--- ray/src/common/calfunc.c 2003/02/22 02:07:21 2.8
+++ ray/src/common/calfunc.c 2019/06/11 22:13:50 2.23
@@ -1,5 +1,5 @@
#ifndef lint
-static const char RCSid[] = "$Id: calfunc.c,v 2.8 2003/02/22 02:07:21 greg Exp $";
+static const char RCSid[] = "$Id: calfunc.c,v 2.23 2019/06/11 22:13:50 greg Exp $";
#endif
* calfunc.c - routines for calcomp using functions.
@@ -10,74 +10,19 @@ static const char RCSid[] = "$Id: calfunc.c,v 2.8 2003
* 2/19/03 Eliminated conditional compiles in favor of esupport extern.
- * The Radiance Software License, Version 1.0
- * Copyright (c) 1990 - 2002 The Regents of the University of California,
- * through Lawrence Berkeley National Laboratory. All rights reserved.
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following conditions
- * are met:
- * 1. Redistributions of source code must retain the above copyright
- * notice, this list of conditions and the following disclaimer.
- * 2. Redistributions in binary form must reproduce the above copyright
- * notice, this list of conditions and the following disclaimer in
- * the documentation and/or other materials provided with the
- * distribution.
- * 3. The end-user documentation included with the redistribution,
- * if any, must include the following acknowledgment:
- * "This product includes Radiance software
- * (http://radsite.lbl.gov/)
- * developed by the Lawrence Berkeley National Laboratory
- * (http://www.lbl.gov/)."
- * Alternately, this acknowledgment may appear in the software itself,
- * if and wherever such third-party acknowledgments normally appear.
- * 4. The names "Radiance," "Lawrence Berkeley National Laboratory"
- * and "The Regents of the University of California" must
- * not be used to endorse or promote products derived from this
- * software without prior written permission. For written
- * permission, please contact radiance@radsite.lbl.gov.
- * 5. Products derived from this software may not be called "Radiance",
- * nor may "Radiance" appear in their name, without prior written
- * permission of Lawrence Berkeley National Laboratory.
- * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED
- * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
- * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
- * DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR
- * ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
- * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
- * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
- * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
- * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
- * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
- * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
- * SUCH DAMAGE.
- * This software consists of voluntary contributions made by many
- * individuals on behalf of Lawrence Berkeley National Laboratory. For more
- * information on Lawrence Berkeley National Laboratory, please see
+#include "copyright.h"
#include
+#include
#include
#include
+#include "rterror.h"
#include "calcomp.h"
/* bits in argument flag (better be right!) */
#define AFLAGSIZ (8*sizeof(unsigned long))
-#define ALISTSIZ 6 /* maximum saved argument list */
+#define ALISTSIZ 8 /* maximum saved argument list */
typedef struct activation {
char *name; /* function name */
@@ -89,18 +34,20 @@ typedef struct activation {
static ACTIVATION *curact = NULL;
-static double libfunc();
+static double libfunc(char *fname, VARDEF *vp);
#ifndef MAXLIB
#define MAXLIB 64 /* maximum number of library functions */
#endif
-static double l_if(), l_select(), l_rand();
-static double l_floor(), l_ceil();
-static double l_sqrt();
-static double l_sin(), l_cos(), l_tan();
-static double l_asin(), l_acos(), l_atan(), l_atan2();
-static double l_exp(), l_log(), l_log10();
+static double l_if(char *), l_select(char *);
+static double l_min(char *), l_max(char *);
+static double l_rand(char *);
+static double l_floor(char *), l_ceil(char *);
+static double l_sqrt(char *);
+static double l_sin(char *), l_cos(char *), l_tan(char *);
+static double l_asin(char *), l_acos(char *), l_atan(char *), l_atan2(char *);
+static double l_exp(char *), l_log(char *), l_log10(char *);
/* functions must be listed alphabetically */
static LIBR library[MAXLIB] = {
@@ -115,6 +62,8 @@ static LIBR library[MAXLIB] = {
{ "if", 3, ':', l_if },
{ "log", 1, ':', l_log },
{ "log10", 1, ':', l_log10 },
+ { "max", 1, ':', l_max },
+ { "min", 1, ':', l_min },
{ "rand", 1, ':', l_rand },
{ "select", 1, ':', l_select },
{ "sin", 1, ':', l_sin },
@@ -122,17 +71,18 @@ static LIBR library[MAXLIB] = {
{ "tan", 1, ':', l_tan },
-static int libsize = 16;
+static int libsize = 18;
#define resolve(ep) ((ep)->type==VAR?(ep)->v.ln:argf((ep)->v.chan))
int
-fundefined(fname) /* return # of arguments for function */
-char *fname;
+fundefined( /* return # of req'd arguments for function */
+ char *fname
- register LIBR *lp;
- register VARDEF *vp;
+ LIBR *lp;
+ VARDEF *vp;
if ((vp = varlookup(fname)) != NULL && vp->def != NULL
&& vp->def->v.kid->type == FUNC)
@@ -145,22 +95,26 @@ char *fname;
double
-funvalue(fname, n, a) /* return a function value to the user */
-char *fname;
-int n;
-double *a;
+funvalue( /* return a function value to the user */
+ char *fname,
+ int n,
+ double *a
ACTIVATION act;
+ VARDEF *vp;
double rval;
/* push environment */
act.name = fname;
act.prev = curact;
act.ap = a;
- if (n >= AFLAGSIZ)
- act.an = ~0;
- else
+ if (n < AFLAGSIZ)
act.an = (1L< AFLAGSIZ)
+ wputs("Excess arguments in funvalue()\n");
act.fun = NULL;
curact = &act;
@@ -176,43 +130,40 @@ double *a;
void
-funset(fname, nargs, assign, fptr) /* set a library function */
-char *fname;
-int nargs;
-int assign;
-double (*fptr)();
+funset( /* set a library function */
+ char *fname,
+ int nargs,
+ int assign,
+ double (*fptr)(char *)
int oldlibsize = libsize;
char *cp;
+ LIBR *lp;
/* check for context */
for (cp = fname; *cp; cp++)
if (cp == fname)
return;
- if (cp[-1] == CNTXMARK)
+ while (cp[-1] == CNTXMARK) {
*--cp = '\0';
+ if (cp == fname) return;
if ((lp = liblookup(fname)) == NULL) { /* insert */
if (libsize >= MAXLIB) {
eputs("Too many library functons!\n");
quit(1);
for (lp = &library[libsize]; lp > library; lp--)
- if (strcmp(lp[-1].fname, fname) > 0) {
- lp[0].fname = lp[-1].fname;
- lp[0].nargs = lp[-1].nargs;
- lp[0].atyp = lp[-1].atyp;
- lp[0].f = lp[-1].f;
- } else
+ if (strcmp(lp[-1].fname, fname) > 0)
+ lp[0] = lp[-1];
+ else
break;
libsize++;
if (fptr == NULL) { /* delete */
while (lp < &library[libsize-1]) {
- lp[0].fname = lp[1].fname;
- lp[0].nargs = lp[1].nargs;
- lp[0].atyp = lp[1].atyp;
- lp[0].f = lp[1].f;
+ lp[0] = lp[1];
lp++;
libsize--;
@@ -228,9 +179,9 @@ double (*fptr)();
int
-nargum() /* return number of available arguments */
+nargum(void) /* return number of available arguments */
- register int n;
+ int n;
if (curact == NULL)
return(0);
@@ -244,30 +195,31 @@ nargum() /* return number of available arguments */
double
-argument(n) /* return nth argument for active function */
-register int n;
+argument(int n) /* return nth argument for active function */
- register ACTIVATION *actp = curact;
- register EPNODE *ep;
+ ACTIVATION *actp = curact;
+ EPNODE *ep = NULL;
double aval;
- if (actp == NULL || --n < 0) {
+ if (!n) /* asking for # arguments? */
+ return((double)nargum());
+ if (!actp | (--n < 0)) {
eputs("Bad call to argument!\n");
quit(1);
- /* already computed? */
- if (n < AFLAGSIZ && 1L<an)
+ if ((n < AFLAGSIZ) & actp->an >> n) /* already computed? */
return(actp->ap[n]);
- if (actp->fun == NULL || (ep = ekid(actp->fun, n+1)) == NULL) {
+ if (!actp->fun || !(ep = ekid(actp->fun, n+1))) {
eputs(actp->name);
eputs(": too few arguments\n");
quit(1);
- curact = actp->prev; /* pop environment */
+ curact = actp->prev; /* previous context */
aval = evalue(ep); /* compute argument */
- curact = actp; /* push back environment */
- if (n < ALISTSIZ) { /* save value */
+ curact = actp; /* put back calling context */
+ if (n < ALISTSIZ) { /* save value if room */
actp->ap[n] = aval;
actp->an |= 1L<prev) {
@@ -310,25 +261,24 @@ badarg:
eputs(actp->name);
eputs(": argument not a function\n");
quit(1);
+ return NULL; /* pro forma return */
char *
-argfun(n) /* return function name for nth argument */
-int n;
+argfun(int n) /* return function name for nth argument */
return(argf(n)->name);
double
-efunc(ep) /* evaluate a function */
-register EPNODE *ep;
+efunc(EPNODE *ep) /* evaluate a function */
ACTIVATION act;
double alist[ALISTSIZ];
double rval;
- register VARDEF *dp;
+ VARDEF *dp;
dp = resolve(ep->v.kid);
act.name = dp->name;
@@ -349,11 +299,10 @@ register EPNODE *ep;
LIBR *
-liblookup(fname) /* look up a library function */
-char *fname;
+liblookup(char *fname) /* look up a library function */
int upper, lower;
- register int cm, i;
+ int cm, i;
lower = 0;
upper = cm = libsize;
@@ -378,11 +327,12 @@ char *fname;
static double
-libfunc(fname, vp) /* execute library function */
-char *fname;
-VARDEF *vp;
+libfunc( /* execute library function */
+ char *fname,
+ VARDEF *vp
+ LIBR *lp;
double d;
int lasterrno;
@@ -398,14 +348,15 @@ VARDEF *vp;
lasterrno = errno;
errno = 0;
d = (*lp->f)(lp->fname);
-#ifdef IEEE
- if (errno == 0)
+#ifdef isnan
+ if (errno == 0) {
if (isnan(d))
errno = EDOM;
else if (isinf(d))
errno = ERANGE;
#endif
- if (errno) {
+ if (errno == EDOM || errno == ERANGE) {
wputs(fname);
if (errno == EDOM)
wputs(": domain error\n");
@@ -426,7 +377,7 @@ VARDEF *vp;
static double
-l_if() /* if(cond, then, else) conditional expression */
+l_if(char *nm) /* if(cond, then, else) conditional expression */
/* cond evaluates true if greater than zero */
if (argument(1) > 0.0)
@@ -437,24 +388,57 @@ l_if() /* if(cond, then, else) conditional expressio
static double
-l_select() /* return argument #(A1+1) */
+l_select(char *nm) /* return argument #(A1+1) */
- register int n;
+ int narg = nargum();
+ double a1 = argument(1);
+ int n = (int)(a1 + .5);
- n = argument(1) + .5;
- if (n == 0)
- return(nargum()-1);
- if (n < 1 || n > nargum()-1) {
+ if (a1 < -.5 || n >= narg) {
errno = EDOM;
return(0.0);
+ if (!n) /* asking max index? */
+ return(narg-1);
return(argument(n+1));
static double
-l_rand() /* random function between 0 and 1 */
+l_max(char *nm) /* general maximum function */
+ int n = nargum();
+ int i = 1;
+ int vmax = argument(1);
+ while (i++ < n) {
+ double v = argument(i);
+ if (vmax < v)
+ vmax = v;
+ return(vmax);
+static double
+l_min(char *nm) /* general minimum function */
+ int n = nargum();
+ int i = 1;
+ int vmin = argument(1);
+ while (i++ < n) {
+ if (vmin > v)
+ vmin = v;
+ return(vmin);
+static double
+l_rand(char *nm) /* random function between 0 and 1 */
double x;
x = argument(1);
@@ -466,91 +450,91 @@ l_rand() /* random function between 0 and 1 */
static double
-l_floor() /* return largest integer not greater than arg1 */
+l_floor(char *nm) /* return largest integer not greater than arg1 */
return(floor(argument(1)));
static double
-l_ceil() /* return smallest integer not less than arg1 */
+l_ceil(char *nm) /* return smallest integer not less than arg1 */
return(ceil(argument(1)));
static double
-l_sqrt()
+l_sqrt(char *nm)
return(sqrt(argument(1)));
static double
-l_sin()
+l_sin(char *nm)
return(sin(argument(1)));
static double
-l_cos()
+l_cos(char *nm)
return(cos(argument(1)));
static double
-l_tan()
+l_tan(char *nm)
return(tan(argument(1)));
static double
-l_asin()
+l_asin(char *nm)
return(asin(argument(1)));
static double
-l_acos()
+l_acos(char *nm)
return(acos(argument(1)));
static double
-l_atan()
+l_atan(char *nm)
return(atan(argument(1)));
static double
-l_atan2()
+l_atan2(char *nm)
return(atan2(argument(1), argument(2)));
static double
-l_exp()
+l_exp(char *nm)
return(exp(argument(1)));
static double
-l_log()
+l_log(char *nm)
return(log(argument(1)));
static double
-l_log10()
+l_log10(char *nm)
return(log10(argument(1)));
