fix: Indexing error in last change
perf: Added shortcut to avoid extra call in eargument(), which was bottleneck
perf: Removed unnecessary test, since argument(0) should never be called
perf: Removing some conditionals with binary operations
fix: Fixed regression introduced in last change for min() and max() calls
perf: minor optimization
Added shortcut (should not affect behavior)
Fixed bug in max() and min()
Made stricter range for legal first argument
Corrected library entry count
Removed parentheses for clarity(?)
Minor optimizations in oft-called argument() function
Changed from member copy to structure copy
Finished ANSIfication
Added prototypes and includes from patch by Randolph Fritz. Added more required includes and reduced other compile warnings.
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
minor improvement in fundefined()
calls libupdate() only when necessary
fixes for ev program
minor cosmetic changes to libfunc()
improved IEEE error reporting slightly
improved specificity of warning for bad function call
minor optimization
added function name to library calls
fixed bug in functions with more than 31 arguments
removed static requirement for function name -- better anyway
