument(1)));
| 511 |
| 512 |
| 513 |
| 514 |
static double
| 515 |
l_tan(char *nm)
| 516 |
| 517 |
return(tan(argument(1)));
| 518 |
| 519 |
| 520 |
| 521 |
static double
| 522 |
l_asin(char *nm)
| 523 |
| 524 |
return(asin(argument(1)));
| 525 |
| 526 |
| 527 |
| 528 |
static double
| 529 |
l_acos(char *nm)
| 530 |
| 531 |
return(acos(argument(1)));
| 532 |
| 533 |
| 534 |
| 535 |
static double
| 536 |
l_atan(char *nm)
| 537 |
| 538 |
return(atan(argument(1)));
| 539 |
| 540 |
| 541 |
| 542 |
static double
| 543 |
l_atan2(char *nm)
| 544 |
| 545 |
return(atan2(argument(1), argument(2)));
| 546 |
| 547 |
| 548 |
| 549 |
static double
| 550 |
l_exp(char *nm)
| 551 |
| 552 |
return(exp(argument(1)));
| 553 |
| 554 |
| 555 |
| 556 |
static double
| 557 |
l_log(char *nm)
| 558 |
| 559 |
return(log(argument(1)));
| 560 |
| 561 |
| 562 |
| 563 |
static double
| 564 |
l_log10(char *nm)
| 565 |
| 566 |
return(log10(argument(1)));
| 567 |
